Miracle Product
HAN8L1965
As we all know our little cars are covered with so much factory undercoat gunk that it leaves you scratching your head why so many of them have become piles of rust. For those of us in the restoration process removing the gunk is almost an impossible feat. Well I found a wonderful product by accident. I have been hand striping my 65 for the last 2 years with a product called Tal Strip by Mar-Hyde. This is an industrial strength striper and yes it does remove the paint, no sand blasting needed. I had a few parts with tons of gunk that I was ignoring, had tried heat and solvent but what a lot of work.
This evening I applied the Tal Strip, simply unbelievable results. I put it on with a paint brush let it set for a little bit then swirled the area with the brush a little, wiped it clean with a rag and cold water. Most of it was removed with the first effort, and I'm talking about the 1/4" gunk. Give it a try, about $30.00 a gallon at Auto Zone.
Mark
Dichloromethane mostly. Pretty nasty stuff to work with, but probably very effective.
Nasty, yes but boy does it work for what it is suppose to.
Water neutralizes it, it's amazing how a fleck of it finds your skin.
Mark
69sprite ...and then a miracle happened Spridgets 13
T Maybe a Crypty Miracle? Triumph 24
Team_Sprite Miracle workers come through again! Spridgets 3
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
Lin Fuse box - new product in my current project, a 1964 jaguar mark tw Austin Healey 10
JPSmit Product review - vinyl cleaner and tonites question Restoration & Tools 3
Lin Rust Removal Product Comparison Austin Healey 9
K Paint product Barscoat Isolator Restoration & Tools 2
Geo Hahn Equipment & Product for Polishing Paint Triumph 39
JPSmit product review 3M headlight restorer Restoration & Tools 3
Trevor Jessie Thoughts on this product? Spridgets 15
bighealeysource good heat insulation product Austin Healey 1
Editor_Reid New Product Advert Austin Healey 5
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
2 Interesting product Spridgets 3
Trevor Jessie New moss product of interest...at least for me Spridgets 1
AUSMHLY Bristleflex - great product - great vendor Austin Healey 1
boxofparts Another fine MF designed product Triumph 2
S Using an air-drying product Restoration & Tools 1
timbn2 cynical or justified: "great product" scam ??? Austin Healey 15
T Krud - The Must for Rust. Nice product. Triumph 2
M 'New Product'OPINION's DUPLICOLOR's 'SHIELD' Triumph 0
AUSMHLY Trans tunnel heat shield - Found a product Austin Healey 1
AUSMHLY Wheelwell anit-chip paint product Austin Healey 10
Steve Zaino Z-2 Show Car Polish: Product evaluation Restoration & Tools 8
