TR6 Limit Mechanical Advance on TR6 distributor?
Rocky_LC
I am running triple Webers on my 1971 TR6 engine, with approximately 9.5 : 1 compression. Pertronics module on a Lucas distributor.
The Webers like LOTS of timing at low RPMs, and I’d like to limit the timing from the 13* available so I keep the “all in” timing to about 34-34*
My preferred method would be something easily reversible, like on Ford distributors, where you can just put heat shrink tubing over the limit stop tabs.
Would like the thumbwheel adjuster to continue to work!
Pictures would also help me visualize the mod…
Thanks -
Rocky
Sarastro
There are probably simple ways to do this, but are you sure that's what you want? Setting the initial timing as high as you have will shift the whole timing curve upward, which may not be what you want. One possibility is to get the programmable 123Ignition distributor, and then you can create any timing curve you can imagine.
R
Rocky_LC
Yes, I saw that option, but they looked like they were about $600.
Trying to come up with an economical, old-school solution.
I did think the 123 solution is a good one with the ability to use both RPM and vacuum to affect the timing…
Thanks -
Rocky
CJD
I would likely first use a dial timing light to set the high RPM advance to the 34 degrees you want. Then see if the car behaves well at idle and low end. I would not include the vacuum when setting the high speed timing...then use it or not. For all out performance, the vacuum advance just gets in the way, and often results in a quick rattle on rapid acceleration. On a street car it will help with fuel economy at cruise.
If you do not get a good low end with this, then I would look at weaker springs to bring the timing in quicker. If neither of those work, then I would move on to restricting the range of advance like you are planning. Do the cheap and easy first to get some reference...
R
Rocky_LC
That seems like a good tuning strategy…. Makes a lot of sense.
Might have to upgrade my timing light!
I don’t have vacuum advance…. No ported vacuum on the Webers.
Thanks!
Rocky
TR4nut
A friend of mine has a similar setup to yours with Webers. He did something like the Ford truck you mention, I believe he used aluminum tubing and fit it over the stop. Sorry don’t have details or pics but enlarging the stop can work
CJD
With a little trig you can draw the proper chalk mark on your front pulley for the 34 degrees you are looking for. On a TR2/3 it comes to about 1/8" per degree...not sure what your diameter is on the TR6? I hate to buy tools when there is a work around, unless they are on sale, LOL! You could also use a degree wheel to find the proper location for a mark, if you have one of those to hold up to the front pulley.
R
Rocky_LC
Yep, I can also find the 34* by scaling the marks on the balancer…. I know I have TDC, 10* and 20* (and maybe 30*) etched on the balancer…
I haven’t taken the distributor out yet. I have seen the vacuum advance and thumbwheel adjustment on the plate that holds the points, but haven’t gotten any deeper into the distributor than that.
Thanks!
R
Rocky_LC
Here’s how I did it…. Made a spacer, 3/16” ID, .320” OD.
This limits my mechanical advance to about half of the stock capability of 13*, which is what I’m looking for.
Rocky
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
SNClocks Bugeye axle limit straps Spridgets 5
J 1275 Rev limit Spridgets 5
S TR2/3/3A Mechanical buddies. Triumph 2
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
A BN1 Mechanical Brake Switch Austin Healey 23
B TR4/4A Mechanical fuel pump vs electric Triumph 16
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
K TR4/4A Mechanical fuel pump glass bowl level? Triumph 1
M Mechanical fuel pump Spridgets 33
M BE Mechanical Fuel Pump - Almost Certain Leak Spridgets 3
D TR2/3/3A Mechanical Fuel pump Triumph 3
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
max71 MGB Here's what the inside of a MGB mechanical gauge looks like MG 0
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
tmcarthur Mechanical Fuel Pump Spridgets 9
J Mechanical tachometer to electric Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
F Spitfire Spitfire 1500 Mechanical Fuel Pump & Spacer Triumph 6
P Bugeye Wiper Mechanical Parts needed Spridgets 1
DanLewis Distance between mechanical fan and radiator core Spridgets 17
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Bypassing the mechanical fuel pump Triumph 8
regularman What was wrong with the 1500 mechanical fuel pump? Spridgets 20
Got_All_4 TR6 Moss TR6 mechanical fuel pump TR6 Triumph 25
T Mechanical tach options? Spridgets 17
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
S Mechanical Tach Repair and calibration Austin Healey 5
T More on mechanical fuel pumps Triumph 32
glemon stupid human tricks mechanical advance Triumph 25
bigjones The 1500 mechanical fuel pump Spridgets 21
S Mechanical Tach Problem Debugging Austin Healey 2
pjsmetana Electric Fuel Pump or carry a spare Mechanical? Triumph 15
pjsmetana Mechanical Sunpro Oil/Water Temp Gauge Triumph 5
RedTR3 TR2/3/3A TR3 Fuel Pump: Mechanical vs. Electric Triumph 14
TR6oldtimer TR6 TR6 Distributor mechanical advance question Triumph 4
veale001 Mechanical or Electric Fuel pump? Triumph 15
prb51 TR2/3/3A TR3 Op temp issue and mechanical gauge Triumph 7
philman Mechanical Oil Pressure Gauge Question???? Restoration & Tools 2
emann BE Mechanical Fuel Pump Installation Spridgets 0
E Body Blasting and Mechanical Work Triumph 9
7 springs for a lucas mechanical advance Triumph 1
Atrus Dizzy – Mechanical Advance Weights Spridgets 19
W Mechanical Fuel Pump Rebuild Spridgets 1
S Electric Fuel Pump vs. Mechanical Pump Triumph 18
Michael Oritt Guages--mechanical versus electrical Racing 31
drooartz Mechanical fuel pump with later 1275 Spridgets 2
V Website about most any auto mechanical question Triumph 1
