TR6 Extra digit in title
pdplot
When I bought my TR6 about 17 years ago, the title had an extra digit in the VIN number. Since only 94K TR6's were built, the extra digit makes no sense. The commission number plate in the car is correct. Knowing the mind of the DMV, when and if I sell this car, should I continue the incorrect number or make the correction? What would you all do?
cheseroo
I had that problem with the TR8 here in CA. A trip to the DMV so they could re-verify the commission/VIN plate on the car was all it took. All the while though I had this fear that they would decide the one on the car was bad and they would rip it out and issue their own VIN plate to replace it. I've seen a few CA state VIN plates over the years so I'm always wary of some overzealous bureaucrat. Same deal when you go to register a car with the old CA black plates on it. You hand them your paperwork and before you know it they have zapped your old plates from the system and issued you new white ones. From that point forward it's an uphill battle to get your old plates registered to the car.
Don Elliott
When I bought my 1958 TR3A brand new in May 1958 The Comm. No. (VIN) was preceded by an 8. When it left the factory, the number was TS 27489 LO but when I took delivery of the TR, the number had been altered with the addition of a pre-fix numeral "8" so my TR was registered as 8 TS 27489 LO. The Canadian customs required the 8 be stamped on the VIN plate because back then, people would try to sell, say a 1953 VW as a 1957. So the requirement of the additional digit. My friend Barry has a 1960 TR3A and the pre-fix digit is "0" indicating that his is a 1960. Maybe your TR6 was imported into Canada originally.
RedTR3
On my CA registration, the "LO" has always been listed as "L0". This must have happened many years ago when the car was brought to California. I decided to just leave it as-is rather than mess with the DMV. Of course this would not work for a modern car where the VIN numbers are in a database.
sammyb
It really depends on the state and the management of the specific DMV/DoL office. In the past, I've had issues with wrong VINs or wrong dates on the title. (My late '76 Ferrari is titled as a '75.) This head county office usually says "you need a State Patrol inspection to change the title." I believe that one time I bought a car and the previous title from out of state had the wrong VIN and they changed it when I titled it in my name.
In any event, it's not a big deal in any way shape or form to have a wrong date/VIN digit if it is evident that it was uncaught human error.
TR3driver
Great Pumpkin - R.I.P
Same here, except in my case the number on the paperwork bore almost no resemblance to the number on the car. When I reported the problem to the DMV, they had me fill out a form and bring the car to be inspected. ISTR they gave me my choice of a DMV or state police inspector, I chose the DMV. A month or so later, I had the new paperwork by mail, showing the number that was on the car.
My opinion, it would be better to address the problem now, and not take a chance on it cropping up later (like when you try to sell the car). They keep passing new rules all the time on what it takes to transfer a title.
P
pdplot
Thanks for the input. As an old-time lawyer, I'm leery of the DMV - besides, they closed almost all their branches and you have to "take a number" in the Norwalk, CT office. Maybe a 2-hour wait. I guess I'll have to bite the bullet at some time, take a picture of my commission plate and hope for the best.
mgedit
I too went through similar thing with my TR3. The actual VIN on car and on ownership were quite different, although I had a complete paper trail and Heritage Certificate as documentation. In my case (I'm in Ontario, Canada), I talked to a friend who is a cop to get his input. His quite correct advise was tell the truth, but like you I was very leery of the hoops I might have to go through. What I ended up doing was getting a letter from a certified used vehicle dealer, certifying that he had inspected the vehicle and that the VIN matched the one on Heritage Certificate. With that I went to motor vehicle guys and presented my case. Took a call to head office, and some head scratching, but they issued new correct ownership papers. The key was to have as much documentation as possible. In my case, the Heritage Certificate was the clincher. One thing that was not changed was the colour, but the agent I was speaking to told me not to push my luck that day and just come back to change the colour when I got the car on the road. Took her advice, said thanks, and left with a smile and considerable relief that the whole process went much better than I had imagined. Hope all works out for you. Cheers, Mike
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
R Extra 948 and 1098 Engines Spridgets 9
D TR2/3/3A extra hole in my water pump? Triumph 3
S TR2/3/3A Tr7 and a little extra Triumph 2
D TR2/3/3A Extra wire in the harness Triumph 7
PC in the movies, an MG-TF [with extra cheese] Spotted 3
M_Pied_Lourd Wedge TR7 Roadkill Extra... Triumph 0
D extra stop/brake light Austin Healey 33
D TR4/4A extra long oil filter attachment stud Triumph 9
T TR4/4A Extra carpet pieces? Triumph 9
Rob Glasgow Extra clip - Austin Healey 5
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
tinman58 TR5/TR250 Extra gaskets Triumph 3
M TR2/3/3A Extra holes in bulhead Triumph 7
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
DNK Got an extra 100 Large? Lotus 3
M 100-4 BN2 Front Fender with extra Groove Austin Healey 2
JPSmit MGB, LBC graveyard & an extra Spotted 10
Banjo TR4/4A AAAAUG! anybody got an extra TR4A piston? Triumph 3
V How much extra engine oil with oil cooler??? Spridgets 5
Number_6 If I had the extra money... Triumph 11
S MGB MGB engine mounts - "extra" plate? MG 2
angelfj1 Anyone have an extra one of these? Triumph 10
G anyone have an extra front side marker lens? Spridgets 8
KVH TR4/4A TR4 Water Pump Extra Vane Triumph 7
tahoe healey extra fuse box Austin Healey 1
R ADDITIONAL FUSING FOR EXTRA PRECAUTION? Austin Healey 15
NardisCNC An Extra Wire... Please Help!! Spridgets 8
S Doc, ya gotta be EXTRA good this X-mas!! Other Cars 11
jlaird Came into a few extra dollars Spridgets 5
E GT6 Do i need to fabricate extra supports for the GT6? Triumph 9
N Maybe a little extra! Triumph 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
regularman Extra cooling idea Spridgets 33
mgb4tim "MG" Key Blanks - I'll have a few extra. MG 4
mgb4tim Wedge TR7 Key Blanks - I'll have a few extra. Triumph 0
B TR2/3/3A adding extra horsepower to your TR3 Triumph 5
tony barnhill T-Series Extra MG TD Parts MG 26
tony barnhill T-Series Extra TD Stuff MG 16
jlaird Extra! Extra! Extra!! Spridgets 0
tahoe healey Extra rear light. Austin Healey 8
jlaird If you have an extra 25 min Spridgets 0
DNK SOMEBODY HAVE EXTRA TIME IN THE MIDWEST??? Triumph 4
regularman A place for extra fuse holders. Spridgets 5
P extra brake lights Triumph 10
Gray_Cat The 2 1/2" Of Extra Leg room in A Bugeye. Spridgets 2
S Oil change in Gearbox & overdrive - extra parts ? Austin Healey 4
T Extra Wires? Triumph 11
G Lotus super seven 1964 Extra car to buy Lotus 1
jlaird Todays extra credit question is... Spridgets 1
