Looking for tranny & rear end help
GilsTR
Trying to help a friend on his project...and he thinks for his TR3A he is wanting to marry up a TR4 tranny with a TR6 rear end that has 4:11 gears. Are 4:11 TR6 rear ends around?
What if any will be the challenges marrying these up? What he tells me is he has a TR3 engine that has been bored out and this is what he wants the power train to be. Any feed back appreciated. Gil NoCal
He is going to put IRS under his TR3A ?? Lotta work there, starting with some major frame fabrication. Be easier IMO to put a TR3A body onto a TR4A frame (ala TR3 beta).
I don't know how many TR6 came from the factory that way, but 4.10 gears are not hard to find. Try BFE or TSi. Carsten Conrad (in Germany) used to sell them as well, not sure if he is still in the business. Same (early) gear set will fit either solid axle or IRS diff.
However, my TR3 came to me with 4.10 gears, and I have to say they are way too short, especially without overdrive. I have to be careful not to spin the rear wheels, and even at 6000 rpm, the rpm is limiting top speed.
Steve Hedke did a careful study with 'Scrappy' (the TR3 he ran in The Great Race https://www.fot-racing.com/tr3/caption/TR3Hedke.htm) and found that he actually got better acceleration with 3.45 gears!
TR4 tranny is no problem. Just elongate the holes in the rear crossmember, to move the rear mount back by about 3/8". If the body is pre-TS50k, he'll need to rework the trans tunnel a bit to fit over the starter bulge. Personally I prefer the TR3 shift lever but the TR4 lever will work.
PS, TRF has 4.10 gear sets on sale for $500 at the moment, PN 505014
For whatever it's worth, I think the "guts" of the TR6 differentials, regardless of gear ratio, are pretty much the same as those of the earlier axles, at least as far back as TR4/4A solid axles and possibly to the later 3/3A "Girling" axle. I know a friend of mine bought a TR4 axle from me years ago for use of the diff. in a TR6 housing.
Randall, does that sound about right to you?
Yes, except that I'm not certain what is involved in installing a late TR6 gear set (designed for the collapsible spacer) into an earlier differential (designed for a fixed spacer). The part number changed, so there must be some difference in the gear set. But possibly all you have to do is use the collapsible spacer.
PS, never mind. The late TR6 housing stayed the same part number, so all you have to do is use the collapsible spacer to fit a late gear set.
The gear set will even fit into the TR2-early TR3 "Mayflower" axle. For very early TR2s, it may be necessary to ream out the holes in the carrier (a factory-approved modification).
Gundy Looking for a Datsun 210 tranny Spridgets 16
sim Looking for a good usable rib tranny for 58 948 Spridgets 6
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
