Dumb Question?
judow
Darth Vader - R.I.P
I was driving my 96 XJS today when all of a sudden the needle on the oil pressure gauge just 'popped'. It registered 2 then it jumped to 6, it was like the needle was confused. It did this several times and if I had to describe what it was doing, I would say it was bouncing. The car didn't change in any way, that is the engine purred, the temperature gauge was on the nose, etc. I checked the oil later on and it was right on the button. I know I'll have to take Onslow to the garage but... Do you think I might get lucky and find it is only a malfunctioning sensor to the gauge or should I be planning on a oil pump???
Thanks for any help you can give me.
Could be an oil filter by-pass or pump by-pass valve or sensor. I presume you change oil pretty regular?
I think it's been about 4-5 months as I don't use Onslow as a daily driver. Indeed I probably only drive him about 3 or 4 times a month. Something tells me rather than go by mileage for an oil change, I should be going by calendar months?
Well, well. It was the sending unit. $252.81 later and Onslow is well again. Then onto the petrol station and he lunched for a total of $45.34 and his tummy is now full. For future, I think I'll just take hubby to lunch - he's cheaper.
Glad you got it done. Yes, you should do the oil by months now since it sits longer than most. Remember to do the trans by mileage. Also, since it sits for long periods make sure you have the brake fluid renewed every 2 years to keep system in shape.( Gets the moisture and contaminants out.)
Thanks for the good information. I will be more attentive in the future. While I do monitor Agatha (Healey 100-M)as she is a much older vehicle, I think I've been remiss with Onslow because I still consider him 'new.'
AngliaGT MGB Dumb Question - What's This Part? MG 3
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
tahoe healey Dumb carb question Austin Healey 23
Darwin Spitfire Dumb Question Triumph 2
M MGB trying to change rotors - dumb question MG 7
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
NutmegCT Dumb bolt question Restoration & Tools 7
D TR6 Dumb question Triumph 2
D TR2/3/3A Dumb question Triumph 3
D Dumb question Triumph 5
60TR3A Dumb Newbie Question Austin Healey 16
E another dumb electrical question Austin Healey 8
Jim_Newman dumb little electrical question Austin Healey 3
richberman Dumb SU fuel pump question? Austin Healey 9
M Dumb Dumb Question about Drum Brakes [pics] Triumph 10
NutmegCT dumb antifreeze question Restoration & Tools 4
Sarastro Quick dumb transmission question Spridgets 9
Tugboat Dumb Question re: Battery Triumph 15
T TR4/4A 62 TR4, new owner, [dumb ]question about cyl head Triumph 15
C This might be a dumb question but.... Spridgets 15
M A Dumb, but Necessary, Question Spridgets 11
Yngbld14 Dumb Question MG 0
Yngbld14 Dumb Question Spridgets 2
StupidHippie Really dumb diff mount question? Triumph 12
2wrench Dumb question I gotta ask Triumph 2
jlaird Dumb question Spridgets 2
tony barnhill Dumb Late Night Question Spridgets 8
G So here's a dumb question Triumph 20
M T-Series Dumb MG TD badge bar fitment question MG 4
B Manifold fitment dumb question Spridgets 4
timbn2 Possibly a dumb question... Austin Healey 4
Lukeee Dumb Question? Spridgets 14
Branson maybe a dumb question but....what are these? Spridgets 38
Jack_Long Dumb question about headlight switches Spridgets 7
B MGB Dumb question on '64 MGB MG 2
W Hungry electical gremlins and dumb question Triumph 1
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
jlaird Question, dumb one for the day Spridgets 10
jlaird Question really dumb maybe Spridgets 7
G Dumb question about electrics Triumph 22
A Dumb tire pressure question MG 9
jlaird Dumb question maybe Spridgets 2
tony barnhill Triple-Carb Interchanges [was "Dumb Question"] Austin Healey 2
G Dumb carb question Triumph 15
jlaird Todays dumb question Spridgets 2
jlaird Tony, dumb question MG 7
jlaird Another strange but not dumb question Spridgets 1
jlaird Dumb question for the day Spridgets 3
G Dumb question #74 Triumph 8
