Jarhead
As I start the restoration of my '77 B, a lot of ideas cross the mind. The idea of lowering the car just one inch seems like a must do. It appears to be a "bolt on change" and be no harder than putting the old back on. Maybe even easier with the new parts. Are there any negative impacts? Appears wheel clearance is not a problem. Wheel travel can be controlled with the right dampers and shocks can be stiffened with a new valve. Could this impact camber? Not sure!
I have also contemplated installing the offset wheels to give it a wider stance (just an inch ). I also keep flopping back and forth about going original or modified. I suppose the value is better as an original but, I keep coming back to the fact "I'm building it for me", so do whatever makes it a better ride. If it was an older B then original.
