Dashboard?
littlecars
Member
Has anybody out there in cyberland ever recovered a dashboard???
My bugeye dash was red originaly and a previous owner painted the vinyl black. I am doing a restoration and need it to be red like it was made. Any information on type of material to use to cover would be helpful thanks
William
Its just thin, fine grained Vinyde stuck directly to the metal dash panel. I bet that on of the trimmers that advertise in the back of Classic and Sports Car or Classic Motorsports has a stock of similar material.
-William
spritenut
I have recovered many Bugeye dashboards.
The original vinyl was "Vinylide" brand.
But when I redo an interior, I buy enough material to recover all the panels and the dash and seats so everything looks the same. Check with a marine canvas or boat supply, they have thousands of different colors and textures.
Use a flamable type of contact cement, the water based types just don't hold up. Weldwood or Formica brand. 2 coats on the fabric, 1 coat on the metal.
Spray glues will work on the face but use the contact glue on the back overlay.
G
I recovered my Bugeye dash and interior panels last winter. I found an acceptable cloth-backed vinyl at a local fabric store and used it for everything. I found the adhesive needs to be pretty think on this cloth backing to adequately hold. It might be easier to use a non-cloth backed vinyl. I also cut my own press board panels since the old ones were heavily water damaged. I found 1/8" press board at a local Menards (Lowes, etc.). The store had it in various sizes, and I used two 2' X 3' pieces for al the panels. I also lined the panels and dash with 3/16" foam for a plusher look, albeit not original. I am very happy with the results. I used an aerosol 3M adhesive found in the local hardware store to tack the larger flat surfaces down, but used heavy duty contact cement to hold down the edges. Using an ample amount of edge clips is important also. It is important to use the old vinyl as a pattern, unless you know what you're doing cutting patterns.
bugimike
for a non-original, but offering a nice "upgraded look" to the factory dash, a nice sheet of marine-grade veneer of any favorite classic wood (I used mahoganny on my red car)cut and shaped off a paper pattern from the metal dash (veneer can be cut smoothly with a steady hand & an X-acto), a few nice coats of varnish and one has a classic dash!
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
JohnGone MGB Wood Dashboard Kits MG 1
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
L Replacing veneer on wood dashboard Restoration & Tools 14
ckeithjordan TR2/3/3A Dashboard Covering Edge Clips Triumph 13
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
J Attaching new BJ7 Dashboard To Body Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
J BJ& MK ll 3000 Dashboard Austin Healey 2
A For Sale TRIUMPH 74 TR6 Dashboard w/Guages Triumph Classifieds 7
S TR4/4A How to finish dashboard? Triumph 19
Joe_Healey BN2 dashboard silver Austin Healey 0
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
T Dashboard Knob Removal Spridgets 1
A TR6 Lettering on 1971 dashboard Triumph 1
wkilleffer MGB Dashboard pad replacement issues MG 3
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
S Dashboard toggle switches for BJ8 - exact match? Austin Healey 12
K TR4/4A TR4A Dashboard Veneer? Triumph 13
K TR4/4A Veneering A TR4A Dashboard? Triumph 0
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
B Dashboard Warning Lights Austin Healey 8
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
AHS TR2/3/3A Dashboard hole identification Triumph 8
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
R 100-4 dashboard color Austin Healey 1
R 100-4 dashboard removal help Austin Healey 4
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
Grannieannie Somerset dashboard Other British Cars 5
Patrick67BJ8 Additonal Gauge[s] for BJ8 Dashboard Austin Healey 13
Xte Original covering center dashboard and top dash ? Austin Healey 5
R Recovering BT7 dashboard Austin Healey 5
H Healey 100 Dashboard Color Austin Healey 10
Zimmycobra TR4/4A TR4A Dashboard question Triumph 5
af3683 Kienzle Dashboard Clock Triumph 10
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
middie Late model dashboard Spridgets 3
Zimmycobra Dashboard air vent grills Triumph 1
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
