Eastwood Aluma Blast Paint
tdskip
Just tried this on my TR4A IRS trailing arms and it is nice stuff - not to dull, not too bright. Looks very much like clean aluminum.
Debating on clear coasting it - probably will but don't want it to end up too shiny. Anyone have their experience to share on this?
Thanks!
Put some satin clear on it.
I've been using it for years. Clearing it on trailing arms would probably be ok. I wouldn't clear wheels, valve cover, etc..
It is nice paint.
Kind of a crappy picture (Blackberry), but here you go Don.
One trick to is to apply lots of misting coats rather than fewer heavier. Fast draw of the spray across the surface with low paint volume in any given spot is the way to go.
As long as you have those trailing arms off you might consider using keenserts on those studs... just my 2 cents :thumbsup:
Tom, did mine with the Eastwood Diamond Clear coat and didn`t find them too shiny. They won`t be after a few miles anyway.....
Cheers,
Tush
D Eastwood Surface conditioning tool Restoration & Tools 18
steveg Soaking in vinegar vs Eastwood Zinc paint Austin Healey 12
tomshobby A nice surprise from Eastwood Company Restoration & Tools 2
B Eastwood leadwork DVD Restoration & Tools 2
Don_R POR-15 vs Eastwood Encapsulator Triumph 19
KiKi Eastwood Body Solder Restoration & Tools 5
T Eastwood forum - waste of time Triumph 25
TR4 ZDDP Additive from Eastwood Triumph 41
Basil Eastwood DVD Set Restoration & Tools 2
J Eastwood alumablast paint Triumph 2
angelfj1 EASTWOOD - Electroplating System Tin Zinc Triumph 8
A RUST: Eastwood, POR15, KBS or ??? Austin Healey 8
Lin Garage Lifts [was "Eastwood Midrise lift"] Austin Healey 14
S Anybody tried Eastwood's Tin Zinc Electroplating? MG 4
DrEntropy Blast from th' past Racing 3
KVH Blast Cabinet Restoration & Tools 2
KVH Any Advice on HF Blast Cabinet? Restoration & Tools 5
Michael Oritt Blast from the past--Dave Russell Austin Healey 9
M TR6 Video of My TR6 after Media Blast Triumph 3
L Replacing blast media Restoration & Tools 10
P BLAST MEDIA? Spridgets 6
DrEntropy Blast-n-dam... Other Cars 19
Lin Blast cabinets Austin Healey 8
T Got the blast cabinet set up, but not stripping Triumph 13
B Sand Blast vs. Soda blast? Spridgets 13
jlaird Today I bought a Blast Cabnet Spridgets 4
Mickey Richaud Now THIS Would Be a Blast! Other British Cars 6
GT6_Mark Grit Blast Stombergs Triumph 12
Rob Glasgow Dip or Sand Blast? Austin Healey 15
AngliaGT Bead Blast Aluminium? Restoration & Tools 3
AH100M Blast Cabinets Austin Healey 6
E Bugeye Body Blast Spridgets 24
fmichaels blast furnace repaired Spridgets 5
D Vanderbilt Concours was a blast!! MG 10
bash What kind of blast media? Restoration & Tools 15
L Removing Carpet Adhesive - Blast Media? Austin Healey 17
1 Soda blast or sand blast? Austin Healey 3
J Paging Basil! Check it out..The cars a blast! Other Cars 6
M Found a great buy on a blast cabinet. Restoration & Tools 9
Basil New Sand Blast cabnet! Restoration & Tools 15
