Looking for two part, three point seat belts
twas_brillig
The tonneau on our BJ7 has slots that appear to be for the chest strap on a three point seat belt to pass through. However - unless you want to unbolt the belt from its upper mount and reinstall every time you but the tonneau off/on - it appears to need some sort of belt combination that would entail a separate lap belt combined with a separate 'chest strap' that would connect, separately, either directly to the lap belt at the tunnel end, or some sort of dual belt connection to the tunnel mount. Can anyone advise as to a source of such a belt that would work with/without the tonneau? And if anyone can phrase my question more clearly, kindly do so! Thanks, Doug
The flap is designed to be used with a belt that is anchored on the outboard side by a removable pin that fits into a bracket next to the seat. You can see it here and is available through British Sports Car Specialists
Hi Doug,
Back when the BJ7/8 was new, 2-point seat belts were just being mandated and 3-point belts were the new think thought to provide greater safety. As time and tests/reality proved, without head rests, 3-point belts held just as many risks as 2-point belts but in the opposite direction. So, the choice is yours.
Keep safe,
Ray(64BJ8P1)
I called British Sports Car Specialists this morning and their comment was that the seat belt pin feature was somewhat awkward to use, so I figure I'll have a look at the tonneau and get it modified with either a zipper or velcro to provide access to the belt-slot.
And today is Day 1 for their new web-page, so that may be why I struggled earlier. Doug
Twas
When I bought my tonneau a few years ago now from AH Spares, it came with all the fixings - lift a dot, Tennax and press studs, I assumed from the number that press studs were the order of the day for keeping the flaps closed but I have never fitted them. Well not yet anyway.
:cheers:
Doug-
Totally unoriginal to british cars, but Klippan made belts like you requested which were sold in Mercedes Benzs in the early 1970s. They are typically inexpensive, but for whatever reason, they are a bit spendy on ebay right now.
https://www.ebay.com/itm/Mercedes-R...ver-Assembly-Klippan-SET-107616/123060606014?
The waist belt has the retractor and the shoulder belt just latches on and has to be manually tightened. The buckles stay together with a friction fit, so they function on a day to day basis just like a three point belt. But with a quick slide of one buckle relative to the other, you can easily separate them.
Depending on which MB model they come from, the receiver has a different length of cable/fastener. Again, because they have nothing to do with british cars, it probably isn't something anyone would consider. But just in case you weren't familiar, I thought I would mention them.
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
vping T-Series Looking for TD Part # MG 3
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
DanZ_BT7 Looking for a part Austin Healey 2
B Looking for rear marker light for 73 midget...just need the socket part or whole,also Spridgets 0
bugedd Working on brakes, looking for a part Spridgets 2
F Looking for an oddball ruber part ... Austin Healey 7
M LOOKING FOR TRUNK STRIKER, moss part 806-460 Austin Healey 4
JPSmit So close and... looking for a part Spridgets 1
6 Looking for a lost part. Spridgets 5
M Looking for a part........ Spridgets 5
DNK Looking for a Part Triumph 3
Team_Sprite Looking for a part and an answer to a "how to" Spridgets 13
G Looking for a part for a 6 Triumph 2
C Looking for a Specific part Spridgets 2
T TR5/TR250 Help...Looking for rare TR250 part Triumph 8
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
