First Race-2006
Re: *Results*-First Race-2006
Doug, any metal to metal contact results in a 13 race / 13 month probation, or outright ban from competition for the same period.
Jeff
It's an attempt to keep vintage racing from becoming a high speed demo-derby like the SCCA.
Keeps a moron from repeatedly bouncing his Crosley HotShot off your EX182. (MGA) /ubbthreads/images/graemlins/grin.gif
[ QUOTE ]
Funny thing is, I PUT A SWAY BAR ON IT!! I went with the 5/8" size, not thinking I would ever auto-x it. A little larger than the stock size but not too big I thought. Now I can see the value in the larger sizes! Oh yeah, I also put on new springs in front, rally springs in back, heavy duty shock valving all around, and poly bushes everywhere.
Even funnier, those pictures are of turns obviously, but I'm not turning, I'm still moving straight and tearing up my all season tires BAD!
[/ QUOTE ]
Sway bars are best used for final/fine adjustments.
Got to get it close w/ springs first.
My suggestion....Go with a good road racing set up first.
Then tighten it down a bit with adjustable (front?) shocks (at the Auto-X)
Consult someone who has experience setting up your car. It will save you $$$
(Where is Tony Barnhill?......He knows MGB-GTs)
Enjoyed the race report, Nial, and the pictures. Great colour scheme on the Mini!
Are you doing Shannonville this year? Or Cayuga? Or Mosport?
Simon.
[ QUOTE ]
[/ QUOTE ]
Well, if you've initiated the turn and the car is still traveling straight forwards, then you're "understeering". You're bar _might_ be too big already, or you could be braking way too late for the turns. Judging from the car's pitch in the pictures, I'd guess you're braking a bit too late for the turns. The front tires only have so much traction. If you're braking as you start turning, it's easy to excede the traction limits of the front tires.
If I'm not mistaken, best practice for turn execution is to brake in the straight before the turn, initiate the turn, sustain a constant speed approaching the apex, start accelorating at the apex, and continue accelorating out of the turn. Of course, car balance and tire traction will change the characteristics of the car in turns and naturally the speed in which you can take the turns.
That's a good point. I'm pretty sure you're right, in that the brakes might still be on hard at this point. You're supposed to ease off the brakes as you ease into the turn (gradually). The more classical approach is to finish braking completely, then turn in, but that's not using the traction circle to its full potential.
Doesn't matter what part of the turn you are in or how badly you were screwing up during the picture.
You have to get rid of that roll in order to keep your camber under control.
You can't tell by the sig. but, I am drifting left to right (driver's) around a cone that is not in the photo. yet the roll is not extreme.
BTW, there is no sway bar on the Elva, front or rear. ( nor will there ever be )
I have tie down shocks that are not adjustable.
Valved properly, you can run them on a bumpy road to the Auto-X & not have to make any adjustments.
Use a bump travel indicator to make sure you have it right.
I have gone through absolute he11 trying to get the springs/valving correct.
Don't reinvent the wheel, talk to someone like Tony B.
Keep in mind that your body is dramatically lighter and lower than our stock B's and Midgets. A front bar is somewhat necessary for my midget, at least.
I REALLY,really.....really.. hate to admit this BUT,........
My 2600 lb Pinto handles about as well as the 1300 lb Elva. (all things considered)
The Pinto has #700 springs & a 1" sway-bar up front.(& corners flat)
The Elva has #250 springs & no sway-bar up front.(& rolls a bit)
It's all in the set up.........
I got the Pinto nailed down on the 1st try because someone told me how to do it.
(except for playing with tires, camber, caster & toe)
Yes the Pinto is a fat pig on a Auto-X course, but I would NEVER go 120 mph in the Elva. /ubbthreads/images/graemlins/eek.gif
I don't want to add any springs that may lower my car any, as I drive it all the time on the roads and its plenty low. Other than the rally springs in the rear, I can't find any springs that are firmer without being lower as well. Am I looking in the wrong place?
You have a wide variety of choices in spring diameters, lengths & rates.
Also, the adjustable perch shocks allow you to adjust ride height to some degree.
You have to measure everything at your preferred ride height. ( shock eye to shock eye as well as compressed spring length)
Then measure uncompressed spring length and have your spring dynoed for a base line.
After all that you find a company that sells the setup you need and then comes the part you will probably get wrong a few times...........Guess your new spring weights.
Tie down single adjustable shocks allow you to set your rebound rate via a little knob.
You can drive your car loose to the track then simply turn the knob and have a instant track weapon. ( that you can otherwise drive on the road over bumps)
aeronca65t Last Race-2006 Racing 4
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
jfarris ALSCCA Club Race Barber Motorsports Park Racing 0
M 1275 Race Clutch Racing 5
B Spridget with a Tilton Race Clutch Racing 1
dougie 2022 Vintage Race Preparation Racing 9
dougie Goodwood Revival - Freddie March Memorial Trophy Race Austin Healey 4
jfarris LBCs in our SCCA club race Racing 0
Hamish Racing General TR UK SPRINT RACE in my TR3a Triumph 5
Z For Sale 1956 Austin Healey 100-4 race car for sale Austin Healey Classifieds 1
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
aero3113 Unique Nasty Boy Race Car On BAT Austin Healey 1
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
tr6nitjulius Great Race 2019 Official Start 6/22/19 pics Other Cars 2
H Lotus Super 7 series 2 Race car for sale Lotus 0
tr6nitjulius Great Race 2016 Riverside, Ca Other Cars 8
MadMarx Wedge Race footage Triumph 0
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Bob Claffie Race car Austin Healey 2
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
jfslenes May 5 & 6, 2018 Road Race, HPDE, and HPDSchool in Albuquerque, NM Racing 1
R Wanted WTB Spitfire race/auto cross car Triumph Classifieds 1
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
C For Sale TR7/8 Group 44 tribute race car for sale Triumph Classifieds 6
69MGC BMW 3.0 Le Mans Race Car Other Cars 0
K TR3A Air vent under grille on Race Cars? Racing 5
Elva164 Trailer space/race support available for Sebring! Racing 0
Elva164 For Sale 1965 Ginetta G4 Vintage Race Car For Sale! Other British Classifieds 7
Steve P. Formula Mazda open wheel race car Racing 0
B Wheel Bearing Race Installation Austin Healey 7
Elva164 A New Race Video and a Request! Racing 3
Elva164 Race video with commentary; good or not good? Racing 7
K Kastner "F" race cam. Racing 3
K TR2/3/3A Kastner "F" race cam again.... Triumph 3
dougie The Hawk 2015 Group 2 Feature Race Rod America Racing 0
aeronca65t Cadwell Park Historic Race Racing 4
aeronca65t General TR Kas Kastner Race - Summit Point Triumph 0
aeronca65t A35 Race Mallory Park-UK-2015 Racing 7
Sherlock Spokane Race Track, has anyone been there? Racing 3
AUSMHLY 1957 healey in race footage Austin Healey 2
M TR2/3/3A TR3 vintage race car on ebay Triumph 5
B Marlboro race track Austin Healey 8
C Daytona 24 Hour race winning Jaguar for sale? Jaguar 0
aeronca65t Popular Race Cars at Watkins Glen Other Cars 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
3798j TR2/3/3A TR at Spa Race Track Museum Triumph 4
C Preparing an MGB to Race in Britain's "ecurie GTS" Series? Racing 2
