General Tech Heater control valve/cable
KVH
I’ve spent three hours trying to get this cable to work. No matter what I do, the heater control valve moves about 3/8 of an inch forward or backward. I’ve tried loosening the cable clamp nut and sliding the valve one way, and then doing the opposite. I tried adjusting when they came control knob is pulled out and when it’s all the way back in. I can’t figure this out. Is there a trick?
I do not think there is a trick to it. You need to determine if your cable has enough movement to allow the valve to fully open or close. Loosen the cable from the valve and determine how much movement you need to operate the valve. Then operate the cable and see how much movement you have there. I suspect there is something going on with the cable not allowing enough movement to operate the valve. It could be that the exposed cable has been shortened to much. If this is the case you may need to shorten ( cut) the cable housing to expose more of the inner cable. If you need tips on doing that just ask.
Charley
BierRunner TR6 Thank You - Heater control Valve Replaced! Triumph 1
BierRunner TR6 Removing the old Heater Control Valve Triumph 2
H BJ8 Heater Valve/Control Tap Austin Healey 3
Lutz Kramer Heater Control Valve function Austin Healey 2
edkap2002 TR6 Heater Control Valve Triumph 9
T TR4/4A Heater control valve - cant completely turn off Triumph 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
S TR4/4A Replace or rebuild heater control valve? Triumph 5
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
D '65 Spit heater control valve Restoration & Tools 1
J TR4/4A TR4A Heater Control Valve Question Triumph 4
GBRandy Wedge TR8 Heater Control Valve Triumph 7
eschneider anyone seen this heater control valve? Other Cars 6
Stinger TR4/4A TR4A Heater Control Valve Question Triumph 1
Stinger TR4/4A TR4A Heater Control Valve Help Triumph 10
Magyar Leaking Heater Water Control Valve Spridgets 4
58Custom Heater control valve. Suggestions? Spridgets 39
Steve1970 Heater Control Valve Assembly Triumph 7
BobbyD New Heater Control Valve Triumph 15
2wrench Heater control valve and spigot install Triumph 20
Jim_Gruber Heater Air/Valve Control Cable Spridgets 2
VelodromeRacer Leaking Heater control valve Austin Healey 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
S Heater and fan control replacement - any advice? Austin Healey 9
B TR6 Removing the ckoke/heater control knobs Triumph 4
KVH TR4/4A Shortening the Steel Wrapped Heater Control Cables Triumph 2
Rut General MG Heater/air control MG 0
Jim_Gruber Heater Knob/Control Switch for BE Spridgets 36
H heater control panel and knobs Austin Healey 1
S Choke & Heater Control Knobs Triumph 2
W Heater Control Tap Spridgets 3
Steve1970 how does the heater control plinth connect? Triumph 4
H Heater control question MG 3
Stewart heater control cable lenth? MG 0
S removing knobs from heater control etc Triumph 4
Shealey How to repair a rusted heater control cable W/Pics Spridgets 0
jhorton3 Heater Control Cable Spridgets 2
Jim_Gruber Heater Control / Knob / Cable needed Spridgets 2
2wrench Is this Heater Control Cable broken? Triumph 6
Dave Richards Stuck heater control lever Austin Healey 4
I TR6 69 TR6 heater control cable Triumph 6
S Heater Control Panel ["Why don't it fit?] Austin Healey 14
Musicman Installing Heater Control Cable Triumph 3
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
jerrybny TR6 Heater Control Plinth Light for 73 TR6 Triumph 1
Rob Glasgow Heater Control Panel Austin Healey 1
A TR6 TR6 Heater Control Question Triumph 4
D SII E-Type Heater Box Jaguar 0
