    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Wedge Nice TR8 on ebay
Mickey Richaud
tr8todd
Looks like a really clean low mileage car. His buy it now price is a little on the high side, but he might still get it. There are not too many cars left with such low mileage. I noticed a couple of things that concern me. He has two oil fill caps mounted directly to the valve covers. One of those is suppose to be a breather. When mounted without the riser tube, the rockers can make contact with the oil fill cap. He does have a small breather mounted to the vacuum nipple at the back of the valve cover. This is not sufficient. These motors develop some serious crankcase pressure when run hard. The other thing I noticed is no heater hoses coming off of the back of the manifold. Could be dealing with the dreaded heater control valve leak in behind the dashboard. I still know of a pretty clean Persian Aqua one with a 4.9 pushing 300 plus HP that can be had for less than his buy it now price.
Mickey Richaud
Mickey Richaud
Yeah - I noticed the "dual oil filler cap option" also. You're right about the crankcase pressure. Until I got my breather hoses routed, steam was pouring out of the engine.
Didn't catch the heater hoses missing. Might also be they couldn't figure out how to route them, with the Edelbrock.
tdskip
Other than disconnecting the hose and living with no heat (OK in SoCal 90% of the time) as a work around, how do you fix this?
Mickey Richaud
Mickey Richaud
My control valve was leaking, and the previous owner simply bypassed it - no heat. I have a new valve, and am thinking of installing it on the firewall for easier access. Pulling the dash and console just to get to the valve isn't my idea of fun!
Another option is to install a manual valve like early TR's, and simply opening it when you want the heater to operate.
tr8todd
You can lay on your back and reach up to change it, but you have to be a contortionist. The valve is held in place with rivets that need to be drilled out. The toughest part in the hose clamps. If you cannot get to the screw, you have to cut them off to remove the hoses. In my opinion, I would rather remove the dash to get at it. I have removed a ton of them before, so I know where all of the screws are. I can R&R the dash in a couple of hours. I'm getting too old and fat to be laying up under the dash anyway. Getting at the clutch master bolts is about all I can handle now.
PATR8
TR8TODD, got a question for you, I too have a small breather on mny valve cover nipple, never had any trouble with crank case pressure, please tell me why this is bad and what I should do instead.. thanks
tr8todd
Passenger side valve cover should have a breather at the front. It has a large black hose that leeds to a Y and then into the sides of the carbs. The drivers side should have the oil fill and riser at the front. At the rear, there is a breather nipple. It has a small bore because it is attached to a vacuum port on the drivers side carb. It first travels thru a one way check and the charcoal canister mounted where the TR7 battery tray is. The small nipple requires a vacuum in order to do it's job. The other breather has a larger bore and doesn't require much vaccum at all. The Rover V8 develops alot of crankcase pressure. A simple breather that is not hooked to a vacuum may not be enough if the motor sees sustained high RPMs.
One time I was caravaning with Woody and a couple of other TR8s up to Stowe. We stopped at a rest area just inside Vt. The fella who was with me(he is a police officer) could not find his wallet when we got back to our cars. Everybody took off and left my friend and I to look for the wallet. 15 minutes later, we found it between the seat and the rocker. It was 6 AM on a Sunday morn. The other guys had a 15 minute head start and they drive fast. We had some serious catching up to do. I don't want to say how fast we were traveling, but we caught up to them in less than 20 minutes. Let's just say even the early speedo's don't go that high. Well long story short, when we got to Stowe, my engine had oil all over it because of the breather set up I had. My car happened to be for sale that weekend, and the police officer I was with, wrote me a check for the car the following Monday. His brother still owns that TR8. So, if you ever decide to unleash the car's potential, you better have a breather hooked up to a vacuum port.
Mickey Richaud Wedge Nice TR8 on eBay Triumph 19
Brosky Wedge Nice TR8 for sale, 39K miles, lots of work done Triumph 1
Brosky Wedge Nice Silver FI TR8 Triumph 3
T Wedge Nice TR8 at Cars & Coffee - might be for sale Triumph 0
Radford Wedge IT's a nice car, its just not a TR8 Triumph 5
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
G Really nice to see some people are posting here again! TVR 13
drooartz MGB A nice milestone since the rebuild MG 3
AngliaGT "Nice Miata!" Other Cars 13
Gliderman8 General MG Saw a Nice MG at the park MG 0
jlaird MGB NICE DAY INDEED. MG 2
Rut It’s been nice knowing y’all! Spridgets 13
S TR6 Very nice original one-owner TR6 for sale in South Carolina Triumph 0
Rut Nice visit Spridgets 1
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
maxwedge5281 nice score on ebay! Austin Healey 3
JPSmit Nice to see a car just parked on the road. Other Cars 4
PeterK General TR Nice TR6 on Griot's Garage latest catalog Triumph 3
Rut TR4/4A Nice project for the right person Triumph 0
Jer Seen a nice "survivor" Bug Eye on the weekend Spridgets 5
GTP1960 Nice driver VW Transporter T2. 1970? Other Cars 0
GTP1960 nice old caddie spotted in my town Other Cars 0
D Nice to hear the old girl running again. Austin Healey 2
Michael Oritt Nice 100 fastback coupe Austin Healey 20
GTP1960 Nice El Camino.... Other Cars 9
M nice day Spridgets 3
glemon MGB What is a nice MGB worth MG 5
GTP1960 Nice Rambler outside Rock Hill, SC Other Cars 2
GTP1960 Some nice vintage cars Other Cars 2
F Wanted wtb a 69 Triumph TR6,rustfree,for resto or nice or anything inbetween Triumph Classifieds 0
Boink Nice Bugeye spread in the latest issue... Spridgets 4
turtle Nice Nasty Boy for Sale Austin Healey 10
N Nice night for a drive!! Spridgets 4
nevets Nice NYT piece about a Cobra Austin Healey 0
Jim_Gruber And these Vents on the valve cover connect to? / Nice Heater hose Valve Spridgets 7
T TR2/3/3A I just posted classified for sale ad on nice project 1959 TR3A Triumph 0
M General TR Nice TR parts on CL in LA Triumph 15
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
tomshobby A nice surprise from Eastwood Company Restoration & Tools 2
HealeyRick Nice Bugeye on Bring A Trailer Spridgets 21
PC A really nice TR6 and a ? Spotted 2
HealeyRick Nice Bugeye Spridgets 3
Marvin Gruber MGB Nice ending. MG 5
HealeyRick Nice Nasty Austin Healey 14
Sarastro T-Series Nice Mark II TD on the LA Craigslist MG 1
D Nice looking TVR Vixen S2 For sale TVR 1
RickB Nice 66 Sprite on Seattle Area Craigslist -nfi Spridgets 2
J Went for a nice drive yesterday Austin Healey 0
britlover Nice fall drive in the BN1 last week Austin Healey 7
RickB Nice looking RWA Seattle Craigslist [nfi] $900 Spridgets 2
