How do I get the door strap off [pic]
Miser
The book says to drill out the silver rivet in the pic. I can't get a good angle with my drill under it I keep breaking bits. Shall I take my sawzall to it?
TR3driver
Great Pumpkin - R.I.P
I'd use a Dremel with a grinding burr. Slower, but less apt to damage anything else.
jsfbond
Drill the top of the rivet down, using a bit larger than the rivet shank. Go slow, and when you get to steel stop drilling. the pin should be ready to be tapped out, again from the top.
dklawson
I used a worn down cut-off wheel on my die grinder... sort of a high-powered version of what Randall said above except I was using an abrasive wheel instead of a burr. There is also less material to remove from below than above... and less evidence to look at if you make a mistake.
S Door Check Strap Austin Healey 5
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
sundown TR6 Door check strap Triumph 3
A TR2/3/3A TR-3A door strap/stop attachment to body Triumph 10
K door check strap Spridgets 10
me61ic Forum search and Door Check Strap ? Austin Healey 1
Stinger TR4/4A TR4A Door Check Strap Spring Clip Replacement Triumph 4
W Broke check strap on door Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
F TR4/4A TR4 Question: Door check strap pin Triumph 5
Rob Glasgow Door Check Strap Austin Healey 12
M Door check strap repair Austin Healey 6
S door check strap attachment Triumph 15
S TR2/3/3A door strap checking tr3 Triumph 8
6 door check strap Triumph 6
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
