I'm getting closer to being ready for the final mounting of my DCOE Webers on my TR4A. One thing I still need to solve is what to do about the manifold clamps. The flange on the intake manifold is about 1/8" thicker than the exhaust header. I've come up with a few ideas, but was wondering if anyone had better ones:
-Grind out half of each clamp by 1/8"
-Grind down the intake where the clamps press. But I don't have any way to do this and still look nice, and the top ones are quite visible.
-Have the entire intake mounting surface ground down by 1/8". Not sure if this can be done while maintaining alignment, but this would probably be the best looking solution. I also don't know if removal of 1/8" of the flange would weaken the intake enough to be an issue (could be a problem with the solution above).
-Build up something on one have of the clamps. I don't have any way to weld, though I could perhaps drill and tape a hole to insert a screw/bolt, and use the head as the additional space.
Any other ideas, or comments on the ones I have?
Thanks,
Darrell
Thanks,
Darrell
