Fried voltage regulator
Recent chat visitors
bugman
After having reinstalled my motor and transmission, I ran the motor approx. one or two minutes when smoke came out of the voltage regulator. Removed it only to find it was fried. Checked all wiring to be correct. Only thing I found was that while changing brushes on the generator I pinched a brush wire on the rear plate. Could this have caused the problem?
Yes, either wire, field or main wire being pinched would have been a dead short.
At least the wire harness didn't smoke.
Yeah, 'fraid so. All the battery current goes through one winding in the regulator, and although it can take a lot of current, it can't take battery dead-short current.
The regulators are not terribly expensive, fortunately, and are readily available.
Cokerair TR4/4A Fried Ignition Coil Triumph 18
S Fried electronic ignition? Austin Healey 22
2wrench TR6 What's for dinner? Fried Coil??? Triumph 4
hondo402000 New front harness is Fried! Triumph 5
Gundy Fried tach Spridgets 26
AUSMHLY Headlight switch - fried Austin Healey 23
F BATTERY CABLE [fried petronix] Austin Healey 20
bighly New OD Solinoid fried ??? Austin Healey 3
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
Jim_Gruber Voltage Regulator Question Spridgets 4
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
M TR4/4A Voltage Stabilizer question. Triumph 10
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
6 Voltage Output Question Spridgets 3
Superwrench Voltage Reg Austin Healey 1
