Dashboard toggle switches for BJ8 - exact match?
SteveHall64Healey
The toggle switch for the headlights and running lights on my BJ8 has failed, and I'm looking to replace it.
I had previously purchased one of these switches from Moss when I added Lucas driving lights, but it was not an exact match with those already on the dash. This slight mismatch didn't matter much because I located the switch for the Lucas driving lights below the dash and not adjacent to the existing toggle switches.
Now that I have to replace one that will be adjacent to the original switches, does anyone have recommendation as to where I can get one that would be an exact match?
thanks
steve
RAC68
I agree with Tahoe but suggest you also apply a good amount of dielectric grease in the switch as well. Also, take a look at the paddles used in the switch and realize that your total draw for lighting is passing through them and the wiring that powers them (the reason I suggest the installation of relays).
Good luck,
Ray (64BJ8P1)
GregW
Maybe Holden has switches that are close enough.
Check too to see if the paddle will come off the old switch if rebuilding doesn't work. The main body of most Lucas switches are the same for two and three position switches other than those with a resistor built in. I've gotten new Lucas before and swapped paddles so they look the same, and have the same patina as the others.
Keoke
Good luck,
Ray (64BJ8P1)
No Ray
Dielectric grease is not a good idea here. This is because a Dielectric is designed to prevent electrical conduction between parts. On the other hand, a relay is an excellent suggestion. Regarding a grease to exclude dirt and moisture from the switch innards just use a good high temperature grease..
RAC68
Keoke,
I am aware of what Dielectric grease is and have used it in all connections and switches to protect against moisture and provide lubrication. A dielectric grease is not a conductor and will eliminate any switch cross flashing and spurious sparking. However, the dielectric grease will separate from contacts under pressure to expose a clean good contact (i.e. when pushing a bullet into a receiver or with the flip of a switch). This approach is not something I originated and is commonly used by many others. For my part, I have applied dielectric grease on the electrical contacts of my Healey for the last 20 years and have not experienced any issues. I stand behind my suggestion.
Ray (64BJ8P1)
glemon
I believe it is the same as the period switches for the Sprite/Midget? A toggle switch with a black plastic or maybe bakelite handle? It should not be too hard to find a good used if that is the case.
P.S. there is an NOS used on Ebay now, but not cheap!
Keoke
OH OK:
But since most greases are of a dielectric nature you should do just fine with a plain HI Temperature one.
S
SteveHall64Healey
Thanks Mike - this was the best idea. The new ones have very slightly different dimensions such that swapping paddles did not work. However, I was easily able to move the guts of the new switch into the body of the old one. The appearance of the old one is preserved and it's back in working order.
thanks
steve
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
JohnGone MGB Wood Dashboard Kits MG 1
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
L Replacing veneer on wood dashboard Restoration & Tools 14
ckeithjordan TR2/3/3A Dashboard Covering Edge Clips Triumph 13
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
J Attaching new BJ7 Dashboard To Body Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
K For Sale MG Midget Dashboard with Gauges Spridgets Classified 3
J BJ& MK ll 3000 Dashboard Austin Healey 2
A For Sale TRIUMPH 74 TR6 Dashboard w/Guages Triumph Classifieds 7
S TR4/4A How to finish dashboard? Triumph 19
Joe_Healey BN2 dashboard silver Austin Healey 0
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
T Dashboard Knob Removal Spridgets 1
A TR6 Lettering on 1971 dashboard Triumph 1
wkilleffer MGB Dashboard pad replacement issues MG 3
AHS 1968 steel dashboard - can anyone confirm? Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
H 1961 Mini MKI speedometer Housing pod & dashboard British Motor Corp 0
K TR4/4A TR4A Dashboard Veneer? Triumph 13
K TR4/4A Veneering A TR4A Dashboard? Triumph 0
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
B Dashboard Warning Lights Austin Healey 8
2billydavies TR2/3/3A dashboard/instrument panel on 1958 TR3a Triumph 4
AHS TR2/3/3A Dashboard hole identification Triumph 8
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
R 100-4 dashboard color Austin Healey 1
R 100-4 dashboard removal help Austin Healey 4
Lbp TR2/3/3A New to Forum, New TR3 Owner, Dashboard Question Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
Grannieannie Somerset dashboard Other British Cars 5
Patrick67BJ8 Additonal Gauge[s] for BJ8 Dashboard Austin Healey 13
Xte Original covering center dashboard and top dash ? Austin Healey 5
R Recovering BT7 dashboard Austin Healey 5
H Healey 100 Dashboard Color Austin Healey 10
Zimmycobra TR4/4A TR4A Dashboard question Triumph 5
af3683 Kienzle Dashboard Clock Triumph 10
Patrick67BJ8 Additional Gauges to a BJ8 Dashboard Austin Healey 6
middie Late model dashboard Spridgets 3
Zimmycobra Dashboard air vent grills Triumph 1
BugeyeNJ58 New gauges in Dashboard where radio goes... Spridgets 5
B TR6 best option for new TR6 dashboard Triumph 3
