Electronic Ignitions
GB1
any intput on electronic ignitions on a positive ground vehicle.
looking for some very reliabe and not to obtrusive.
thanks /ubbthreads/images/graemlins/driving.gif
Presumably you're looking for one to fit a Spridget with a 23D4 or 25D4 Lucas distributor since you still have positive ground. Pertronix does make a positive ground model for those distributors. I know Mini Mania sells it but you will probably get a better price from Retro Rockets (online). Since you're looking for positive ground, reliable, and unobtrusive, Pertronix is probably your best bet.
EDIT:
LU142/POS $99.95 @ minimania.com
LU-142AP12 $81.55 (25D4) & LU-148P12 $93.70 (23D4) @
https://www.vintageperformance.com/retrorockets/mg.htm
I don't know why they show two different ones for the 23D4 and 25D4... they shouldn't be different.
A word of warning to the electronic ignition buffs. Do not use a high voltage coil. 20 to 30 thousand volts is all you need. If you use a high volt coil you will blow an arc through the rotor to ground on the distrubutor shaft unless you use a high quality high clay content rotor.(even that is no guarantee.
The stock units were designed for stock stuff.
When this happens it usually takes out the pertronix unit too. The signs that this has happened is the car will miss-fire and spudder about. You can look inside the rotor where it fits over the distributor shaft and see a little melted spot in the bottom corner somewhere. Look close it will look like a little bubble of melted plastic.
I see it all the time at the races. Carry a spare pertronix unit.
Wow Jolly thanks, I had always heard that you needed a hot coil if you swapped over to the pertronix. Good advice man. Stick with the stock coil...12v or 6v? any preference???
JC
Rivergate Restorations added a Crane Fire Ball electronic ignition system when they rebuilt my 1275, and I then went out and bought the Crane Fire Ball coil (the one in the Moss catalog)...
I have yet to install the engine...but is this the wrong set up jollyroger?
Thanks.
Jolly:
Is a Lucas Sport Coil to powerful?
Thanks.
I doubt the Sports Coil is too much. However, start with a standard coil and replace it later if you want to. Don't change too many things at once.
I currently run a Hitachi distributor in my 1275 and I carry a spare ignition module just in case. When I ran the Lucas dizzy with Pertronix I carried a new set of points and a condenser with me... also just in case. You don't have to have a second Pertronix unit, just carry the old standard parts for backup. It's such an easy swap you can replace the parts by the side of the road IF it's necessary.
Anyone have a link for this item?
I see a number of guys using the sports coil. I guess they are ok. I don't know the output. As far as the crane stuff, make sure you use a good rotor. Maybe one of those bosch units.
Most fancy coil guys don't want ya ta know you don't need a zillion volts. If anything a longer spark is much more important than massive voltage.
I second that. If it jumps the air gap of the plug reliably, it's about as good as it gets.
Thanks all!
I will carry the original as a spare.
Anyone try running the second strikes ignition?
thought about it in my Mini when the warranty expired. Not in my BE
txs.
Nunyas Electronic Ignitions - to dual or not to dual... MG 3
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
TRickster6 MGB electronic ignition on '73 MGB MG 1
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Basil Electronic Clutch [Deleted] Other British Cars 9
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
Lin Installation Notes for 1-2-3 Electronic Ignition Austin Healey 1
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
O Sprite Petronix Electronic Ignition Spridgets 10
S General Tech Electronic store for quality connectors. Triumph 9
S Fried electronic ignition? Austin Healey 22
F TR2/3/3A Timing with Electronic Ignition Triumph 14
B Crane Cams Electronic Ingnition Austin Healey 9
S Wiring connections for electronic ignition BJ8? Austin Healey 3
T MGB Vacuum advance and Electronic ignition conversion MG 5
rjc157 bn7 electronic choke Austin Healey 0
matmire Crane XR700 electronic ignition, now FAST XR700. Spridgets 12
S TR2/3/3A Tr3/4 electronic distributor Triumph 2
Marvin Gruber TR5/TR250 Pertronix vs Crane electronic ign Triumph 1
T TR2/3/3A electronic distributor problem Triumph 3
B Question about Dual Polarity Electronic Fuel Pump - How to Connect Wiring? Austin Healey 9
F Swapping out original 1098 distributor to electronic Spridgets 13
L Electronic ignition? British Motor Corp 4
S TR4/4A Electronic Ignition Recommendations? Triumph 14
PAUL161 General MG Crane Electronic Ignition MG 9
S will old style distributer cap work with electronic ignition on AH Austin Healey 8
Keith_M SU Electronic Fuel Pump Spridgets 3
DanLewis Electronic tachometer for Bugeye Spridgets 18
R Electronic Ignition Distributor Spridgets 14
JPSmit Electronic Rust Inhibitors: works? - or snake oil? Restoration & Tools 8
D Electronic Ignition for 25D distributors Spridgets 15
D Timing with an electronic distributor? Triumph 14
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Scotsman Pertronix Flame Thrower Electronic Distributor Triumph 7
bighealeysource LED bulbs and electronic flasher module issues Austin Healey 26
M Fuel Flow problem with new Electronic SU Pump Austin Healey 2
drambuie Anyone using flame thrower Electronic distributor Austin Healey 6
sundown TR6 TR6 electronic ignition Triumph 10
mountainman pertronix electronic ignition hepl please Triumph 10
D TR6 TR6 Electronic Ignition Triumph 16
PATR8 Wedge More TR 8 electronic questions Triumph 2
T Electronic Ignition Issue Austin Healey 6
wkilleffer Anyone familiar with GM Electronic Climate Control Other Cars 11
A Pertronics vs Electronic Distributor Triumph 23
D Installing Electronic Distributor Austin Healey 8
Tim_Creger need help with electronic distributor MG 7
drooartz Cheap electronic tach for bugeye? Spridgets 9
