HS6 BJ7 Carb Insulators
BLong63AH
Member
HS6 BJ7 Carb Insulator Blocks # Needed?
Having to do a little work on my HS6 Carbs and I noticed when ordering a rebuild kit that I have more than 4 total insulator blocks? Catalogs and pics I have seen show 4 total, one, two total, on each side of the heat shield. Is there any possible reason/benefit for having more?
I think the originals were black phenolic--aka Bakelite--and, as you say, there was one on each side of the heat shield. It almost looks like a PO rolled his own; like there's actually 6 total on each carb, albeit thinner than OEM. If I had to guess I'd say s/he built them up on the manifold side in an attempt to keep the fuel lines from cavitation ('vapor lock') when hot.
steveg
Maybe the HS carbs are more prone to vapor lock - hence the BJ7 having more insulators than previous cars. The PO went even better with 6 instead of 4. If this was really necessary, we would have seen it on more cars. Like bigger heatshields on 100s.
BLong63AH
BLong63AH
Member
Thank you both for your responses. Does your car/s have 4 only? I guess I will go back to the original configuration for now unless if I have “vapor lock.” I know this motor was out of a 1980’s full restoration that got caught in a tornado right after the completion. My father bought the car for the motor and he has no idea or does not remember adding insulator blocks.
gonzo
The number of insulator blocks in the photo is correct for early-build BJ 7s; mine's original with 4 thin insulators stacked from the manifold to heatshield and 2 thin ones stacked from heatshield to carbs. All together the look is cobbled up particularly with whatever was used as sealant between the insulators.
These original insulator blocks look to be made asbestos, so be careful. I recently replaced the stacked insulators with phenolic blocks - 2 sets / carb. This combination allows for the HS 6 carburetors to be positioned correctly on their very long carb studs. GONZO
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
chicken HS6 Carbs for BJ7 Austin Healey 3
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Y TR6 SU HS6 question Triumph 1
J TR6 Moss HS6 SU conversion kit question Triumph 4
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
D TR4/4A SU HS6 throttle spindle size Triumph 20
T TR4/4A HS6 problem Triumph 6
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
KVH General Tech HS6 SU Carbs Triumph 1
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
Simmo TR2/3/3A HS6 Carburettors Triumph 4
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
G TR4/4A tr4a hs6 carb Triumph 1
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
Hap Waldrop SU H6 and HS6 carbs Triumph 9
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
T SU HS6 tuning - lifting pin question Triumph 11
Lotuswins HS6's on a BJ8 motor Austin Healey 11
H TR6 TR6 HS6 Needle selection Triumph 0
TR4nut TR4/4A TR4A HS6 Factory writeup? Triumph 9
KVH HS6 SU Carbs Triumph 2
K H6 SU carb dome and HS6 carb dome? Triumph 9
T HS6 idle setting Triumph 3
R SU HS6 Carbs overflow leaking........... MG 20
T NLA SU HS6 part request Triumph 10
T Anyone have a spare HS6 pivot bolt Triumph 13
S HS6 Carburetor Austin Healey 16
T One more SU HS6 question Triumph 25
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
T TR2/3/3A Will HS6 fit in TR3? Triumph 10
H HS6 Fixed needle centering tips Triumph 1
B Measurements of HS6 Carb MG 12
H TR6 TR6 HS6 Conversion Triumph 6
H HS6 JET identification Triumph 2
H TR6 Volvo HS6 Carbs on a TR6 Triumph 9
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
H TR6 HS6 for Tr6 -Pics Needed Triumph 1
