excess wear on outer edge of front tires
Goldie
Car was restored about 6 years ago. About 5K miles since. Too much wear on front outer edges. Is this likely too much + camber or could it be toe in. Rears are wearing okay. How can camber be adjusted? Two types of mod's available that I found: 1. remove top shock plate and reweld an adjustment plate, or 2. cut slit in shock tower below top plate, remove welded nuts, and install a slider plate. 1967 BJ8
Keoke
Car was restored about 6 years ago. About 5K miles since. Too much wear on front tyres at outer edges. Is this likely too much + camber.
Sounds like it to me.
But check the toe in too it could be off causing the tyres to scuff.--Fwiw--Keoke
Legal Bill
Goldie,
You can get adjustable bushings that replace the rubber bushings in the shocks where they connect to the upright. The adjustable bushings are off-set. You can get about two degrees of negative camber with them. It is about a million times easier and less expensive than the two methods you mentioned.
red57
I suggest taking it to a tire store/suspension shop and ask them to simply check and document settings & set tow (explain that to them that nothing is adjustable but toe) then you know where you are and what you need to do. In my area it isn't really too expensive and then you really know.
Obviously make sure they can deal with low ground clearance getting on/off the test bed - I've had best luck with places that have a pit and you drive straight & level onto the rig.
If it turns out your camber is off, I agree with Legal Bill, the off-set bushings are definately the way to go unless the frame is way off.
Dave
wheelguy
Have your toe in set as close to 0 as possible. Plus or minus a 1/16. That is the best setting for toe in.
Wheelguy
If I remember correctly, this took my car from about one degree positive (1*+) to about one and one half degree negative (1-1/2*-).
I still have never gotten an explanation (even from vintage racers running Bugattis) of the logic of running postive camber; anyone here know?
My father--who was an auto shop teacher and factory rep for Ford--explains it thusly:
If you place an ice cream cone on its side and roll it, it will turn towards the small end of the cone. Camber--if you imagine the tilt of the wheel forming a cone with an extended axle line as its center--causes the tires to want to turn as well, to the outside in the case of positive camber. That causes the two front tires to try to turn away from the car as you drive, restrained, of course, by the steering rods. This takes up slop in--and generally tightens--the steering which is compensated for by a bit of toe-in. I suspect--but don't know for sure--that modern rack-and-pinion steering requires less as it inherently has less slop than gear-type steering mechanisms.
Also, camber goes increasingly negative with body roll, which increases the tire patch and grip and helps turn the car. Negative initial camber gives better 'turn in;' good for racing but making steering a bit too squirrely for most everyday drivers. A little positive camber probably gives a little understeer, which is considered a good thing for average (i.e. bad) drivers.
Ed_K
Hello Goldie,
Welcome to the forum.
Look at all of the advice you got already.
There are some very Healey knowledgeable folks on this forum.
Ed
:cheers:
Bill: I made those; they were early <span style="font-style: italic">getting to know and understand my lathe & milling machine</span> projects.
They are commercially available now though: https://www.bighealey.co.uk/content/offset-trunion-bush-set
These would be a little harder to set, without the hex and being two (2) piece, than mine are (even though I had to mill a 1-1/16" open-end wrench thin enough to fit in the gap).
Bob: thanks, that's the best explanation I've heard yet. The ice-cream cone certainly puts a different spin on it.
G
Goldie
Thanks for the advice. I just received two new tires for the front and will have them mounted. Then will have shop check toe-in ASAP. Weather here is not so great right now. I already have the off-set bushings but only installed on left front so far. I will add the second one next. I have been expanding my garage to 3 bays since July and just finished so I have put off car work for about 4 months. If off-sets don't work, I am trying to decide what next. I have heard toe-in should be zero to about neg 1/16" so at least I know where that needs to be. Also heard +1 to zero on the camber is good for these cars.
How old are the tires? If you can see the wear after only 5K you may have a serious problem. If the tires are much older the re-builder may have fixed the problem but left the tires. I'd get a tire store to check the alignment out as suggested above.
TH
Legal Bill
Thanks Randy. That's what i thought.
Goldie, did you put in the bushings before or after you noticed the tire wear? If it were my car, I'd try .5 to 1 degree of negative camber.
G
Goldie
added the offset after I noticed the tire wear. Car has been parked in storage while I was redoing my garage so it wasn't being driven. Garage is now done. Now time to fix it. Just got 2 new tires for the front. rears are wearing okay. left front is worst wear than right front. Both wearing to the outside. the outer half shows the wear.
T ZS throttle shaft - how to determine excess wear Triumph 15
DrEntropy Selling off the excess. Other Cars 3
C Excess oil consumption MG 39
K Half-shaft wear? Spridgets 3
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
P MGB Tube axle wear MG 3
AUSMHLY BJ8 Laygear Wear Austin Healey 11
A T-Series Arkansas MG Odd Lifter Wear MG 12
M TR2/3/3A Steering Worm Gear Wear Evaluation Triumph 6
J TR2/3/3A Oil Pump Wear Triumph 5
K TR2/3/3A Ring and Pinion Wear? Triumph 11
T TR2/3/3A Propeller Shaft Spline Wear Triumph 3
KVH TR4/4A Clutch Pressure Plate Wear Triumph 1
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
S TR2/3/3A Front end alignment and tire wear Triumph 9
C TR4/4A Diff gear wear Triumph 10
M First Gear Wear Austin Healey 4
RAC68 Axle Bearing Wear and Imbalanced Drums Austin Healey 3
TRclassic3 TR2/3/3A Extreme tire wear Triumph 6
RickB Front tire wear - insides Spridgets 14
T Timing Chain Wear? Austin Healey 5
K TR4/4A How to check TR3/4A Trans for wear? Triumph 3
glemon Opinion/Experence Rocker Shaft Wear Triumph 6
D Rear Tire Wear Austin Healey 13
glemon Valve Adjustment/Wear Triumph 4
M Wear a helmet Triumph 49
Darrell_Walker Timing chain tensioner wear Triumph 8
T This is why you wear protection Spridgets 11
T This is why you wear protection..... Triumph 14
TimK Uneven wear on Healey front disk brake pads Austin Healey 2
T very early gear wear Triumph 8
PatGalvin Assessing wear on engine parts Triumph 4
D SU questions - wear and needle interchange Restoration & Tools 6
T TR4/4A ? on TR4A clutch shaft - wear @ push-rod attachment Triumph 6
T Checking for front suspension wear Spridgets 4
I TR6 TR6 - uneven tire wear in rear tires Triumph 1
jhorton3 Inner Tire Wear Spridgets 4
Baz Ring gear wear.... Spridgets 4
jcatnite Tire Wear Spridgets 4
2wrench Let's talk about the dreaded thrust washer wear. Triumph 8
S Front Brake Hose Wear Austin Healey 9
G Is this acceptable wear....fork pins Triumph 9
fmichaels wear tear tranny repair Spridgets 13
philman tire wear question Triumph 17
SilentUnicorn Tire wear Diagnosis Spridgets 7
D Oil Pump Spindle wear MG 10
D xjs v12 tire wear Jaguar 1
O tyre wear Triumph 3
Z Camshaft wear and other ramblings Triumph 4
T Wear eye protection!!!! Triumph 14
