mcguijo
Wasn't sure where to post this question, but figured I'd start with this forum. Time to prepare the fenders and bonnet of my TR3 for painting. I've decided to go the media blasting route (mainly because alot of rust has found its way into numerous nooks and corners on the panels). To cut the cost of media blasting, I'm going to do some prep work on the metal. I'm not above using aircraft stripper to remove paint and thus cut the time needed by someone else to blast. I've used the stuff before and realize it is very messy and probably cut a few years off my life. My concern is that I won't be able to remove the residual stripper from the forementioned nooks and corners. Do you all think that the media blasting following the paint stripping can remove all residual goo from the nooks and corners?
