HS6's on a BJ8 motor
Lotuswins
Hello All,
I was wondering if anyone can help. I have a
BJ8 motor in my Healey, with HS6 carbs. I've installed needles and springs from a BJ7, rich set, to see if they would work, but the cold start seems pretty lean as it backfires alot. I've richened it out, but it still runs lean, and I fear it will be lean when on the road. I haven't gotten the car on the road as yet since I'm in the middle of body work, but I was wondering if anyone out there has installed the smaller carbs on a BJ8 motor which apparently has a cam with a longer duration and perhaps higher lift.
Since my original HD8's were in very poor condition I opted for the HS6's off a volvo until I got the coin for a new or used set of them. Anyways, perhaps they'll give better gas mileage too......
So, would anyone have the HS6's on a BJ8 motor, and could you recommend needles/springs for this combination?
thanks for any help, and Merry Christmas
Jerry Rude
BJ8 Healey
Lotus Europa TCS
I would send them off to a respected rebuilder. Shouldn't cost more than $400 for the pair for a rebuild.
Did you replace the intake manifold as well. I seem to remember (perhaps not well) that the ports were larger on the BJ8. I don't know if that makes a difference. You might be better off getting the originals rebuilt by someone like Joe C.
The BJ7 from VIN 29F/2286 came from the factory with HS6 carbs and the new cam and valve springs. The later BJ7 cam and valve springs were used in the BJ8 engines until the end of production in March of 1968.
Set up properly, there's no reason to think the HS6s wouldn't be satisfactory, after all, the displacement is the same.
As long as the fuel is in proportion to the air, you could run the BJ8 on a single Spridget carb, it just won't rev very high :wink:
:iagree:
However, selecting the proper needles can be a chore.--Keoke
I wouldn't use them on a BJ8. You should have the original HD8 carbs rebuilt as mentioned. Wait until "you have the coin". The HS6's are 1 3/4" and your intake should be 2", at least that what memory says.
Hi all,
Thanks for the comments, to respond to a few of the questions:
1) I didn't have to change the manifold, the bolt pattern is the same on the HS6 and the HD8 carbs, and the gaskets fit fine.
2) The cams, from what I can determine from the shop manual and the parts manual show that from 29F-2286 to 6188 (VIN 25314) the cam was P/N 12B594 with a duration of 240 degrees (intake and exhaust). That was the end of the BJ7 run.
The BJ8 starts with 29K-H101 and they had cam P/N AEC865 with a duration of 252 degrees Intake & Exhaust.
I understand that when you increase the efficiency of the engine by additional flow potential (cams, headers, porting, etc.) the carburators generally need to be richened up to compensate? The HS6 carbs should perform okay as the SU manual shows two of them good to a maximum of 3 liters.
Anyways, I was just wondering if anyone had toyed with changing the needles to get the right configuration for the combination of the BJ8 cam and HS6 carbs....
I'll check if the needles are BC....I think they are, along with the green springs.
Thanks again, Jerry
Yes, the carbs fit the manifolds, but the manifold ports are bigger so the flow from the little carbs to the big manifold is not smooth and you interrupt the flow. I would have the right carbs rebuilt.
Referencing the Anderson / Moment Restoration Guide (Gary G Anderson, 2000) page 181 Table 4.3. No drivetrain change to the BJ8 cam is indicated after 10/62…
The BMC BJ7 and BJ8 Mechanical Service Parts List indicates three camshafts – ACE 2029 (29F-H101 to 2285), 12B 594 (29F-H2286 to 6188 29FF-H101 to 164) and AEC 865 (29K-H101 on 29KF-H101 on).
Can I assume the Anderson / Moment Guide table is incorrect?
Any cam lift changes or just the 12 degree duration change Jerry indicated with the later BJ8 camshaft?
Lots of misinformation out there.
The BJ8 had a different cam from all the earlier cars, but it had been used as the standard Competition spec cam for the earlier cars as well. And this cam profile was carried over to the MGC.
This cam should work for any carb combination you can find that fits the Healey, twin HS6/HD6, triple HS4, triple HS6, twin HD8 or triple HD8s like I have. Simply a matter of having the right setup in the carbs.
Yes there will be a step from the carb throat into the manifold, but it shouldn't affect mixture. That is a function of vacuum, needles, springs and dampers.
You should be able to properly setup the HS6s to the BJ7 tuning and get by temporarily, but I would expect a BJ8 to have twin HD8s. Get yours professionally rebuilt as soon as you can. They will work better that way.
C Ya,
Mark
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Y TR6 SU HS6 question Triumph 1
J TR6 Moss HS6 SU conversion kit question Triumph 4
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
D TR4/4A SU HS6 throttle spindle size Triumph 20
BLong63AH HS6 BJ7 Carb Insulators Austin Healey 5
T TR4/4A HS6 problem Triumph 6
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
KVH General Tech HS6 SU Carbs Triumph 1
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
Simmo TR2/3/3A HS6 Carburettors Triumph 4
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
G TR4/4A tr4a hs6 carb Triumph 1
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
Hap Waldrop SU H6 and HS6 carbs Triumph 9
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
T SU HS6 tuning - lifting pin question Triumph 11
H TR6 TR6 HS6 Needle selection Triumph 0
TR4nut TR4/4A TR4A HS6 Factory writeup? Triumph 9
KVH HS6 SU Carbs Triumph 2
K H6 SU carb dome and HS6 carb dome? Triumph 9
T HS6 idle setting Triumph 3
R SU HS6 Carbs overflow leaking........... MG 20
T NLA SU HS6 part request Triumph 10
T Anyone have a spare HS6 pivot bolt Triumph 13
S HS6 Carburetor Austin Healey 16
T One more SU HS6 question Triumph 25
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
T TR2/3/3A Will HS6 fit in TR3? Triumph 10
H HS6 Fixed needle centering tips Triumph 1
B Measurements of HS6 Carb MG 12
H TR6 TR6 HS6 Conversion Triumph 6
H HS6 JET identification Triumph 2
H TR6 Volvo HS6 Carbs on a TR6 Triumph 9
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
H TR6 HS6 for Tr6 -Pics Needed Triumph 1
T TR6 HS6's on a TR6 Triumph 14
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
