TR2/3/3A Finally painted the 63 3b
mctriumph
Yesterday was the big day ! trailered the car down to my old shop and got it into the booth.
Robbins egg blue.Or at least the modern facsimile of it in modern paints. Will bring it home today
and get some pics to post up.
Mad dog
mctriumph
mctriumph
Boot, bonnet , and spare cover were off as well as the scuttle cover. Naturelly a large fly
landed on the hood before the last coat could flash off.So some sanding and buffing is
necessary.That is why painters drink........
Mad dog
mezy
Mad dog
When that happens to me i will get some one inch masking tape rolled sticky side out and fetch the dirty little begger off with that, normally only leaves a few footprints.
moths are the worse, had a huge one land in the bonnet, by the time i had sprayed down the one side he had walked a foot accross the bonnet trying to find his way off.
TR3-Stu
Mark,
The paint job looks great. Like the color. Quick question - how to you insert fender beads at tis point?
mctriumph
mctriumph
The car in the back ground is a 61 Morgan with the Le Mans style spare cover(hand made).
The wings are bolted,but not tightened .After polishing, the panels are taped and the beads
inserted carefully, before final fitting/tightening.
Mad dog
mctriumph
mctriumph
It is the modern base clear version of the OE color( or at least as my eye could
judge it) The human eye can detect differences in lighter colors more easily than
dark colors. So white is the ultimate test, In my 55years I have never seen an actual
pure white car. 100% of all whites that are used on cars are some pastel of white.
having a few drops of black, or blue ,or red or yellow or all of them.Each of the mixing
colors will have 5 or 6 shades/hews.
The paint is a Sikkens line that I have used for many years with great results.
Mad dog
Rick_Thompson
Love the color, but I'm biased!
It took over two years to get the paint right on this one. Three different painters. If I knew that I would encounter all of that I would have done it myself, since I put a HarborFreight portable garage in my big workshop and used it to paint the frame and various bits. Once done, I stripped and sanded the engine compartment and sprayed it again to get it right....
TR3-Stu
Mad dog
Mad Dog
I assume you also install the stone shields at this point. Do you have any hints on how to install the shields without damaging the new paint?
TR3 Stu
mctriumph
mctriumph
Yes I do. painters tape to protect the finish. Multiple test fittings and filing the
contours of the poorly done edges until the fit is just so.The bolt holes are also
wrong and must be modified. Two hours later take off the tape ,have a cold one!
Mark
TR3-Stu
Mark
Or two!
B Finally - BJ7 painted Austin Healey 3
J TR2/3/3A Picture of painted substructure, finally! Triumph 8
drooartz MGB Finally some progress -- floors painted MG 4
UmmYeahOk GT6 Finally Got My GT6 Painted!!! Triumph 12
H TR2/3/3A TR3A Is Finally painted Triumph 10
B Finally Painted! Restoration & Tools 8
TR6oldtimer Engine Compartment finally painted. Triumph 22
zimmy PAINTED!.....................finally ;] Spridgets 2
J TR2/3/3A TR3A Finally on the Road! Triumph 6
AngliaGT Finally - A (Mostly) True craigslist Ad Other Cars 0
Grantura_MKI Pre-War Finally arrived. MG 7
J Finally getting (re) started on the Bugeye Spridgets 27
HealeyPassion Finally, paint on chassis Austin Healey 17
Lou E Finally a Bugeye of my very own Spridgets 41
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
Bayless A Sprite gets some paint finally Spridgets 2
EricJNewman MGB Weird Brake issue finally solved. MG 1
Rob Glasgow Finally Found It (Original License Plate Number) Austin Healey 3
J Shroud Painting ["Finally done with these"] Austin Healey 3
Rhodyspit75 Finally on the road Spridgets 7
AngliaGT MGB FINALLY Got the Engine Out MG 5
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
Tr3aguy TR2/3/3A Tr3 frame work finally Triumph 93
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Basil I finally joined Jaguar 4
J General TR Finally on the road Triumph 1
Bayless More Sprite progress finally Spridgets 23
SherpaPilot TR6 Stromberg War, Finally Success Triumph 2
Bayless Progress finally begins Spridgets 5
tinman58 General TR Finally almost Triumph 7
J TR2/3/3A Finally getting started Triumph 20
Elva164 Finally did another onboard video! Racing 4
J It is driveable! Finally. Morris 8 Other British Cars 8
M Finally Joining the Bugeye club! Spridgets 20
simon1966 Rain cleared up so finally got out. Austin Healey 31
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
B The Prince of Darkness on the dash board finally conquered Austin Healey 10
vickxxx T-Series Finally MG 3
Sarastro TR4/4A My TR4A finally arrived! Triumph 11
B Scuttle shake finally sorted Austin Healey 23
Jer when something doesnt make sense... and you finally figure out why ! Spridgets 4
Basil Back to the EType finally Jaguar 5
Marvin Gruber Three rebuilt BJ8 engine- FINALLY! Austin Healey 17
J TR2/3/3A Finally started 17 year old rebuilt motor! Triumph 3
drooartz Finally found one Spridgets 8
L Are 100's finally eclipsing the 6 cylinder cars Austin Healey 6
trrdster2000 GT6 Finally got a photo of some of our work on the Spit 6 Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
Steve P. Finally found a RWA Midget Spridgets 1
CJD TR2/3/3A TR4 Gearbox in the TR3...Finally! Triumph 3
