TR2/3/3A Greasing the the Idler lever on front suspension?
karls59tr
Bronze
Replaced it last year. The grease zerk on the bottom faces straight down and close enough to the frame that you can't get a grease gun to fit in there. I'd like to replace the zerk with a 90 degree one (was there a 90 on there from the factory?) but I can't find the right size locally. I'm wondering if the aftermarket replacement is some kind of oddball thread size for the zerk. The threaded portion seems wider than the other grease zerks on the car. Anyone know what size is on there and where I could get one. Maybe the original idler I replaced had so much play in it because no one could get grease in there?
If it a replacement part, perhaps it is metric. I bought a box of various sizes, both in metric and imperial, from Princess Auto a couple of years ago because I got frustrated trying to size zerks in various pieces of machinery. Cheers, Mike
I'm not certain offhand, but I think the originals may have been 1/16" BSP threads, which would be 28 tpi but larger in diameter than 1/4-28. (.304" according to my chart, which is almost 5/16".) They were definitely right angle.
TRF sells replacements for the original nipples at a premium price, which also suggests they are somewhat unusual threads.
Thanks for the input guys. I now believe the aftermarket idler lever from Moss must have a metric grease zerk on it. Should have known. Moss could have told them in Taiwan or China to at least put a 90 degree metric zerk on at the factory. Or am I turning into a curmudgeon?:playful:
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
K TR2/3/3A Greasing the Front Wheel Hubs? Triumph 9
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
BN6_2197 Greasing the distributor of BN6 Austin Healey 1
RJS Greasing U-joints Triumph 13
NardisCNC Greasing Splined Hubs for Wire Wheels........... Spridgets 6
hondo402000 TR6 TR6 wiper cable and greasing it Triumph 11
H Greasing the drive line Austin Healey 4
S Greasing new upper ball joint? Triumph 5
D Greasing the car Triumph 14
hondo402000 TR6 Greasing the TR6 urgent help needed Triumph 2
R6MGS Extreme Degreasing! Restoration & Tools 16
bluemiata90 TR4/4A greasing rear u-joint on tr4a Triumph 1
M TR2/3/3A Cracked Welds on Steering Idler Arm Triumph 5
T TR2/3/3A Question on steering idler unit Triumph 2
Martinld123 Steering Idler Noise Austin Healey 21
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Lutz Kramer Steering box and idler bush Austin Healey 4
F Tightening the idler pulley bolt on a 1098 Spridgets 2
G Steering idler arm removal Austin Healey 33
RickPA Need help installing steering idler oil seal Austin Healey 6
RickPA Clunky steering idler Austin Healey 8
C Idler Arm Differences and Rebuild Question. Need Help! Austin Healey 2
R BJ7 Steering Gear and Idler Rock shaft Austin Healey 4
C Oil Seal Removal from Idler Arm? Need Help Austin Healey 4
BN6_2197 What to put in steering idler reservoir of BN6 Austin Healey 2
pkmh BJ8 Idler Gear [Steering] Austin Healey 34
S Austin Healey New Steering Idler Assembly Austin Healey 2
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
D MK2 idler arm Jaguar 6
T TR2/3/3A tr3 idler arm and shocks Triumph 2
GBRandy Wedge TR8 Idler Bearing P/N? Triumph 10
6 Problem after installing new steering idler Austin Healey 15
6 End Play in BJ8 Idler Austin Healey 2
6 Problem Removing Steering Idler BJ8 Austin Healey 9
6 How do you remove steering idler on BJ8? Austin Healey 0
6 Idler steering Assembly Problem [BJ8] Austin Healey 7
F Steering Idler Austin Healey 14
M Steering idler bushing direction Austin Healey 3
C Steering Idler problem Austin Healey 7
A How do I convince steering arm to come off idler? Austin Healey 10
N Steering Idler Box Austin Healey 3
nevets steering box and idler removal Austin Healey 14
C steering idler Austin Healey 5
S BJ8 Steering Idler Assembly Austin Healey 3
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
mctriumph For Sale lever shocks from a 61 Morgan plus 4 Other British Classifieds 0
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
