Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback
mwagon
Healey Overdrive Accumulator Piston using O-Ring Seal Update Feedback
In the process of rebuilding the O/D & noticed that AH Spares offers an updated Accumulator & Piston that uses a Rubber O-Ring on the Pistion, instead of the original design that uses a metal Pistion Rings. I don't see any other supplier selling this yet, but wondered if anyone has tryed this setup yet. I like the idea of eliminating the metal Piston Rings. The originals last a long time , but steel rings on an Alu. Accumulator never seemed right to me. Seems like it would minimze wear on the accumulator, similar to the Operating Piston arrangement
Re: Healey Overdrive Accumulator Piston using O-Ring Seal Update Feedback
I could be mistaken (it happens...) but seems like the later Healeys, certainly the units fitted to MGBs had switched from cast-steel rings to rubber O-rings, so you really won't be blazing a trail__which is to say that they're proven/accepted.
Likewise, the operating pistons on the later Healeys (and ALL MGBs, regardless of ovd type) used O-rings too, if you're so inclined to swap out these pistons.
Not to mention, the O-rings cost a minute amount compared to the cast rings!
[edit- updated info, thanks Randy.]
I left mine as-is on the basis that the accumulator piston is also the pressure regulation valve and I felt that having an oring constantly crossing over the spill ports at 400-odd psi would shorten it's life greatly. The later design with oring seal used different size holes for the spill ports I think. Definitely good to replace the apply piston rings with orings. Andy.
Steel piston
Aluminum sleeve
The same pieces, save for new cast rings and O-rings, but with a dry-film polymer coating added.
longbridgehealey Longbridge-built Healey Overdrive Switch Austin Healey 1
W Healey 100 Overdrive stopped working Austin Healey 15
G Austin-Healey BN1 Overdrive Challenges Austin Healey 5
Lin Cruise control on an overdrive Healey Austin Healey 4
M Healey Overdrive Bench Testing Austin Healey 2
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
AUSMHLY 2025 Austin Healey YouTube AI Austin Healey 1
G Healey Trunk Handle Removal Austin Healey 8
L For Sale AUSTIN HEALEY: REAR AXLE Austin Healey Classifieds 0
dougie Big Healey Racing Austin Healey 0
L For Sale AUSTIN HEALEY: REAR AXEL WITH DISC BREAKS Austin Healey Classifieds 0
J For Sale Big Healey bits and pieces Austin Healey Classifieds 2
L For Sale Austin Healey Body Panel Austin Healey Classifieds 2
D A Red Engine In a Big Healey Austin Healey 19
H Big Healey Search Austin Healey 1
Basil Other Austin Healey Enthusiast sites Austin Healey 0
Basil Healey Registry forms changes Austin Healey 0
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 18
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 3
R Healey 100 Dipstick Stuck Austin Healey 12
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 2
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
