Looking for four original sprite rims
59diamond
I am looking for 4 1958 to 1960 original steel rims for my 59 bugeye. There was one thing wrong with the rims I have now. Now there are two things wrong.
First my present rims do not match. The front ones have 8 holes and the back ones have 12 holes. I thought I would pretty them up by putting Trim Rings on them which are sold by Victoria British for $50 bucks and $95 bucks by Moss.The ads on both Victoria British and Moss say fits 13 inch wheels, but nowhere does it say for rostile wheels only. Only in the new Moss printed cataloge does it say Rostile. I bought a set from Victoria British and in trying to put them on my rims I scratched all four rims so I had to get some silver paint and retouch them. What I would like to get are four steel rims that match that I can have sand blasted or what ever it takes to make them look original. I would keep driving with my present rims and then switch to the new ones when they are in good shape. So if anybody has some left over after switching to more modern rims I would be interested in buying them from you.
It's my understanding that there were 2 different wheels and that one or the other had problem's with cracking. Don't remember which but believe it had to do with the large hole's [2 of them] lining up with the hole's around the outside.
May want to check that out or, better yet, someone on this forum probably has more knowledge about it.
Kurt.
I have four that I am no longer using. They are the ones in the photo below. Make me an offer.
Dan
How about a hundred bucks plus shipping. I live in Southern California.
Sure - that's a fair price. But would you prefer me to take some close up photos first?
Dan
If they look like the two in the picture I won't neeed any more photos. By the way what did you do with the hub caps? I might be interested in them also.
lei me know how we can do this deal and thanks for responding to my appeal.
I have the huncaps and lug nuts too if you need them. Any reasonable offer is fine.
I have the four cardboard boxes that the mags I bought came in and could ship them in those boxes, but they're not terribly strong. I'll try to figure out shipping costs tomorrow and let you know. I'll send you my cell phone number in a private message.
Dan
BTW: There were three types of BE wheels: First type uses rivets to hold the face of the wheel to the rim (not too strong and can leak air). Second type had the "cooling holes" aligned with holes for the brake adjust (cracks can develop between the brake adjust holes and the "cooling hole". Third type had the cooling holes offset from the brake adjust holes, reducing the chance of the cracking noted above. Cheers,
Scott
I am getting 4 matched rims and hub caps from Dan Lewis today. My plan is to spruce up the rims if need be and put white wall tires on my BE. I have ordered a set of Firestone 2 inch wide whitewalls from Motors Spot in Fallbrook, CA which carry Kroger tires. I will use the best 4 of the 8 hub caps that I will have. I will have them mounted and balanced by a place in Fallbrook that does a lot of work for Motors Spot. I will then bring them home and put them on my BE. i have seen very few BE"S with white walls and thought it would make my BE standout a little more. It is also cheaper than some of the other wheel alternatives I have researched such as wire wheels.
I will have my black walls for sale after the switchover and a few extra hub caps to dispose of. The black walls are steel belted radials, wide track 165 R13 82 W M/S. These tires were fairly new when I bought the BE and have lots of tread left on them. I put about three thousand miles on them since I have had the BE. The new whitewalls are 520-13.
Not mentioned here is the issue of bent rims. All of the above is good but if the rim has had a hard blow to the side no matter which variety they are cooked... I went through a pile of rims years ago before finding 5 true blues......
5 Wanted Looking for a Rear Cockpit Molding for a BN2 Austin Healey Classifieds 0
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
