    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Machine shop in NorthernCal needed
JKB1957
I am looking for a little help. I am in the process of restoring a Spitfire MK2 and I am looking for a machince shop in Northern California that is familiar with working on these engines. I am looking to put together an 1147cc fast street engine (maybe those two phrases shouldn't go together). Anyway I figured I would ask if anybody knew of a shop in my area that actually knows about these engines. In particular how to correctly port the head. Any help/ideas would be appreciated.
I am currently working with Del's Machine Shop in Sacramento. They aren't race specialists but have been really helpful and easy to work with and patient with my unending questions. Very reasonable too, IMO. For my TR3A, they are turning crank, resizing big end of rods, fitting rod bushings, installing new cyl liners, installing new flywheel starter gear and surfacing flywheel and fitting TR6 pressure plate, surfacing head, valve job with new valves, hardened seats, new guides, springs, restore rocker assembly (send it out), install cam bearings, balance rotating assembly, shot peen rods, head, and block and magnaflux all, fit modern oil seal on crank (remove scroll). I think that's it. For about $1,400 - I supplied nearly all parts except valve seats. They are checking all important dimensions.
They offered to send out head if I was insistent on porting and flow work but they discouraged me. They said that was the least bang for your buck when it came to performance upgrades and I was feeling the pinch of this $3,000 engine rebuild so took their advice.
For head work, why not ship it back to Hap at ACME Speed Shop? Spit head is pretty small, right? I bet he can set up your head as wild as you could possibly want.
Pat
That ain't that northern. I figured you meant Eureka, by Doug.
Somebody should chime in now that the location is centralized
I agree with Pat about shipping the head out. I have a great machine shop here in Modesto. He even had 7 replacement TR3 cams on the shelf. Good service and they were able to bring back this BCF anchor or restore
Rettig Brothers Inc
2612 Woodland Avenue
Modesto, CA 95358
(209) 529-8016
But if you are loking for a little race in the Spitfire I would send it to a specialist. Plus, you will not have to pay CA sales Tax
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
R Machine Shop St. Louis or Nashville Austin Healey 1
T TR2/3/3A Machine Shop Recommendations Needed Los Angeles/San Diego Area Triumph 0
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
M Machine Shop in Pacific Northwest Spridgets 7
S T-Series Auto machine shop TD engine MG 20
K SU Newppindles and bushes done by a machine shop? Triumph 1
rikiwho123 a good machine shop in N.J.? Triumph 1
TR6oldtimer Need a machine shop in N. Calif to bore for cam Triumph 5
JodyFKerr Machine shop recommendations [Phoenix, AZ ] ? Restoration & Tools 3
ronzet Got a call from the Machine Shop MG 14
Geo Hahn My Machine Shop is Closed Triumph 9
davidk Need a machine shop near Northeast Texas Triumph 7
eejay56 Bad news from the machine shop Triumph 12
2wrench Picking up engine from machine shop tommorrow Triumph 4
Brosky Block to machine shop yesterday Triumph 8
G TR6 Does anyone have a machine shop and a TR6? Triumph 15
Bruce_B 1275 Engine Returned from Machine Shop Spridgets 12
L Machine Shop in Santa Barbara, CA area? Austin Healey 0
ChrisS DE machine shop / engine builder Racing 2
D Machine Shop Needed British Motor Corp 6
max71 Looking for a top machine shop in the L.A. area MG 1
Morris Hello machine shop! Spridgets 1
Morris Before I go to the machine shop Spridgets 2
Alan_Myers Need machine shop recommendations - SF Bay area Triumph 0
jlaird Stoped by the machine shop Spridgets 11
G Got screwed by a local machine shop Triumph 14
Paul Slice good machine shop around Nashville TN Triumph 0
G Recomendations for Machine shop In Boston area Other British Cars 1
G Looking for good machine shop in Boston area Triumph 0
L Machine shop Santa visit!!! MG 2
S Machine Shop Recommendation Austin Healey 5
T Machine shop in Atlanta? Jaguar 0
I Machine Shop In Albuquerque MG 2
C Machine shops Pittsburgh Pa area inquiry Other British Cars 1
P Fuel Float to tank bolts [machine screw] size?????? Spridgets 1
eschneider machine gun brake pedal Other Cars 3
M Is it a Triumph or a Singer [sewing machine]? Triumph 14
P Fuel pump sounds like a machine gun MG 6
M Portlan Oregon Machine Shops Austin Healey 4
Stewart Machine gunning on acceleration, loss of spark MG 8
jvandyke ghost in the machine/ gearbox and horn? Spridgets 6
healeynut Pozidrive machine screw source? UNF Austin Healey 3
healeynut Monster Machine Other British Cars 6
Brosky Cylinder head machine, valve job & CC Triumph 10
PeterK Machine shops Triumph 12
John_Mc Mystery Machine pics Triumph 0
DrEntropy Jumped into the Wayback Machine... Lotus 5
T distributor machine Restoration & Tools 3
Bret BMW - the Ultimate Driving Machine! Other Cars 11
