    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
TR6 Leaky TR6
SCguy
Every time I wash my TR6 I find a small puddle of water on my rubber floor mats. I've tried to track down the source of these leaks (both sides). I've been under my dash more times than I wish to mention. I know your TR6s probably leak as well. Who has found the source(s) of these leaks, where were they and how did you seal them?
Hey Larry,
Other than the rubber seal at the base of the windshield, the only other place is through the scuttle vent. Once in the scuttle vent the water drops into the plenum and usually drains in to two tubes, each one in the further most corners close to the "A" post. The tube leads to a hose that drops down in the front rocker panel. These corner tubes frequently rust out because debris collects & clogs them allowing water & gunk to collect. The rubber hose also rots & drops away from the tube. Many have run the tube forward to exit out the wheel arch or ran a tube all the way down and out the rocker panel.
A close inspection will expose the problem. This has been the cause of many a floor panel being replaced.
Not to sure if you can see/access them without fender removal.
You can see the hose if you remove the side carpet.
trboost is spot on. I have the same problem. Only after a wash were ther puddles of water on the floor mats. If you can reach up under the dash and feel around in the extreme upper corners, you may find a few rest spots were water has been sitting. I made a solid cover which fits under the grille but is raised by rubber tubing. This still allows air to enter but water to stay out. I'll take some pics on the weekend and post them here so you can see a possible solution to stop further water damage.
Regards
Craig
Larry, mine does the same thing. That is why we have rubber floor mats.
Lay on your back with a strong flashlight and have your neighbor run a water hose all over the front of the car. Of course you will look nuts but you will eventually find that drip. Probably coming from the firewall somewhere.
All Triumphs leak. They are supposed to. If someone says theirs doesn't leak, they just haven't seen it yet.
SCguy said:
Checked my hoses. Everything is new and installed properly. Can't find that leak!
Wish I could say that, personally
mrv8q TR6 TR6 Leaky Carbs Triumph 10
AltaKnight TR6 TR6 leaky heater valve Triumph 2
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
S TR4/4A Leaky Overdrive Triumph 16
M Leaky Fuel Pump and Weak Performance Spridgets 14
C TR6 Leaky brake caliper Triumph 6
Rut TR4/4A Leaky heater valve Triumph 3
M Leaky carbs... Austin Healey 5
Bob_Spidell Leaky Steering Box Austin Healey 11
Bob Claffie MGB Leaky gearbox MG 2
R Leaky carb Austin Healey 6
Zitch Leaky SUs where to buy rebuild Triumph 22
Westfield_XI A leaky dipstick Spridgets 5
M Leaky oil pan... again Triumph 16
tri_carb_healey leaky lead carb Austin Healey 6
L Simple fix for leaky tappet cover Austin Healey 0
V Leaky heater valve? Spridgets 47
60TR3A Leaky Oil Pressure Gauge Triumph 14
MCNX_BFF Cracked and leaky Triumph 20
W Leaky Windscreen Triumph 3
K Leaky roof Jaguar 22
C Leaky exhaust from manifold Spridgets 3
bthompson More leaky axles... Spridgets 6
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
N MGB MGB with Leaky brakes? MG 3
Brosky Leaky voltage stabilizer Triumph 7
B Leaky SUs on E-Type Jaguar 2
Stewart Leaky transmission oil drain plug MG 3
C Leaky Carbs Triumph 16
MTribe leaky fuel pump - ideas? Triumph 6
healeyboz Leaky engine poll Spridgets 31
MadRiver Z3 leaky top Other Cars 2
TR3sharon TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
MadRiver Leaky BT7 Overdrive Austin Healey 2
Adam58 Leaky TiDi [rhymes w/ tiki] transmission MG 25
S Leaky valve cover gasket Triumph 5
delisaj Leaky fuel pump? Triumph 7
19_again Leaky wheel cylinder MG 8
B Leaky Freeze Plug Austin Healey 33
C Leaky carbs. Triumph 6
jjbunn T-Series Leaky Clutch Slave Removal MG 20
Sarastro Leaky rear hub seal Spridgets 10
Woodie leaky wiper posts Spridgets 3
W Leaky clutch cylinder Triumph 2
L Leaky Car MG 2
jsneddon TR2/3/3A Leaky SUs - Late TR3A Triumph 3
Johnny Leaky side shifter Austin Healey 8
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
G leaky brake master cyl MG 4
tr6web TR6 TR6 Manifold gasket help Triumph 1
