Do it yourself interior panels question
Thor
I wanted to change the interior of my midget from black to beige. I have done the seats but my question is: "Does anyone have suggestions on how best to redo the panels?". I don't have the cash to order "new beige panels".
What I attempted but think I need help on is that I order Beige material for the panels and then cut out the pattern so there is about 1/4 to 1/3 inches to fold around the panel edge onto its back. Next I used spray adhesive to an existing panel, I think it was called M3 adhesive spray. But after a fashion I have noticed that the new material puckers some and has pulled away from the back and edges so the original black shows.
Should I have extended the lip of the new material even further on the panels back? Anyone have suggestions on a different spray adhesive? Thanks
I haven't tried it but was considering it. I found a book the library called (I think) Automotive Upholstery Handbook by Don Taylor that seemed like it would be very helpful FWIW
I would use proper contact cement.
Of course, contact cement. Works great.
Thor -
I just did this. I did NOT use contact cement / glue / etc as many have commented. I felt (& you found out the hard way) that the glue is unforgiving and doesn't stretch.
I cut new panels from a fresh compressed fibre board from home depot ($10 each or so) (x2). Bought the appropriate fabric (got extra from where I had my seats done (ended up getting 6 yds - have 2 or 3 left over / lots in case I messed up). I sanded the freshly cut edges so they do wear through the fabric over time.
I purchased a 22 gauge ulpholstery staple gun from ebay ($60 or so). Use the Unicatch 22 gauge air stapler
https://cgi.ebay.com/1-4-To-5-8-Upholster...1QQcmdZViewItem
It uses "stock" staples (not necessiarily home depot, but a roofing supply house). It can use "Senco "C" from 3/16 to 5/8 (Unicatch makes to 1/4 - used another brand to get to 3/16").
With the air stapler - it provides the power to go through new / thick fibre board. 3/16" is very shallow (smaller than an office stapler) and allows for you to stretch the fabric without fighting the bonding effect of glue. If you mees up - you remove the staple and re-fit the fabric.
I am very happy with this. I still have never been able to post pictures on BCF - send an email and I can send over to you. Am installing over the next few evenings since I finally got the car back from the paint shop. I also wnet with a tan / camel color (naugahyde; "pleather"). Looks awesome with the maroon paint job !!
It's very easy !! Just time consuming, but if you owned the car for more than 20 minutes - this is not news to you.
Sincerely,
George Zeck
gzeck2 at yahoo dot com
I've done a number of interior panels- from leather with foam backing to indoor outdoor carpeting (like my old truck). As far as glue, I would use nothing less than 3M Super 77 or 3M Hi-Strength 90. I've messed around with too many cheap spray glues and hot glue guns and finally learned that using a quality spray adhesive glue across a panel yields a uniform look- in other words the material bonds to the panel in all areas with no lift. Hot gluing often showed. The stuff is not cheap, but you have committed to going through the trouble to do this, spend the extra money and do it right. Afterall that's what you want, right? The ultimate insult to personal craftsmanship is when you say "yeah, I did it myself," is when you get the reply: "it looks like it."
I usually let the glue set up until it is sticky and then smooth the material over the panel. It also helps if you do this at a decent temperature (70 degrees or warmer). I did some panels in a cold garage once and it never set up.
I usually leave enough material to get around the panel anywhere from a 1/4 to a half inch. It depends largely on the material. I've gotten away with not stapling (3M hi-strength 90 is good enough that you don't have to if you follow the instructions and let it set up)but I have done a number of panels using a basic paper stapler- just open the stapler up, lay the front side of the panel against something hard, press the stapler against it and shoot. Carpet staples are way too thick for interior panels- you dont want them coming through the fabric. Look at the factory staples and you will see that they are basically the same as a paper staple.
On my MG, the door panel thickness is pretty crucial. The original fabric was glued on with a very thin piece of foam behind it and the fabric was stapled around the edges. I tried to use a thicker fabric and ran into problems because the door weatherstripping interfered with the door shutting correctly (even despite trimming the panel down 1/8th's of an inch all around to accomodate the thicker fabric). In this case its best to duplicate the original in fabric thickness.
B Do It Yourself Paint job Triumph 67
J Pacing yourself. Triumph 11
bighly Spare parts stowage - do it yourself hide-away Austin Healey 6
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
KVH General Tech Reinstalling TR4A Interior Triumph 13
Mickey Richaud Wanted Interior Austin Healey Classifieds 2
W TR2/3/3A Interior and Body Colours Triumph 14
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
K 100-6 Interior Austin Healey 4
MGTF1250Dave T-Series Interior Trim Panel installation MG 12
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
H 100-6 Interior Installation Austin Healey 4
nichola TR6 Interior panels Triumph 5
F Interior Door Handle Removal Austin Healey 2
S TR2/3/3A carpet kit and the interior done Triumph 8
B BJ7 Interior Finishing Details Austin Healey 2
rjc157 Wanted 76 interior Triumph Classifieds 1
77MidgetMkIV New top and interior-that escalated quickly! Spridgets 9
C XK120 Interior... and Interiors in General Jaguar 17
B TR4/4A Midnight blue interior Triumph 6
T Interior Door Panel and Top Rail Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
S TR4/4A Vinal interior trim piece eaten by rodent Triumph 3
F Wanted Used leather interior for BT wanted Austin Healey Classifieds 5
R Wanted TR6 Interior Door panels Triumph Classifieds 0
AUSMHLY BJ8 Leather interior - what pieces were leather/vinyl Austin Healey 13
D Interior Finished Austin Healey 3
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
F Bug eye interior Austin Healey 2
D BT7 interior purchase Austin Healey 5
D Prepping Floors Before Installing Interior Restoration & Tools 6
HealeyRick 100 Interior Trim Austin Healey 1
G TR4/4A Interior Install...and other random questions. Triumph 11
D T-Series Trying to find out an interior dimension MG 7
S For Sale Austin Healey 100-4 Carpet Kit and Interior Panel and Trim Kit Austin Healey Classifieds 0
D interior on a budget... Austin Healey 6
R Paint first or interior Austin Healey 10
ckeithjordan TR2/3/3A New Interior Trim Re-Use Triumph 6
G TR4/4A Interior Install Steps Triumph 3
Zitch TR4/4A Tr4 Carpet Install and interior install Triumph 2
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
CessnaTPA New Interior Recommendations Austin Healey 8
D BJ8 Interior Austin Healey 6
