TR6 Gold stars for TR3Driver&NutmegCT: it's a fuel delivery issue
sammyb
When last I posted, I had taken the TR6 out for its first drive since I bought it and did the head R+R and it had run fine for about 12 blocks then crapped out under load. It would rev in neutral after choking at idle for a moment, but would die in gear. I was thinking a bad connection/ignition or maybe fuel. Randall and Nutmeg said it was fuel, fuel, fuel.
So I finally got around to putting a clear inline fuel filter before the pump. Car started almost immediately and the filter filled up with fuel. Then as the car came up on the choked high idle, the filter drained of fuel. So they were right. Three gold stars for our experts.
Didn't have a chance to check the line leading back to the tank, but I have a suspicion that it's the pump that is dying -- just putting out enough suction to keep the car running at idle. I had previously drained the tank and fuel line. I can always drain the tank again and replace the fuel line outright.
I flipped open the gas cap. Made no difference.
Open the fuel cap, connect an air line to the fuel line where it connects to the fuel pump, blow air back to the gas tank, listen for bubbling in the tank to make sure the line is clear. As per earlier post, I 've have to replace gas lines in several TR6's that sat for a while.
MARV
Marvin and Andy: yup that was already on the plan. Just didn't have time yesterday afternoon to deal with it. Already have the air compressor there with the nozzle hooked up ready to blow it back. I still think that the fuel pump might be an issue, but I always think the worst of any situation, so that I can be surprised and happy when it's a cheap and easy fix.
Meanwhile, I put the new seat upholstery/foams on, so once I get this fuel thing fixed, I'll be able to drive it comfortably (even if the car still looks like **** on the outside.)
Not a bad idea, Andy, to do a quick go-through of the fuel pump either way, because it will give me a good look at the diaphram. Since it was running without a fuel filter, I'm guessing I'm going to find some junk in there.
Went up to my shop today and put the air hose to the fuel line (gas cap open, of course.) The first pull of the handle sent the nozzle out of my hand from back pressure. Put it back on and pulled, holding it tightly...and after a little pressure it let loose and I could see the vapor coming up from the tank. Whatever was in there broke up and pushed out. I couldn't see it in the tank with a flashlight.
When I started the car, the fuel flow was normal, even under throttle. Sounded pretty darn good, actually, for a car that really hasn't been driven in years.
tahoe healey Gold Sparkle in Oil Austin Healey 15
K TR2/3/3A Coil nuts? The SW and CB nuts on a Moss gold coil? Triumph 3
HealeyRick Gold Level Concours Value Austin Healey 20
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
B Gold TR8 Waxhaw N.C. Spotted 2
2 TR2/3/3A Classic Gold TR2-4 water pump Triumph 5
steveg Moss Classic Gold 7 lbs. cap now "sucks"! Austin Healey 0
P Guages with gold rings Spridgets 2
B TR6 How restore the "gold" finish of TR6 door latch? Triumph 4
K Gold in the junk yard Triumph 5
Michael Oritt VIR Gold Cups/ACME SPEED SHOP Racing 1
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
HAN8L1965 Found Gold Spridgets 14
angelfj1 Warning - Moss Classic Gold Master Cylinders MG 0
angelfj1 Warning - Moss Classic Gold Master Cylinders TVR 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Spridgets 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Austin Healey 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Lotus 0
angelfj1 Warning - Moss Classic Gold Master Cylinders Jaguar 0
AngliaGT "Classic Gold" Water Pumps MG 2
T Free Dunlop Gold Seal 5.20 13 bias ply tyre Spridgets 5
M VIR GOLD CUP THIS WEEKEND TVR 0
S Gold Wheels MG 8
Sherlock Emoticons & the new Black/Gold style FORUM Navigation Questions 2
jerrybny Classic Gold Semi-Metallic Brake Pad Set Triumph 2
Jim_Newman gold cylinder head Jaguar 4
Newkie Napa Gold oil filter MG 5
healyfan53 Barret J. vs Gold concours BT7 1960 on the block Austin Healey 23
JeffR Thanks for all the help - Gold! Austin Healey 4
S VIR Gold Cup Historic Auto Race Photos Racing 1
G T-Series What is a MG TD "Gold Seal" Engine? MG 17
Bret Gold Corvette Other Cars 20
Webb Sledge Gold Cup Race Pictures... Again MG 3
Webb Sledge Gold Cup Race Pictures... Again Triumph 0
dklawson Pictures - VIR Gold Cup MG 3
dklawson Pictures - VIR Gold Cup Austin Healey 10
dklawson Reminder - Gold Cup Races at VIR Start 6/10/05 Austin Healey 2
Webb Sledge Gold Cup Historic Races Triumph 1
T Bugeye TV stars :D Austin Healey 2
D Pawn Stars Spridgets 13
L On History Channel Tonight--"Pawn Stars" Austin Healey 5
HAN8L1965 Pawn Stars Spridgets 45
mrsprite Midget stars on a primetime show! Spridgets 26
NutmegCT Stars and bars? FORUM Navigation Questions 3
YankeeTR TR's as Movie Stars...Hey...That Rhymes! Triumph 4
YankeeTR TR2/3/3A TR3 Stars in the movie "Flywheel"... Triumph 4
TRopic6 TR4/4A TR4 stars in the new Chipmunks movie Triumph 7
Sherlock Stars and their cars... neat link Other Cars 6
Sherlock Top Ten Car Stars Other Cars 32
C Throwing Stars MG 6
