Mail lady just came.
jlaird
My latest Moss order arrived. Page A 16, top of page, decal & plate kit.
What the heck does the item with the red caution go??
In addition I got an item not shown White on Black, says Smiths and a couple of arrows with + and - and the word Rotation.
What is it?
Oh yea, now have a new heater plate.
bug_sixty
Did you call Moss yet? Years ago at the 25th AH in Snowmass CO there was a guy from CA that brought the best example of a factory fresh 58 Sprite I had (have) ever seen.(took best in class)Anyway, one item (haven't seen since)was a bracket wired or attached to the upper radiator hose that said something about a "hot"warning don't touch...wonder about your tag
jlaird
jlaird
Actually it says: " <span style="color: #FF0000">CAUTION</span> IT IS IMPOSSIBLE TO DRAIN HEATER UNIT WHEN DRAINING REMAINDER OF COOLING SYSTEM-UNDER FREEZING CONDITIONS BLUECOL ANTI - FREEZE MUST BE USED.
This tag has a hole at each end, like for a rivet or a wire?
bug_sixty
Well it's been a loong time.. maybe the tag was rapped around the heater hose. Anyway the reason it hasn't been seen is the first time the hose was replaced the tag went with it.. Maybe the Heritage Group knows.. I'll check my copy of the factory part list from 60's.
Platinum
The black/white "rotation" sticker is for the heater blower motor.
Can't recall where it went, above or below the "SMITHS" logo but the CAUTION tag was riveted to the heater box someplace. Looong time since I've seen an "original" bugeye heater box!
bug_sixty
My heater box still has the original metal plate attached but painted over... Let me know the OD of decal and I'll compare
jlaird
jlaird
oh, I am good with heater tag, is metal. Holes are already drilled in my heater cover for the tag rivets. Can you look at your tag. Any one know what the numbers stamped into the tag should be??
Banjo slugs in the mail Triumph 2
davester Any parts sources [SF area] that are NOT by mail? MG 3
jlaird In the mail today Spridgets 5
PatGalvin Look what came in the mail today Triumph 21
TR6oldtimer Look what came in the mail Triumph 22
T E mail address Triumph 1
T E-mail request Triumph 2
jlaird Todays mail Spridgets 1
jlaird My POR catalog came in the mail today. Spridgets 7
I Surface Mail Service Triumph 1
angelfj1 General TR last run with the lady Triumph 19
DrEntropy Gray Lady Down!! Other Cars 5
Lynn Kirkpatrick PBS Series-Lady races a Mini British Motor Corp 3
CJD Lady Gets Her Badge Triumph 18
angelfj1 Project Up-date - The Grey Lady's body is painted Triumph 17
jaybird MGB GRRRRRRR! Some 'lady' just hit me in the MGB MG 46
H Little old lady Latest MG 8
H MGB Little old lady's MGB Limited value MG 25
M Silver Lady V8 MG 18
DrEntropy Came across these "tools" Lotus 2
AngliaGT Came Across This Frogeye article Spridgets 2
KVH General Tech Angle Drive Came Apart Triumph 10
PAUL161 T-Series Where My TF Came From MG 1
John Turney Came Across a New Book Austin Healey 2
Lin Post in float bowl came loose Austin Healey 6
Jim_Gruber A beautiful piece of jewelry for Bugsy/ Christmas came early Spridgets 12
Jim_Gruber New Wheels They Came, They Came!!!! Spridgets 14
Keith_M Look what came home Spridgets 14
Keoke This just came in Austin Healey 3
M Tie rod end came apart easy - too easy? Spridgets 6
J Got my Heritage certificate but nothing new came on the sheet British Motor Corp 2
5 It came with oil Spridgets 1
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
TR4A_IRS The sun came out! Triumph 11
BugeyeNJ58 Radius arm came out...how to put new one in? Spridgets 6
Johnny Door handle on BN7 came loose. Austin Healey 8
Gliderman8 Mr. Lucas came to town today.... Triumph 7
TR6oldtimer TR6 Look at what came for the TR6 this afternoon... Triumph 12
V An LBC came to visit today Triumph 1
abarth69 My new old shed came today Spridgets 18
HerronScott BMIHT certificate came today! Triumph 19
JPSmit Look what came today Spridgets 12
Got_All_4 Hear's what I came up with- light/badge bar Triumph 16
JPSmit Appraisal came in Spridgets 10
drooartz Jet-Hot headers came today! Spridgets 5
M Fuel Line Came Loose; Yikes! Spridgets 4
T My B came home.... MG 11
RickB Lookie what came today from Ray McCaleb!!! Spridgets 12
jlaird Came into a few extra dollars Spridgets 5
N MGB What came out as I pulled the heater core for MGB MG 7
