Curse from the price of darkness.
caseyjones955
Member
Good morning. I just got this car and Im sorting the elecrical demons. NOT working--running lights, dash lights, hazzards, heater.........WORKING,brake, turn, headlamp hi/low beams, radio, tach, fuel gauge. Fuses look intact.
Although somewhat simple it is the strangest wiring diagram I have ever seen. Any ideas on what the issue might be or where I would start checking for voltage. (79 Midget)
Thanks!, its getting colder and darker around here.
Tony
drooartz
Don't know the later cars, but in lots of cases (especially with lights) the grounds are often the issue. Make sure those connections are all good and clean. Probably good to go around and clean all of the connections first, then try and chase what is still not working.
Also clean all the fuse holders and contacts before you start trouble shooting.
C
caseyjones955
Member
Thanks for the info. From what I have read so far I believe I will replace the fuseblock w/an aftermarket one and eliminate the AGC fuses. Thanks for info, going to clean all grounds/contacts right now.
Tony
C
caseyjones955
Member
I removed the Lucas fuses (cracks around contact caps) I cleaned contacts, installed new AGC fuses, Removed and replaced a few of the crustier plugs going to the fuseblock. Everything works, even dash lights/dimmer. Only the hazzards remain non functional. I will replace the fusebox as soon as I find one similiar to it. THANKS ALL for the advice, Electrical things are not my specialty.
Tony
Baz
Flasher unit behind console may be out, $3.
C
caseyjones955
Member
I was sitting here thinking that flashers are not that important and I can wait till the book came before I fix it.... then I had some flashbacks of my Fiat 124 and I will fix it right away. I dont see any way behind the console or dash, how do I access this area? I also have to replace a couple bulbs behind tach and temp gauge.
Thanks again!!
Thanks.
Tony
Baz
The console is screwed in on the side panels in the footwell, the dash doesn't need to come out.
Do you have a Haynes?
C
caseyjones955
Member
I have ordered a Haynes, in the 2 full walls of auto repair manuals I dont have anything for an MG.
I will be out there in the morning to see if I can remedy the flashers. Then after replacing a few dash light bulbs I can offer the Prince of Darkness the dorsal view of my traffic finger. At least for the time being.
drooartz
A fuse thought -- do the later Spridgets still use Lucas rated fuses? I made that mistake when I got my first LBC -- the older ones at least used Lucas fuses that look like modern cylinder style (Bussman) fuses, but are not:
Good read on fuses: https://www.drooartz.com/index.php?page=29
May not be relevant, but I'd hate to see your car go up in smoke!
JPSmit
[ QUOTE ]
[/ QUOTE ]
/ubbthreads/images/graemlins/eek.gif NO you mustn't taunt him - that would only make him mad!!! /ubbthreads/images/graemlins/nonono.gif
weewillie
good info Drew thanks /ubbthreads/images/graemlins/thumbsup.gif
C
caseyjones955
Member
The prince of darkness is already pretty ****, he told me so in a vision of my car reduced to burning embers. I already replaced the fuses according to that chart!, THANKS for the heads up on that link, it was enlightening.
Tony
PATR8 Curse you Lord Lucas Triumph 19
B The Curse of Caster Austin Healey 1
mrv8q Curse of Captain Hazelwood Triumph 10
aeronca65t The "axle curse" Spridgets 9
T TR4/4A Triumph TR4A 1965 price Triumph 8
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
tr6nitjulius For Sale "PRICE REDUCED" 4Sale: TR6 (L/R) taillight assembly Triumph Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
S Price check on TR3A valve cover Triumph Classifieds 0
G TR2/3/3A Valvoline VR1 price Triumph 3
S TR4/4A Fair price for a crankshaft? Triumph 2
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
Morris Price drop Spridgets 1
Bmekosh TR6 Fair price for this car? Triumph 16
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
W At this price..... Spridgets 3
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
jlaird Miss Agatha has a new price Spridgets 45
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
PAUL161 General MG Automotive Paint Price! MG 13
1 Price for original 57 100-6? Austin Healey 22
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
W Good price on Pacesetter Monza Muffler Spridgets 0
sqbsprite What will be the real price? Spridgets 11
B Hard Top Price Guestimate Spridgets 1
J Help me price my Bugeye? Spridgets 37
PAUL161 T-Series Engine rebuilds going up in price! MG 14
Jim_Gruber BE Bonnets - OMG the price Spridgets 5
J TR6 Is This a Fair Price for TR-6? Triumph 25
BoyRacer BN2 bellhousing - how rare - price? Austin Healey 2
G [Price] King Midget ? Spridgets 12
K Reasonable price for a Morris Minor project car? Other British Cars 4
HCE What is a fair price for a ’69 XKE? Jaguar 19
aeronca65t Replica Price Lotus 3
C What is a fair price for a Caterham? Other British Cars 2
Rut Fair price for a Midget? Spridgets 10
M Healey 3000 Mild Steel Exhaust good price Source Austin Healey 2
D TR6 TR-6 Steel Hardtop -- fair price? Triumph 4
G Fair price on O/D switch and knob? Triumph 5
CZ_Dave Yippeeee 1/2 price day at MG 0
dougie Clapped-out race car....record price? Austin Healey 3
W The price on this bonnet..... Spridgets 9
W What's a realistic price.... Spridgets 14
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
