Checking out lever arm shocks
67BJ8
Can lever arm shocks on the front and rear of an AH 3000 be tested to see if they work properly while still mounted on the car?
TimK
You can push down vigorously on the fenders a few times. Then make sure it stops bouncing immediately when you stop exerting force. If it keeps oscillating (bouncing), the shock is worn.
glemon
I don't know about the fronts, but I don't trust the bounce test for the rears, between the limited travel and friction from the leaves--I had two rear shocks totall gone on my hundred, did not "bounce" when pushed down on rear fender, but did handle horribly on bumpy roads, one rear shock had frozen and the are has stripped from the shock, the other just had no resistance.
best to take them off--it is not too hard, you can check to see if the bolts are tightened down good then too, they tend to loosen up over time.
Johnny
If their the original shocks and have never been off the car it's safe to say they all should be rebuilt anyway. Good winter project, just take them off and send them off to Worlwide or etc.
J TR4/4A Fuel Pump just checking before I snap off the lever. Triumph 11
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
T General MG Checking tiers tread MG 2
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
FlyingCat Spitfire Checking/Changing Fluids Triumph 5
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
K TR2/3/3A Checking steering box End Play? Triumph 5
B TR2/3/3A Checking oil in rear axle Triumph 2
T TR4/4A Your procedure for checking out a new-used engine Triumph 6
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
E TR4/4A Checking a generator Triumph 12
5 Checking The Spedo Spridgets 11
PSJ Checking for interest - meeting of NW Organization of Spridget Handymen In Transit Spridgets 6
vette Checking RPMs Austin Healey 14
DanLewis Checking condition of rear springs on a Bugeye Spridgets 17
A TR2/3/3A checking axle float triumph tr3a Triumph 10
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
RickAnderson Checking an Engine Not in the Car? MG 2
M Checking rear break drums and pads Triumph 7
T Checking OD function w/out solenoid handy? Triumph 4
P Checking oil levels Triumph 6
drooartz Checking transmission/OD levels MG 14
N Checking a rebuilt engine Austin Healey 15
T Anyone interested in checking out a BN2 in NM? Austin Healey 14
M Newbie: Just Checking In MG 7
P CHECKING DIZZY CAP Spridgets 10
Gundy Checking B's tranny oil MG 26
T Checking for front suspension wear Spridgets 4
drooartz Checking a ribcase transmission Spridgets 2
2wrench Checking the thrust washers.....Dale? Triumph 3
KindredSpirit Just checking about spark plugs. Austin Healey 2
vping Checking an axle ratio MG 2
Hap Waldrop Plastigauging for checking crankshaft clearences Spridgets 7
S TR2/3/3A door strap checking tr3 Triumph 8
M Another New Member - Just checking things out MG 9
G Checking & filling shock absorber fluid Spridgets 9
wkilleffer Checking distributor shaft wobble MG 37
N MGB Checking out MGB's Betwix Here and There MG 3
M Checking/Changing Limited Slip Diff. Oil on XJS Jaguar 2
M Checking a temp guage Triumph 2
aeronca65t Checking Pertronix Unit Restoration & Tools 1
S Paint Checking on the Hood Austin Healey 4
G Checking leak in used radiator Restoration & Tools 3
TNMGB Checking/adding gearbox oil?? MG 34
D Checking Tranny Fluid Level Spridgets 5
N MGB 1978 MGB Coolant Level Checking MG 3
B MGB Another new owner of an MGB checking in MG 9
Andy Blackley Checking my 74B MG 2
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
