T
Tinster
<span style="color: #000099">I hope there is a special extra hot cave in heck for
designers who create parts combinations, they themselves
could never assemble. Hateful, hateful, hateful hand brake assembly!!
Why -0h- Why did I ever decide to make my hand brake fully
functional... when I remember the torture and agony
installing it the first time- with slack in the cables??
Now that the center of my car is once again torn open
and the hand brake in individual pieces, I am still unclear
how the spring and button fit into the scheme of things.
Does the small, semi-loop at the very end of the spring,
slide down the arm shaft, with radius against the metal arm?
Does the semi-loop slide over top of the small hinged,
single tooth arm, inside the handbrake lever??
If this concept is correct? Do I wrap everything in strong
tape to hold it together while I try to thread the eye of the
needle with bushings, bolt, etc?
BTW- I did not have the energy to remove my rear end twice
in one week. I am working with hand brake cables under tension.
I've come up with a way to get the assembly apart under tension.
Put back together might be a different story.
thanks,
d
d</span>
thanks,
d
d</span>
