Clutch Problem
AngliaGT
Daughter's car ('96 Corolla/Refridgerator)was having
problems going into gear.I drove it,& could get it to work
if I double-clutched it.
I tried bleeding the slave cylinder,but couldn't get
any fluid to come out.Could the slave cylinder be bad?
- Doug
That was a gravity bleed or pressure bleed?
Get a stick, long enough to hold the clutch pedal down and wedge against the front of the seat or the bottom of the steering wheel.
Work the pedal 2 or 3 times (pump) and hold down with the stick.
Jam stick into location, crack bleeder (and keep your face out of the way).
Slave, eh, usually if they go bad they leak.
Hose, could be, master, most likely, but get the air out first to see.
Was the reservoir low?
full=not leaking, slave is probably not the primary issue.
See if it will bleed as directed, do it a couple of times to get any carp (sp) out, and then see how it works. If the master is shot, as in leaking past, do the slave and probably the flex hose at the same time, as they all have similar wear issues.
I finally got it to bleed.Bled it twice.Took it for a test drive-
sometimes you have to double-clutch it to get it into gear.Crap!Does this
mean that the master cylinder is bad?
Has anyone replaced one on a '96 (or therabouts)Corolla?Looks like
one nut holds it on,on the passenger side of the firewall.Our Daughter made
a reservation to have it looked at/fixed at the dealer,but I can't see spend-
ing all that money if I can do it myself.
- Doug
Don't know where it is, but I just looked up the part on World pac. It looks like it has a standard clevis connection at the pedal, and 2 studs that pass thru the firewall.(nuts inside the car) I had to guess which engine... The cylinder has the reservoir mounted to it directly. Probably easy enough to do without paying the dealership Slave looked easy as well. Best in my experience to replace them both Good luck.
Yeah, done 'em.
Cannot remember if it's one stud and one bolt or two studs anymore.
If the catalog says two studs, then you'll need a 24" 3/8 drive extension, a good 3/8 ratchit, and a wobbly 12mm socket (could be bigger, but for some reason I remember 12), pop the clevis pin out, loosen the nuts and drop them on the floorboards, get under the bonnet, pop the line, and pull it out.
Funny twist as it comes out, if I remember.
I just did this in my Miata two days ago. The slave was leaking very slightly...could barely see it except the dust boot had some brake fluid in it. Pedal was soft and bleeding made only a slight improvement on a temporary basis. I changed the slave and master but it probably just needed slave. Cost about $55 for both at Amazon.com
Works great now. (be sure to bench-bleed master before installing....it'll save time and effort)
Wow!I worked on something.....& it works!
It only took 4+ hours.I need to get smaller fingers.I had to loosen up
the brake booster to be able to remove the clutch master cylinder.
Reminds me of working on American cars.I kept thinking "WHO was the-
genius who designed this car?".You need some tiny hands to get to some of
these parts.
....but I saved $$$ by not taking it to the dealer.
- Doug
:thumbsup:
Govtslug TR6 Clutch Problem Triumph 21
T TR2/3/3A TR3A clutch problem Triumph 15
E TR2/3/3A Tr3 a clutch hydraulics problem, again. Triumph 16
Healey Nut Clutch problem Austin Healey 5
R TR2/3/3A Tr-2 Clutch Problem Triumph 46
P TR6 Clutch problem not solved Triumph 6
MKIII_Joey Clutch Problem Austin Healey 5
M BJ8 Clutch Problem Austin Healey 4
T TR4/4A clutch problem on brand new TR4a Triumph 6
T TR6 Problem with Clutch on 1976 TR6 Triumph 12
G MGB Clutch problem MG 7
F BT7 3000 - Push rod problem on clutch slave cylinder Austin Healey 7
I TR2/3/3A Clutch and brake pedal assembly problem Triumph 4
aeronca65t Clutch pedal problem- 1275 race car Spridgets 12
M Clutch problem, a little different than usual Spridgets 8
U Spitfire Help - Clutch Problem on the Road! Triumph 11
M TR2/3/3A TR3A clutch hydraulic problem Triumph 9
J Clutch Problem - Seeking Input Austin Healey 4
K TR2/3/3A Complicted Clutch Slave Problem TR3A Triumph 12
G TR6 TR6 Clutch Problem Triumph 22
aeronca65t Common problem-clutch pedal Spridgets 2
smaceng Clutch Problem Jaguar 3
D TR6 New poster, TR6 clutch problem Triumph 10
Jims71TR Clutch Problem need Help Triumph 14
tahoe healey clutch problem Austin Healey 14
F TR6 triumph tr6 clutch problem Triumph 14
T Sqeeling Clutch Problem..SOLVED Triumph 2
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
TR_JOE250 Spitfire Spitfire clutch problem Triumph 22
F 67 austin healey 3000 clutch problem FORUM Navigation Questions 0
F 67 austin healey 3000 clutch problem Austin Healey 20
RickB Clutch problem this morning MK2 Sprite Spridgets 4
M A possible problem with the clutch Spridgets 8
bluemiata90 TR6 TR6 clutch issue, Possible bleeding problem ????? Triumph 4
A TR6 TR6 Clutch Problem Triumph 11
J T-Series clutch problem MG 13
F Frogeye clutch problem Spridgets 10
R Clutch Sticking Problem Austin Healey 4
Brosky Typical, but lucky, nice day problem [Clutch] Triumph 13
Sarastro Yet another odd clutch problem. Spridgets 5
Brosky TR6 TR6 Clutch knocking noise problem [not mine] *DELETED* Triumph 2
simpzimmer Found the Clutch Problem Triumph 1
simpzimmer Clutch Problem Triumph 1
DerekJ Clutch problem - I think! Austin Healey 14
B Do I have a problem with My New Clutch ???? Austin Healey 3
M TR6 76 TR6 clutch problem Triumph 3
G TR6 TR6 Clutch Problem Triumph 5
MattP T-Series Clutch Problem? MG 3
EMGEBE T-Series Is this a clutch problem? MG 2
