ID Tag
spooch22
What type of ID tag should be on my wheel arch. I have a 1970 TR6 built in January 1970. The door post has the build date,color codes and trim. There are two rivet holes on the wheel arch so it looks like something was there and the paint is original so there would be no reason to remove it. What should be there if anything?
G
The Roadster Factory sells these plates, ready to go, just like the original. You will need a letter and number punch set to stamp in your numbers (serial, build date, etc.) I would advise getting a scrap piece of aluminum the same thickness and practice, practice, practice before you tackle the new plate. Oh, and the obvious, stamp the number on a good hard surface, the the fender of your car. Sorry, I had to say that. One guy actually did it that way. What a mess.
The plate makes a nice touch to the engine bay. My car (1973 TR6) had the engine bay plate (I put a new one in.) as well as the holes on the B pillar for the other plate, but none was ever installed. TRF sells these too. (they are slightly different, I think) I got so good at stamping numbers, I added one here as well.
G
Yep, I just looked. Same info, however, slightly different layout. One is definitely for the B-Post and the other for the fender.
There were holes, I had to fill them......
S
spooch22
I noticed in the Moss motors catalog that the ID tags for the model year 70 were moved to the door pillar for US models. My car has two holes on the whheel arch and this is why I asked.I thought maybe my wheel arch, being on a early 70 car, was used from the 69 model year, thus the holes.Either way I'm not crazy about the look of the holes.
Brosky
On a 1970 and even the later models (I had two on my 74), there are two holes in the LF wheel arch. The earlier cars used a metal emission plate (available from TRF) and the later 73 & up used a stupid silver decal that wrinkles, no matter how you try to apply it. I just used the earlier version metal plate and it looks great.
I had friend who does pad printing do my VIN plate, rather than stamping in the numbers. Not original, but it looks really good.
Here is the emission/engine settings plate. The attachement below this picture is a picture of my VIN plate, since it's not on my web site.
The attached file is the VIN plate that has been pad printed.
tomshobby
Hi Paul,
I print my own decals. Can print white, silver, and gold also. Anyway, to protect them I use a product from Testor's called Dull Cote. It works well except if it is left in bright sunlight for extended periods like all summer.
I spray a light coat and after drying a coat that covers.
TRTEL
That pad printing looks terrific. Is it a thick ink or paint, air dried or baked on? And can you get any cleaner on it other than water?
Tom Lains
TS8651 & 58107
Brosky
It's baked on in a commercial process and the ink is fairly heavy. You can use any normal cleaner that you would use for the new plates from TRF or Moss, because they're pad printed as well. That's how I got the idea. /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Brosky
Here's a better closeup picture of the engine spec plate. This fills those two holes nicely.
Brosky
Tom, you're a lot more talented than me. I just got my first photo printer, that does CD's as well, so that's been a been fun to play with. Maybe I'll try my own decals down the road.
R TR6 Triumph vin tag information Triumph 7
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
steveg What is this tag? Austin Healey 4
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
D September 1959 Radiator Tag Austin Healey 6
C TR5/TR250 Red Master Cylinder Tag Triumph 4
Lotuswins Coventry Radiator Tag Austin Healey 1
Steve P. Need Bugeye vin tag & title Spridgets 15
bugedd VIN tag wanted Spridgets 20
Nelson Replacing engine ID tag Spridgets 15
DornTRoriginal Frame ID Tag Question Triumph 2
E How to identify Healey carbs, Tag missing Austin Healey 1
H English front tag install question MG 13
J Chassis ID number tag missing Triumph 11
B TR5/TR250 TR250 frame tag Triumph 0
bighealeysource Engine ID tag color on BN2 Austin Healey 3
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
Bob Claffie Tag sale special Spridgets 0
Bob Claffie Tag sale special MG 4
R TR6 '71 TR6 Windscreen Vin Tag Rivets Triumph 1
Jer 1275 ID Tag ? Spridgets 2
H Cool tag or good cribbage hand MG 8
H Cool British tag MG 10
O ID for 1275 with no tag Spridgets 1
B 61 Midget VIN Number Tag Spridgets 7
angelfj1 Help Need replacement body ID tag Triumph 8
7 Midget missing VIN tag....what to do??? Spridgets 26
A TR4/4A TR4A commission tag paint and trim codes Triumph 5
vping Engine ID Tag Spridgets 12
D BN1 wiring harness/Plastic ID tag Austin Healey 12
PeterK TR4/4A TR4A engine block tag Triumph 2
fmichaels engine vin tag Spridgets 5
G VIN Tag Question Austin Healey 1
S Engine I.D. tag MG 3
P Interchanging bumpers&license tag mount Sunbeam (Rootes) 1
