TR2/3/3A Lockheed diff setup
raskas
Member
Hey Guys
Im at the point where i need to bite the bullet and decide whether or not to rebuild this diff. I have used white lithium grease to get an idea of where the pinion is contacting the C/W and the result is as pictured below. From what ive read its a little to high on the face of the C/W so the pinion needs to be closer to the C/W. Im a bit concerned at the pattern on the pinion but cannot find any info as to what it should look like. So im asking rebuild or leave it alone ?
Cam
Agree with David on the blue. The pattern might give you some indication of the condition but there are many reasons for a bad pattern. If the differential has been quiet, I'd ignore a little unusual pattern. Your ears are a better judge.
If you do have issues, here's a good reference, just don't let Andy talk you out of it:
https://www.macysgarage.com/myweb6/diff-overhaul.htm
Tom
Thanks for the reply Tom
Noise wise i cannot be sure as this car has been off the road for 34 years, i will get some blue and try again. It feels good and the backlash measures consistently at .006" so is in spec. nil signs of wear in the crown wheel or pinion.
Cam
With the blue you need to use as little as possible to get a good result. A Q tip is probable a good way of applying the blue to one gear.
David
K TR2/3/3A Lockheed Diff...why is it considered 'weak"... Triumph 3
mgedit TR2/3/3A Lockheed Diff Oil Seal Replacement Triumph 10
S TR2/3/3A Lockheed brake system Triumph 7
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
CJD TR2/3/3A Lockheed Axle Triumph 8
CJD TR2/3/3A Lockheed Dif seals Triumph 5
T TR2/3/3A 1956 TR3 with Lockheed Drums to Disc Questions Triumph 11
R TR2/3/3A Lockheed axle questions Triumph 8
N Lockheed brake assembly grease??? Spridgets 2
M Orientation of Lockheed brake servo Austin Healey 2
mgedit TR2/3/3A Master Cylinder 56 TR3 [Lockheed] Triumph 14
D Lockheed Booster Austin Healey 4
2 TR2/3/3A TR2 Lockheed Hubs - Disc Wheel Triumph 3
2 TR2/3/3A Lockheed Master Cylinder Triumph 1
mgedit TR2/3/3A Bleeding Lockheed Master Triumph 7
A TR2/3/3A Possible problems replacing a Lockheed rear axle with a girling unit Triumph 6
mgedit TR2/3/3A Lockheed Master Cylinder 56 TR3 Triumph 2
C TR2/3/3A TR2 Lockheed brakes Triumph 13
mgedit TR2/3/3A Replacing Lockheed Axle Seals 56 TR3 Triumph 25
CJD TR2/3/3A Lockheed Axle Triumph 32
CJD TR2/3/3A Early Lockheed Master Cylinders Triumph 24
2 TR2/3/3A TR2 Lockheed axle? Triumph 9
mgedit TR2/3/3A 56 TR3 Lockheed MC Reassembly Triumph 8
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
E 1275 Brake MC Lockheed vs Lucas Spridgets 0
N Lockheed servo photo Austin Healey 2
N Brake Servo Lockheed Austin Healey 0
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
S Lockheed Vacuum Brake Booster Austin Healey 10
C Wanted Spitfire 1500 diff rebuild Triumph Classifieds 0
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
Darwin GT6 Diff Help Please Triumph 2
skystryd Trans and Diff Spridgets 7
M TR4/4A Diff comparisons Triumph 2
N TR6 Triumph Diff which model??? Triumph 1
pbraun Wanted 3.9 diff for sprite Spridgets Classified 5
steve00136 MGB Diff refurbish MG 6
Tr3aguy TR2/3/3A Been a while Diff question? Triumph 4
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
M TR4/4A Diff Conversion Triumph 3
T Diff Ratio BJ7 Austin Healey 5
Zitch TR4/4A Diff Fluid - GL4 Triumph 7
Sarastro General TR How is the axle tube attached to the diff housing? Triumph 16
K TR2/3/3A 3.45 Diff ratio? Triumph 7
B best diff British Motor Corp 5
wangdango '67 XKE rear diff? Jaguar 2
Jim_Gruber Bugsy IV decided to leaked out almost a quart of diff fluid Spridgets 6
B diff ratio British Motor Corp 3
B TR6 Should the poly diff mounts be snug to the studs? Triumph 2
