TR2/3/3A From novice to …errr … less novice ?
Hamish Racing
I was going through my videos and looked at my 1st event at Curborough in 2017 the car was new to me and pretty much stock..
I decided to do a comparison video to 2022 as both were dry events.
the car has changed quite a bit and I have just got older and greyer.
one thing is for certain the videos are better!!!!
i was also going to do a selection of videos from different years at Shelsley but one after another as they are shorter. What do you think to that idea ?
mctriumph
We never videoed our races but some of the stills are way cool.
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
C Tacho drive - more help require for a novice Healey owner. Austin Healey 2
60Bugeye Sprite Body Work Tips & Tricks For A Novice? Restoration & Tools 24
livinginthepast Confessions of a novice, shady tree mechanic... Spridgets 3
B TR6 Another novice question re:TR6 tune-ups and chokes Triumph 9
E Novice mechanic with a Starter Problem [Hopefully] Spridgets 12
R BJ8 + Novice. Idle speed adjustment help req'd. Austin Healey 5
jjbunn Novice Decals Question Triumph 4
2wrench TR6 Novice level mechanic seeks views on rebuild TR6 Triumph 4
1 Novice question about vacuum advance line. Austin Healey 26
T Novice seeking advice on starting problem Spridgets 32
mjobrien Novice at points based distributors Austin Healey 3
C Floor Pan Replacement by Novice MG 2
L Tyre diameter less than 680mm but bigger than 640mm, any ideas? Austin Healey 11
Bob Claffie T-Series More or less TD action MG 0
J TR2/3/3A Blade-less bumper in TR3A Triumph 1
Sopwith_Camel MGB Less Welly Grommet! MG 16
Sopwith_Camel tach-less Spridgets 11
S Ignition timing - I can't get less than 12 deg at idle Austin Healey 7
aeronca65t One less Toyota 2000 GT Other Cars 5
F Bias ply tires [cross ply tyres]- more for less? Austin Healey 36
aeronca65t One less diesel racer. Other Cars 2
L New and improved with 95% less carburetor! Spridgets 20
TR6oldtimer Lotus Elise, where less is more.... Lotus 11
jaegzie Cleaning Up / Less Clutter in Engine Bay Spridgets 4
R less schwab alignment on midget? Spridgets 7
B Dash Pad-less Austin Healey 18
T TR2/3/3A Wanted [maybe]..a restored TR3 for $25K or less... Triumph 0
R Car-less in Chambersburg Austin Healey 1
regularman Less than a week Spridgets 6
A Any ideas on a steering box with less play? Austin Healey 8
TR4 Pertronix offered for less Triumph 11
M Technically I'm still MG-less, BUT.... Spridgets 26
Z Less than a 1000 of the BN1's surviving! Austin Healey 3
R6MGS Less than pinhole radiator leak.... MG 34
drooartz One less car at the show Spridgets 7
Bruce Bowker If it sells for less than $800! Other British Cars 14
G Gasoline additive - 20%more MPG, 70%less emissions Restoration & Tools 0
G Spring-less..... Triumph 2
G One Less Alpine...now Sunbeam (Rootes) 13
