New to site. High Oil Pressure
AussieBJ7
Hi all. I'm only new to the site, so be gently with me :joyous:
I have a 1963 AH 3000 Mk11 abnd have just had the carby's re tunned. The old girl was missing a bit and though it may be due to the carby. Took her out on the week end and she was still missing and the oil pressure seemed a bit high, normaly aroung 40 when warm, but the gauge was showing as high as 60. Just wondering if anyone has had a similar issue and what the cause me be?
Love to here back from anyone hou could help.
Cheers
Steve
A
AussieBJ7
Thanks for the reply.
I don't think it is the points.
I have recently done the points, distributor cap, rotor.
My main concern is the oil pressure.
Don't unders stand why the pressure would be going up?
Steve
Healey Nut
Maybe the gauge is out of whack ?
Ignition/Carb issues are not going to alter oil pressure .
Brinkerhoff
Is this a new problem? At an idle you should be able to see oil coming out of the rocker arm when you take the oil cap off.
Brinkerhoff
If its still missing at a steady speed you could be a little too lean . Jet needles wear more at the fat part of the needle so if you've adjusted for a good clean idle , you can be too lean at speed.
A
AussieBJ7
Cheers for you reply.
Though about the gauge. It seems to be ok, as far as I can tell.
When idling it seems ok, just when it gets warm.
When I took her out, last Friday, and noticed the gauge I wasn't going to chance anything so decided to take her home.
On the way back the gauge dropped back down to the correct pressure. If it was the gauge I would've expected it to be more variable.
A
AussieBJ7
Yes, first time it has happened.
I will check the rocker arm when I get home tonight, just gone 12.30pm here. Only a few hours to go.
Healey Nut
Sticking oil pressure relief valve ? when did you last change the oil and filter and is it original or a spin on filter .
A
AussieBJ7
doesn't seem to miss at idle. I have put a new fuel pump on with a flow valve.
I have 'tweeked' the rate but haven't taken her out since.
I'll see how that goes and if that's not it, it could be the needle.
Brinkerhoff
If it is high one time and normal another , yes the relief valve. I've never seen a bad mechanical gage do that. You just want to make sure it pumps oil to the rockers without blockage.
Healey Nut
Full service only a few weeks ago, this has happened since then, the first time out since the service.
what kind of oil filter , original or spin on
Brinkerhoff
If you've changed the fuel pump and have to run a pressure regulator you could have too much fuel pressure still . I think the stock pressure is only 2-3 lb. any more than that will leak past the needle and seat valves and raise your fuel level in the jets causing too rich of an idle. If you are adjusting for this by leaning out the mixture , then yes you will be too lean at speed.
Healey Nut
Change the filter again and I bet your problem will dissapear .
RAC68
Steve,
I’m a little confused. What oil are you using? When are you getting the 60 lbs of pressure and in what stage of the start/run cycle are you getting 40 lbs?
It is not uncommon to get 60 lbs of pressure on initial startup with cold 20W50 oil. Also, since the oil pump will push a high volume of oil, any passage restrictions will increase pressure until about 60 lbs when the relief valve opens. Change the spin-on cartridge with a completely different brand.
For the miss, do you have an electronic ignition or points? Other than the standard stuff, I would check plug wires and plugs. I would also check the pins and seats in the carbs for ware along with their damper oil levels if you are getting you miss on initial acceleration.
Hope this helps,
Ray (64BJ8P1)
bob hughes
Engine missing- You have those HS6 carbs - have you checked the feeds from the float chambers to the jet. I could not go faster than 60mph, stripped the carbs down and found that one of the feeds was blocked by the rubber grommet at the float chamber where there is a stuffing gland. After that performance went up and petrol consumption followed suite :wall:
:cheers:
Bob
busybrit
How old is your car? How old is your oil gauge? I have a "tester gauge" to use when customers have similar concerns. I have replaced two gauges in the last year, and two owners chose to live with their inaccurate gauge.
Saying all that, I was driving a TR3 having a fresh full frame off restoration including a rebuilt engine and the oil pressure was a steady 55 psi when hot. The day was very hot in the mid 90's and without any warning the gauge shot up to 90 psi, stayed there for a 20 seconds or so and then settled out at around 60. In the next 11 years of owning the car it never did this again, so I considered the problem fixed !
I know this doesn't help you, but if your car is missing on 1 cylinder you might, I say might, be getting a little pressure transfer from the piston to an oil port under a not so very well sealing head gasket. This would increase your oil pressure. Oil coming the other way from the oil port to the cylinder could also drown out the spark causing the misfire. Hope I'm wrong!
1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
PAUL161 Site Appearance FORUM Navigation Questions 1
J New site!!! Triumph 9
B Why can't I stay logged in to this site without entering user and password info? FORUM Navigation Questions 8
Rob Glasgow Austin Healey Experience Site Austin Healey 8
M Wanted This entire web site moves like a glacier Austin Healey Classifieds 9
M BN1 "in-site" steering box overhaul ? Austin Healey 4
HealeyRick Derek's Site Cited Austin Healey 6
69MGC General MG Vendor List web site idea MG 0
D TR6 TR6 for sale on the Government Liquidation site Triumph 0
M TR2/3/3A Does anybody use the oils and lubes from the moss motors site? Triumph 3
C New to this site Rover / Land Rover 3
B New to the site and to the sprite. Spridgets 38
PAUL161 Moss Motors Site Down? MG 3
T small site issue - geeks please help Triumph 4
T site instructions please Jaguar 3
G new to this site MG 2
T Status of Rivergate Web-Site? Spridgets 8
N Cold Plug site shutdown! Other British Cars 19
PAUL161 Mickey, Tony's Web Site Question MG 1
Gray_Cat "Best Ride by a Dam Site" British Motorbikes 0
jsfbond paint code site Restoration & Tools 0
histerical site help Spridgets 3
T cool site tracks cars in britain Triumph 0
rikiwho123 does anyone remember this web site? Triumph 3
Gerard New Web Site Spridgets 1
B Triumphest 2011 Web Site Triumph 2
BobbyD Site Up-date for British Invasion Triumph 10
Tabcon New Pic's-New Site...ROLLING! Triumph 15
N I'm the new guy - I guess this is the Healey site Austin Healey 4
jlaird Anyone else haveing site probs? Spridgets 8
BobbyD Custom Leather Panels and Site Up-date Triumph 12
T Helpful cross reference site for parts Triumph 6
angelfj1 Very Nice Web Site for TR Enthusiasts Triumph 1
GeeBee1 Found this site when looking for Wolfrace rims British Motor Corp 0
BobbyD Miata Seat Site Up-date Completed..... Triumph 8
jlaird Saw this site today and could not beleive it-SUs Spridgets 1
davester MGB Unusually comprehensive MGB site. MG 4
jclay Wedge Wedge Technical Site Triumph 5
jlaird Try this site Spridgets 4
angelfj1 the site is crawling today Triumph 4
Geo Hahn TR2/3/3A Interesting TR3 Site Triumph 5
L side curtain web site Triumph 3
Brosky Buckeye Site back up Triumph 0
Cottontop Modified AH Registry Web Site URL Change Austin Healey 0
Lin Web site of my complete BT7 restoration Austin Healey 12
P Mercedes site needed [again]. Other Cars 2
T My car featured on the British V8 site Triumph 30
P Mercedes site needed Other Cars 5
PAUL161 Tech Tips Via the Motorhead web site. Helpfull! MG 0
