I can't believe the difference in the speed!!
Brosky
Basil, thank you so much! What a great change in reaction time in logging on and posting. Night and day difference!
The best forum only gets better!!! /ubbthreads/images/graemlins/cool.gif
Holy Krikeys!!! It is BLAZING. Can you come fix my websphere portal site that is crawling like a slug now?
Went so fast the computer locked up because it couldn't handle the speed! Thanks Basil, for everything.
When I saw the forum was down with a link for a temporary forum, I figured it would be down for a week or more.
I was pleased to see how quickly the transision took.
Thanx again Basil for making this forum possible /ubbthreads/images/graemlins/england.gif
What a difference! I always had a problem with the site loading early in the morning over my morning coffee...no problem today!
Thanks Basil!... /ubbthreads/images/graemlins/smile.gif
I've now learned to heel and toe my mouse when on the BCF!
[ QUOTE ]
[/ QUOTE ]
Thanks all. I'm very glad I was able to get things (mostly) back online quickly. I ran into a few snags along the way, but overall the move went pretty well.
With this kind of speed, Bas, Jaybird should be able to set a new lan-speed record for posts.
Oh, and by-the-bye, now you've done it, my laptop is smoking.
Bill
Bob Claffie Would you believe --- Spridgets 14
Jim_Gruber Source for Smiths Gauges in UK I believe Spridgets 7
S Can't Believe I'm Doing This Other Cars 20
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
K TR2/3/3A NGK BPR5HS spark plugs I believe are one stage hotter.... Triumph 5
drooartz Just ordered me a new Jeep, there is a logic to it [though none believe me] Other Cars 13
AngliaGT Can't Believe that it's Been Three Years..... MG 3
rkep01 I can't believe that it's finally begun Spridgets 10
Morris I can't believe it! Spridgets 3
mgnewbie I can't believe I broke the head bolt! MG 8
roscoe Not going to believe this one. Austin Healey 2
T I can't believe it - daughters B-day gift Spridgets 12
2wrench I can't believe what just happened Triumph 27
2wrench Can't believe I broke my rotor Triumph 12
regularman I believe a blind man, might be able to see my... Spridgets 14
T would you believe... Triumph 9
V I can't believe my eyes! Triumph 14
Adam58 You'll never believe... MG 4
bugimike can you believe this? Spridgets 6
H Well you are not going to believe this!!!!! Spridgets 11
vping Can't believe I fit my 1972 Midget in.... Spridgets 18
jaybird WHOA! Another BCF first I do believe! MG 11
M TR4/4A Difference between two Oval Air Filters Triumph 3
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
AUSMHLY The difference between GL4 and GL5 gear oils Austin Healey 0
Got_All_4 TR6 Any difference between 69 & 70 camshafts Triumph 3
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
K TR4/4A Difference between 4A frames and TR6 frames? Triumph 6
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
drooartz MGB Difference in clutch master cylinders? MG 4
K BJ7 interior back panel difference Austin Healey 4
M TR4/4A Is there a difference between the "Body" number and the Comission Number? Triumph 8
HealeyRick A 100 With a Difference Austin Healey 9
trrdster2000 GT6 Another little difference, big problem. Triumph 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 10
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
N 3" difference between front and rear track Spridgets 5
HealeyRick 100 With a Difference Austin Healey 6
5 Mk1 vs Mk2 front shroud difference Austin Healey 6
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
R difference between instal of 1500 radiator in 1275 Spridgets 3
T Weight difference beween steel and wire rims Triumph 11
K TR4/4A Difference in Clutch Shafts 4A? Triumph 4
M 3.0 iron weight difference Austin Healey 7
L For those who know the difference Lotus 5
bugedd Difference in 1275 heads? Spridgets 24
S ride difference oem vs poly bushings Triumph 4
H Steering box adjusted, what a difference Austin Healey 0
