HEY SKIP, IT'S ALIVE
DNK
With the great help of Dave (TOC) the Wedge roars to life.
Not without worry.
Things that were Kady Wompus.
-The firing order in the front of the manual is missin the 5 and I put it in the wrong order.
-Either I didn't tighten down the rocker arms hard enough or they loosened up. Had to re torque the bolts.The drivers side was real noisy and the pass.side is starting to make noise.
-Don't forget to hook up both dizzy connections.
Pulled the pass. side cover off and all the nuts were tight. Hopefully the slight clatter is just tightness in the new head,cam,and lifters.Beginning to think I must have lost concentration on the drivers side and forgot to torque them
There is a slight leak in the exhaust connectors I showed. When I spun them to get them up out of the way I noticed 1 of them was not tight in a small area. There must be a dimple in the muffle pipe.
I have checked all the hoses and tightened the clamps onelast time so all that is left for it to beon the road is to install the tie rod ends and put the wheels back on.
YEA!
Did you lose your camera during this process or can we expect a barrage of progress photos very soon?
Geez Pics. Haven't you seen enough half dressed v-8s in your life time Paul?
Stripped with old heads
New heads on
Timing chain installed
Front Cover
Intake on
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Haven't you seen enough half dressed v-8s in your life time Paul?[/QUOTE]
Yes I have Don, but not too many have ever been of the variety that you just posted. Just how much room do you have to work in that front end?
Not much, here a shot with all the stuff up front.
And here's a pre shot with all the stuff on.
Holy moley!!
Where does the radiator fit in there????
If you notice, carefully, this vehicle sports a prototype vacuum advance unit that actually plugs into the upper radiator hose.
Room up front?
Uh......no.
But, it all fits.
Brosky said:
Holy moley!!
Working on a TR8 engine bay will make you appreciate the room provided in a TR4/6, and make you positively weepy for a Spitfire.
Worth it however.
Don - one thing to consider, I found my TR8 ran surprisingly stronger with the fresh air vents from the front side of the engine back connected to the carbs. She really seems to like the cold fresh air. YMMV w/ your FI.
So when do you think she'll make it out of the garage?
Explain Please
Depending on weather
DNK said:
Explain Please
Hi Don. I had the oval foam air filters on my carb TR8 which pulled air from the immediate area in the engine bay. As part of my efforts to get her through CA SMOG I fitted the stock air boxes and the ducting that brings fresh air in from the vents on the far outside top corner of the front engine bay. Made a surprisingly noticeable difference in how she runs. I can post pictures when I get back.
Tom, Look at the tube in front. It does pull air from the front of the car.
Hi Don - saw that. Was just observing that fresh cool air made a big difference for me.
That air filter will still pull warmer air in from the engine bay BUT much less than a carb car will and I <span style="text-decoration: underline">did</span> see the air intake from the front of the car.
Usually a bit hotter down here than up where you are ;-)
So what is next on the build Don?
Ran it again for about 10 minutes @ 2000 RPM. Then pulled the oil plug to drain.
Installed the tie rods and will bleed the 4 nipples on the front calipers and install the wheels. Then off to an alignment shop.
I guess the major thing next is to hook the laptop up to it and find out what the #'s show. Then an interior if I'm still in this area this winter. If not,nothin.
tdskip said:
...Moving coming up?
Maybe
Vroom , Vroom. The alignment shop is only about 4 -6 miles away
Waiting on a banjo bolt for the clutch master first.
Started it up. Up and back in my fairly long driveway. Back in the garage to do a double check. Aw what the heck. 1.3 mile drive to get some more fuel in the tank.
That new cam and heads ,WOW. Back in the garage to top up the oil and check for leaks.
There seems to be a little slop in the steering at 12:00. The manual rack is stiffer than the power but quicker. It will take some getting use to.
Next drive, alignment shop.
Slop in R&P steering:
Rack mounts tight?
Inner tie rod ends okay and tightened to rack?
Column joints tight?
Collapsible sections tight enough to prevent wiggle?
kodanja TR2/3/3A Hey Its been a while Triumph 7
JPSmit Hey Tom! Other Cars 15
K TR4/4A Hey CJD...gravity bleed clutch MC and slave? Triumph 6
Keoke Hey Use guys Austin Healey 1
Basil Admin Note Hey Joe Reed! Your watch MG 4
Keoke HEY!! Austin Healey 2
Mickey Richaud General MG Hey, Drew! MG 2
Keoke Hey !!! Austin Healey 7
W Hey Drew.... Spridgets 27
Mickey Richaud Hey, Walter! Other Cars 4
Mickey Richaud Hey, Walter! Other Cars 1
Mickey Richaud Hey - J-P! Other Cars 3
J TR5/TR250 Hey Pat, you are getting behind Triumph 0
Mickey Richaud Hey, Tom [Nutmeg] Other Cars 2
Mickey Richaud HEY, Nial! Other British Cars 6
Mickey Richaud Hey, J-P! Other Cars 7
5 hey new here Other British Cars 6
Mickey Richaud Hey, Paul [Brosky] - Triumph 2
JPSmit MGB-GT Hey Mickey - here's a mod for the GT MG 10
J Hey, Northern California Healeys Austin Healey 0
Sherlock Hey Walter! More IHC trucks for you Other Cars 4
Mickey Richaud Hey, Tom [Nutmeg]! Other Cars 3
JPSmit Hey Billy! Other British Cars 5
Mickey Richaud Hey, J-P Other Cars 11
Mickey Richaud Hey, J-P! Other Cars 10
Cottontop Hey, Healey Rick.... Austin Healey 1
A Reversed battery posts?? Hey Pat, get this! Triumph 35
Morris Hey JP...OT Spridgets 7
JPSmit Hey Doc!!! Other British Cars 3
JPSmit Hey Nial Other British Cars 2
gsalt57tr3 hey all Triumph 10
AngliaGT Hey Doc - Did You See This Cortina? Other British Cars 1
DNK Hey Andy Triumph 9
JPSmit Hey Theron Spridgets 4
DNK Hey Doc Lotus 1
Mickey Richaud Hey, Nutmeg! Other Cars 1
JPSmit Hey Morris Spridgets 3
JPSmit Hey Mickey!!! MG 4
JPSmit Hey Jack - you neeeeed this! Spridgets 5
jdubois Hey, at least she kept failing in style! Triumph 6
Mickey Richaud Hey, Basil - Other Cars 8
DNK Am I a Fool? [Hey, Rhetorical Only!] Triumph 18
G Hey JP Spridgets 1
Mickey Richaud Hey, Doc and Mark II Other Cars 5
JPSmit Hey Doc & Mark Other Cars 16
Mickey Richaud Hey, RANDY! Triumph 1
JPSmit Hey Drew! Spridgets 9
vping Hey an Latest from VPING!! - My '63 MG 2
DNK Hey Lotus 18
G Hey Hap, got $25 ??? Spridgets 16
