MGB Less Welly Grommet!
Sopwith_Camel
well spring is here...really it is, snow Saturday morning but I'm moving forward.
the MGB is running well I rebuit the h4 carbs in the fall. my issue is when i give it alot of "welly" it bogs.
i did replace the temperature sensor in the carbs last fall and stupidly fiddled with the adjustment screws, so should I put them all the way up or all the way down?
I have the carbs well balanced for once in my MG existence. and just solved a stuck float on the jag but that is anoughter story.
thanks
steve
P.S. its amazing how many britsh parts you can order while gettting Chemo.
I can't offer any clues on the H4 carbs, but hope the chemo is going OK.....not fun I'm sure.
thanks, keeping focused on the car projects helps. looks like the move to Norway was worth it for the free health care.
my buddy Greg gets paid to drive me in the MGB to the hosptal plus the cost of gas.
im hoping to have the energy to rewire the B this summer and swap the steering to Left hand drive. I have the time but every thing wears me out. and i have to get the jag running, i think its just the starter moter.
Good luck with the chemo -- hard stuff for sure.
yeah half way through treatment number 4, I've found good deal on a jag mk9, I'm resisting temtation. way too much time on my hands.
I guess ill adjust the carbs temp screw all the way down then tune the idle and see how that gose.
steve
Steve, sorry indeed about the chemo. Re the carbs, I have no idea what you are talking about when you say carb temp screw? So far as I recall, there is an idle screw, a mixture nut (needle) and that is about it.
can you clarify? If you are talking about the mixture, screw it all the way up and then back down twelve flats and you should have a good strating point.
on the Hif carbs its the jet adjusting screw ok that article says to raise it till its level, obvious now that I think about it. I shall try that when i get home from the hospital.
then its time to wack the jags starter motor.
ok i think i got it.
i adusted the jets all the way up then slowly brought the choke down and the idle adjustments till it would run warm with no choke, took a test drive, then adjusted the jets down an the idle abit now I have power when I Give it a bit of Welly, i only tested second gear, this town loves its speed bumps, but I have two days till the long drive to the airport so I should have any supprises delt with by then,
Thanks. I had tracked down welly on the net, but could find no grommet except in its most common usage. Curiously, when I googled the phrase in quotes, all that came up was one use on some weird board called British Car Forum. Thanks,
Bob
Bob
weird indeed - sometimes the most obscure arcane things show up. who knew there was a forum for British Cars?
Bob said:
...all that came up was one use on some weird board called British Car Forum.
Gotta love teh google-thingie!
thanks
back now, home with my cat "the duchess of wellington" I feel like i have a bad hangover.
but the jag mk2 is running and ready for EU inspection.
still need to get the jets on the MGB just right, it still bogs, but its better. and can wait till I'm a little bit better.
and im trying to get a good 3D scan of my MGB dash so i can mill one out of wood. Ill post on that if i have any success.
yes if you're not for familiarize with "Wallace and gromit" your in for a treat they are worth watching no mater what your age. the hevey Lome setting on the A35 van windshield wiper settings, is hilarious.
Wallace: [as the BunVac 6000 labours] Sounds like a really big brute, this one. Give it some more welly.
steve
Hamish Racing TR2/3/3A From novice to …errr … less novice ? Triumph 6
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Bob Claffie T-Series More or less TD action MG 0
J TR2/3/3A Blade-less bumper in TR3A Triumph 1
Sopwith_Camel tach-less Spridgets 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
aeronca65t One less Toyota 2000 GT Other Cars 5
F Bias ply tires [cross ply tyres]- more for less? Austin Healey 36
aeronca65t One less diesel racer. Other Cars 2
L New and improved with 95% less carburetor! Spridgets 20
TR6oldtimer Lotus Elise, where less is more.... Lotus 11
jaegzie Cleaning Up / Less Clutter in Engine Bay Spridgets 4
R less schwab alignment on midget? Spridgets 7
B Dash Pad-less Austin Healey 18
T TR2/3/3A Wanted [maybe]..a restored TR3 for $25K or less... Triumph 0
R Car-less in Chambersburg Austin Healey 1
regularman Less than a week Spridgets 6
A Any ideas on a steering box with less play? Austin Healey 8
TR4 Pertronix offered for less Triumph 11
M Technically I'm still MG-less, BUT.... Spridgets 26
Z Less than a 1000 of the BN1's surviving! Austin Healey 3
R6MGS Less than pinhole radiator leak.... MG 34
drooartz One less car at the show Spridgets 7
Bruce Bowker If it sells for less than $800! Other British Cars 14
G Gasoline additive - 20%more MPG, 70%less emissions Restoration & Tools 0
G Spring-less..... Triumph 2
G One Less Alpine...now Sunbeam (Rootes) 13
Sopwith_Camel reverse welly Gromit? Jaguar 7
S CHROME RING, shift lever grommet ....? Austin Healey 3
M Rev Counter Grommet Spridgets 7
JFS Wedge Steering shaft / fire wall grommet Triumph 2
T Grommet - sling hole in floor - XMSC108 Spridgets 3
T TR2/3/3A Steering Column Grommet Triumph 4
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
tmcarthur Grommet quest Spridgets 6
R Deck lid grommet Austin Healey 7
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
I Bugeye grommet help Spridgets 1
Patrick67BJ8 Red Grommet Locations for a BJ8 Firewwall Austin Healey 4
W Part Number for Grommet Spridgets 2
Trevor Jessie Bugeye steering column grommet? Spridgets 46
Jarhead Rubber Grommet MG 7
2wrench Want new grommet set, engine bay/firewall Triumph 10
C Grommet Help... Triumph 10
DrEntropy One little GROMMET!!! MG 23
AUSMHLY Grommet in rear battery cable panel Austin Healey 1
KLUTZ Steering Column Grommet Triumph 0
D Temp gauge grommet Austin Healey 2
W Fuel pump compression grommet Triumph 2
