New oil pump with 2 screws - old one had FOUR!!?
Bruce_B
So I'm rebuilding my 1275 engine and I'm putting on the new oil pump which is a 'slot' drive vs. the old one which was a 'spider' drive'. The new one matches the new cam.
BUT the old pump was held on by four screws, this one only has places for two screws. I don't think this is a problem - the screws from the old one will fit fine.
Is this a problem? Or just bolt it on with screw screws? Anyone use any sealant back here?
thanks...
I put Aviation Form-A-Gasket on the oil pump gaskets prior to fitting.
Over the years the A-series pumps have changed fastener hole locations and counts. Be glad that your pump's two holes line up and just use them. If the un-used tapped holes in the block bother you, get some short set screws, apply some gasket sealer, and insert them into the open taps. I think the pumps mount with 1/4-28 bolts.
On the Mini I had to add a new tapped hole to mount the pump I bought. It's not that it was a big deal, it was just an unexpected additional step.
Thanks Doug...I'm headed to the garage now to put on the pump.
I've down to Durham.....nice country.
Thanks for that. I grew up in Raleigh too many years ago and as a boy Durham was not the kind of place my parents thought much of. Today it's a much nicer area, particularly in the southwest corner where I live.
T TR2/3/3A fuel pump oil leak Triumph 7
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
D TR2/3/3A Oil pump question Triumph 31
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
JPSmit Question One - oil pump Spridgets 2
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
T TR2/3/3A Oil Pump Grief Triumph 8
D Not another oil pump question. Austin Healey 7
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
B Overdrive Oil Pump Installation Question Austin Healey 10
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
BOBBYR oil pump choice Austin Healey 5
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
JPSmit Oil Pump Question Spridgets 13
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
johnrip Wedge tr7 oil pump leak Triumph 2
B Oil Pump for 100-4 Austin Healey 2
chrpark MOWOG oil pump cover- attachment to back plate? Spridgets 6
richberman Which oil pump? Austin Healey 1
DNK Oil Pump spin up Question Triumph 18
P T-Series Looking for TD Oil Pump Top/Cap MG 0
