    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Leaky fuel pump?
delisaj
Started smelling gas when driving my tr6 yesterday, and noticed a puddle of fluid underneath the car. After looking under the hood, I can see gas oozing out of the fuel pump. Any suggestions on how to fix it/replace it? If it is an easy job, I'd like to try to tackle it, otherwise, I could order the pump from TRF and take it to my local repair guy. Thoughs and suggestions?
As always, thanks in advance. Weather is getting too nice to leave her in the garage.
John
I just did this job, and it's not too difficult.... my only advice: Mark "inlet', or something, on the pump body, so you don't mix up the valves; (ask how I know this) /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
I found the valves to be difficult to remove and replace; I think mine was original to the car, and I had to destroy the original valves to get them out. I also found the TRF kit better than the Moss kit, in that the Moss kit valves seemed slightly larger. In fact, I gave up trying to use them; IMO, the TRF valves themselves were made better.
Use a Vice-Grips, or something similiar to pinch off fuel flow before starting to dissasemble. Amazing how well gravity feed works!
Replacing the pump is pretty easy. Two nuts off and on.
As Kevin notes, you can also get a kit and rebuild them. Usually it's the diaphragm thats punctured and leaking. Rebuilding is a little more fiddly, but not too difficult - just make sure you get the valves the right way around. If you search for Kevin's earlier posts (a few weeks ago I think) he has some pics and good notes.
If your budget allows, I would think about getting a new pump to get going, and rebuilding the old one as a spare.
If you have fuel running down the side of the block you probably have fuel inside the block also, so change the oil.
mrv8q said:
...Use a Vice-Grips, or something similiar to pinch off fuel flow before starting to dissasemble. Amazing how well gravity feed works!
True. Depending on the exact size of the (presumably) rubber fuel line, I prefer to use either a golf tee or an appropriately sized Philips screwdriver or drift. Add hose clamp as needed. Sure, you'll spill a bit getting that line off the pump (or wherever it's attached), but I'm uncomfortable clamping on rubber hoses.
I suppose a hemostat would work if you've access to surgical tools.... /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
I have to admit that I simply replaced Greenie's old leaky fuel pump with a replacement from TRF. It looks exactly like the original, and installation took about ten minutes. I did save his old pump just in case I'm overtaken with a desire to rebuild it, but thus far, that desire has not set in. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Even if the mood strikes ya, you'll need to clean the points if you leave it sit for any time... Ooh. I fergot: I'm in th' 'rumphie house. Youse guys have those li'l "R2D2" lookin' things bolted up to yer blocks fer fuel pumps...
DISREGARD. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Clamping off rubber fuel hoses ('specially if they're a few years old) can lead to some problems: internal deterioration can introduce 'junk' to the system and squeezing 'em can introduce cracking and leaks if they're brittle. Good practice is to replace the hoses as you do the pump. Fuel hose is cheap!
We don't wanna read the tech article: "How to Make a Triumph BARK!".... I.E. "Free-range gasoline, errant spark: WOOF!"
I still remember 20 years ago replacing the fuel pump on a Spifire I had at the time. DOH (stupid, stupid me)...make sure when putting the new pump on that the lobe is not "out" against the pump lever. It goes right back on very easy if it isn't. It took me an hour or more of cussing and swearing to realize what was wrong.
Edit: WOW, it just hit me....I meant 30 years ago..where did the time go?
M Leaky Fuel Pump and Weak Performance Spridgets 14
MTribe leaky fuel pump - ideas? Triumph 6
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
S TR4/4A Leaky Overdrive Triumph 16
C TR6 Leaky brake caliper Triumph 6
Rut TR4/4A Leaky heater valve Triumph 3
M Leaky carbs... Austin Healey 5
Bob_Spidell Leaky Steering Box Austin Healey 11
Bob Claffie MGB Leaky gearbox MG 2
R Leaky carb Austin Healey 6
Zitch Leaky SUs where to buy rebuild Triumph 22
Westfield_XI A leaky dipstick Spridgets 5
M Leaky oil pan... again Triumph 16
tri_carb_healey leaky lead carb Austin Healey 6
L Simple fix for leaky tappet cover Austin Healey 0
V Leaky heater valve? Spridgets 47
60TR3A Leaky Oil Pressure Gauge Triumph 14
MCNX_BFF Cracked and leaky Triumph 20
W Leaky Windscreen Triumph 3
K Leaky roof Jaguar 22
C Leaky exhaust from manifold Spridgets 3
bthompson More leaky axles... Spridgets 6
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
N MGB MGB with Leaky brakes? MG 3
Brosky Leaky voltage stabilizer Triumph 7
B Leaky SUs on E-Type Jaguar 2
Stewart Leaky transmission oil drain plug MG 3
C Leaky Carbs Triumph 16
healeyboz Leaky engine poll Spridgets 31
MadRiver Z3 leaky top Other Cars 2
TR3sharon TR2/3/3A Leaky Steering Box [TR3A] Triumph 29
MadRiver Leaky BT7 Overdrive Austin Healey 2
Adam58 Leaky TiDi [rhymes w/ tiki] transmission MG 25
S Leaky valve cover gasket Triumph 5
19_again Leaky wheel cylinder MG 8
SCguy TR6 Leaky TR6 Triumph 10
mrv8q TR6 TR6 Leaky Carbs Triumph 10
B Leaky Freeze Plug Austin Healey 33
C Leaky carbs. Triumph 6
jjbunn T-Series Leaky Clutch Slave Removal MG 20
Sarastro Leaky rear hub seal Spridgets 10
Woodie leaky wiper posts Spridgets 3
W Leaky clutch cylinder Triumph 2
L Leaky Car MG 2
jsneddon TR2/3/3A Leaky SUs - Late TR3A Triumph 3
AltaKnight TR6 TR6 leaky heater valve Triumph 2
Johnny Leaky side shifter Austin Healey 8
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
G leaky brake master cyl MG 4
T TR2/3/3A fuel pump oil leak Triumph 7
