AUSMHLY
Again, Roger has come up with an intriguing project that modernizes our Classic Healeys incognito.
In looking into Roger’s project and follow-on discussion, 2 main thoughts pop to mind.
I understand that each LED headlights require base cooling fans and ballast units. Will this additional power draw and space requirement create any difficulty to the Healey’s wiring and space limitations or be adversely affected by its hot engine compartment?
I am not trying to be negative as I am one that is intrigued by this type of project.
Ray (64BJ8P1)
Hi Ray, thanks for your kind words. Happy to see others chime in on this topic.
As I research car led headlights, I'm finding that some are self contained units, not requiring an external ballast. No additional space needed. A simple plug and play unit. Remove the current bulb in the headlight bucket, replace with this LED bulb. Use the existing H4 socket that's in the bucket.
Here's a link to Amazon and the write up plus photo of that LED.
https://www.amazon.com/gp/product/B00L8G8IKE/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=AFCCAHNOW2XSP
This is first ever built LED head light / fog light with built-in all-in-one ( heat dispense, fan, resistor, decoder) ultra bright 3000 lumen (brighter than most HID on the market. best HID only has 2400lm). No ballast or resistor need. You just direct plug and play. You can use it as head light. It also has High-low Beam function.
As far as the additional power draw, LED's draw the least amount of power. (I'm running the stock generator. Reason I'm very interested in LED headlights being Headlights are one of the most power consuming items.)
Here's another LED that does have an external ballast. I'm including this one for it lists the specs.
https://www.amazon.com/gp/product/B00MOR4CME/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A1BWWDJZJI6NET
Our NEW Design LED Headlight replaces your standard halogen headlight bulbs or fog lights. These new LED bulbs produce 6400 lumens of light compared to 900-1000 lumens with regular halogen bulbs.
LED Headlight Features:
Plug & play, No need to cut and wires.
Low Power Consumption, Long lasting.
200% brighter than your stock Halogen headlights.
Low Voltage Protection, High precision Constant Current Driver Chip.
Built in IC Circuit (Current Regulator)-Prevents LED Damage From Voltage Variations & Spikes.
Up to 30,000 Hours Service Life.
Specifications:
Power: 80W/set
Voltage: DC12V-24V
Material: Aluminum
Color temperature: 6500K
Beam Angle: 180 degree
Size: Approx 19.6mm in diameter and 93.2 mm in height
Input: 2.6A ± 0.2A
Lumens: 3200lm/bulb
LED quantity: 2PCS Custom Cree chips
Certifications: CE, RoHS
Package included:
2 - Cree LED bulbs
2 - Micro-fans
2 - Ballasts
I look forward to hearing what others think of these two LED's.
PS. these can be purchased a lot cheaper on Ebay.
