Door Skin Help Please
fad64b
I need the opinions of anyone with door skin replacement experience. My dilemma is that I have a British Heritage door skin ordered with TRF that has been on back order for two months and is holding up my body work. I emailed Moss motors to ask them about there door skins and received this response..
This part is supplied to us by Leacy, whose full company name is LEACY MG SPECIALISTS. They are well known in the British parts supply network, and send us parts that compare to Heritage in quality. You can buy their parts with confidence.
My question has anyone had experience with these parts or should I wait for the British Heritage part?
Hi mate,
TRF is a good supplier, but concentrating on Triumph
I would contact the little British Car Company https://www.LBCarCo.com they respond very quick and you can talk to knowledgeable people there. Door skins need be of first quality. And while you are there, check with a pro body shop to have them tack inside a reinforcement where the «crack of doom» usually develops as time goes by. I would also look into just pasting on a piece of PowerMesh painted over with Por15 paint; check the webside at www.por15.com
All POR15 products are <ultimate class» for ease of use and filling their promises, they are one of the trade secrets. However, special precautions need to be followed, the fumes can be toxic if the area is not well ventilated, I mean as ventilated as outdoors.
Remember the fit and finish of an MG door tells a lot about the state of the car and the least missfit will induce water leaks with known consequences.
You could also check with a Canadian supplier www.obsoleteauto.com
One last tip, spray the inside of both door panels (skin and interior panel) with GALVICON (zinc paint), you may find this at NAPA or from companies who produce or install metal fencing. This is like galvanizing the inside of your doors.
Good luck and keep the faith.
GreenBtanner.
BoyRacer Door Skin Removal Austin Healey 6
J TR2/3/3A Door Skin Reusable? Triumph 11
red57 Door skin patch panel question Austin Healey 11
beaulieu POR 15 between door skin + door shell expanding Restoration & Tools 6
Jim_Gruber Door Fitting - A-Pillar Skin - Success Spridgets 5
2wrench What tools best suit interior door skin replace? Triumph 8
KLUTZ Door skin questions MG 7
pan Door Shut Face Panels Austin Healey 0
D Door Lock Tumbler Austin Healey 4
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
E 3000 Healey Door Checks Austin Healey 1
A MGB MGB a glove box door MG 10
chicken BJ7 Door Fit Austin Healey 27
Patrick67BJ8 Glazing Door Window Glass in BJ8 Austin Healey 15
F Door Panel Hardware Austin Healey 3
LAW75 Door Latch Adjustment Austin Healey 22
BoyRacer Door Panel Measurements Austin Healey 3
LAW75 BJ8 Door Locks Austin Healey 2
Cappy Occasional Door Malfunction Austin Healey 1
nichola TR6 Door handle and window crank installation Triumph 0
J Door Draught Metal Clips Austin Healey 4
F Interior Door Handle Removal Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
M Spitfire 1500 LH Door Triumph Classifieds 0
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
