Minilite Repro's for Sprite
irish
Member
Have a 1961 AH Sprite (Han6L/6608). I bought 4 Minilite repro's and have P175/70 R13's tires on the Minilites however the inside of the wheels (front only) are being cut into (by a millimeter or two) by the edge of the nut on the end of the shock absorber arm as the wheel is rotating. This is putting resistance of course on the wheel rotating freely while scraping the inside paint off the wheel. This only happens when the stearing is turned to the left or to the right. The same thing happened when I had the car jaked up and and noticed some inside wheel scraping as I rotated the wheel so I am not convinced the tires have anything to do with it (I assumed wrongly that the problem would correct itself when the car was lower back to ground).
I know the Minilite Repro has a good reputation and I am pretty sure it is not the wheel. Could the problem be the shock absorber? Anybody else had this experience? Puzzled... /ubbthreads/images/graemlins/pukeface.gif
On most cars it is the nut of the tie rod end that rubs. The solution involves just a bit o grinding.
Yes, a wheel spacer may provide enough clearance, but with 175's I think you might get rubbing on the fender lip on corners that induce roll.
Bugeye58
Trevor, your car rolls in the corners?
I ran 185's on a '65, and rubbing was never an issue uness it was a severe high speed cornering incident. I don't think there would be a problem with only a 1/4" spacer. Especially on the front.
Jeff
Never rubs with casual driving, but when diving into a corner (just before the back breaks loose) I have slight rubbing. This is with 165/70's and a stock ARB. I think I may need to replace some tired springs. What ratio 165's were you running? If they were smaller diameter, you might have gained some clearance there that I do not have.
PS in this part of KY, backroads have many 90 degree corners around the corners of fence rows.
Bugeye58
Trevor, I was running 185-70's, not 165's. That was also with four new springs, urethane bushings, and tube shocks on all corners.
This car is in Northern California, and believe me it sees plenty of hard use on twisty mountain roads. I haven't gotten around to installing the Panhard bar yet, but that's next.
Jeff
Do the tube shocks allow for the same travel as the levers? Do you have additional camber (this tucks the top of the wheel a little more). Overall, I think my issue is weak springs and a floppy ARB.
Bugeye58
Trevor, the tube shocks allow for plenty of travel, and are adjustable. I have them set at the medium setting, which is stiff, but not uncomfortable.
I'm running about 1 1/2 degrees negative camber in the front, as I'm willing to sacrifice a bit of tire longevity for handling.
I'm also running a 3/4" front ARB, mounted in urethane bushings, and no bar on the rear. New front lower control arms, as well.
The car has a heavily warmed over big crank 1098 in it, putting out 92 HP, and pulls like a freight train all the way to 7200 RPM.
Jeff
T TR2/3/3A minilite wheels Triumph 5
F For Sale: Minilite Style Knockoff Wheels, 15" x 5.5" Austin Healey Classifieds 2
B Refinishing Minilite Magnesium wheels Restoration & Tools 0
maxwedge5281 Minilite Wheels Austin Healey 3
I For Sale Minilite replicas with Michelin tires $400 Triumph Classifieds 16
Scotsman TR4/4A Spinners for bolt on minilite wheels Triumph 0
S GB "Minilite" wheel info British Motor Corp 0
Jim_Gruber Experience with Minilight not Minilite Wheels Spridgets 2
Scotsman TR4/4A Minilite Wheels Triumph 9
maxwedge5281 minilite bolton wheels Austin Healey 20
vette Minilite Wheels Austin Healey 8
Z Minilite Wheels - England Austin Healey 4
P Opinion Wire Wheels Vs. Minilite Style Knock Offs Austin Healey 21
R 5mm wheel spacers on front when switching Minilite Triumph 2
R from wire wheels to minilite style Triumph 14
Dudly Minilite Wheels Triumph 48
Tabcon "Rota" Wheels-Panasport/Minilite lookalikes? Triumph 1
T picking minilite style wheels-things to consider Triumph 11
TexasSprite What tire and size for Minilite wheels? Spridgets 1
vping Minilite/Panasport Wheels MG 15
J Minilite or minilite style wheels Austin Healey 8
R Best price for Minilite Knock-offs? MG 8
S Other types of Minilite look alike wheels? Triumph 6
S Minilite Wheel and Tire Size Spridgets 3
crya Current go-to source for VIN/Chassis Repro Plates? Austin Healey 8
M Anyone Have Experience with Moto Build Ashley or Speedwell Repro Hardtops? Spridgets 2
T TR2/3/3A Experience with repro cylinderhead Triumph 5
rkep01 Brand new repro Sebring Sprite photos Spridgets 5
W re chrome parts from ebay / lucas repro headlamps Austin Healey 15
Parker TR2/3/3A TR3A Lamp lenses: NOS / "Lucas" repro differences? Triumph 9
T TR2/3/3A TR3 parts original and Repro quality Triumph 13
AUSMHLY Repro trafficators are sealed? Austin Healey 3
Editor_Reid Repro BOX for Healey Boat Model Austin Healey 3
jdubois Spitfire Rebuilt vs repro Spit starter? Triumph 17
toysrrus "356A Speedster" Repro: Who has one in NE PA Area Other Cars 9
toysrrus 356A Speedster Repro: Who has one in NE PA? Triumph 2
G Vendor for repro decals Triumph 1
D Repro S1 radiator cowl quality? Jaguar 1
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
