BSW Filler Plug Armstrong Rear Shocks?
twas_brillig
The filler plugs on the rear shocks didn't seem to match Imperial or Metric wrenches last night - bigger than 1/2 inch; too small for 9/16; bigger than 13 mm etc. I've got one socket set where the socket design allows them to used on both metric & imperial, and successfully used the 14 mm. Any advice as to the sizing? Possibly British Standard Whitworth?
Try this adjustable spanner :highly_amused:
normally I just grab the nut twixt thumb and forefinger....... Doug
CJD General TR BSW thread stock Triumph 2
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
timbn2 Whitworth / BSW tap and die question??? Austin Healey 25
Celtic 77 MGB Fuel filler for a 77 B. MG 12
Todd78d Sprit MK1 gear box filler Spridgets 2
Celtic 77 MGB LeMans Gas filler MG 10
Celtic 77 General MG Lever shock oil refiller MG 0
M Fuel Filler Caps Austin Healey 2
JFS Wedge Stripped gearbox filler hole thread Triumph 3
S TR2/3/3A TR3 gas filler cap Triumph 1
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
ckeithjordan TR2/3/3A Gas Filler Cap Triumph 1
Chuck9482912 Rust in new fuel filler neck Austin Healey 4
BlueMax TR2/3/3A No Body Filler On This TR3 Triumph 7
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
maxwedge5281 gas filler opening replacement Austin Healey 4
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
bugedd Aston filler cap Spridgets 8
TRMark Body Filler Mixing Board on the cheap Restoration & Tools 2
maxwedge5281 gas filler and cap options Austin Healey 9
maxwedge5281 monza fuel filler door??? Austin Healey 6
S Embarrassed to ask: Transmission/Gearbox filler location on BJ8 Austin Healey 14
S TR2/3/3A fiberglass filler Triumph 4
Rut Body work and filler Spridgets 2
steveg Steering box filler Austin Healey 0
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
andrea OIL sprayed on the under hood-TOP oil filler indaghed Austin Healey 26
D Body filler brand??? Spridgets 26
Lukens Is this my gearbox filler plug? Triumph 10
T Filler question Triumph 14
tahoe healey Gas filler tube gasket Austin Healey 11
jhorton3 Fuel Filler Hose Spridgets 0
BillD Gas Cap does fit on new tank's filler tube Spridgets 5
bighealeysource Looking for a 100-4 valve cover oil filler cap Austin Healey 0
Jeepster fuel tank filler pipe Austin Healey 8
Jim_Newman Fuel tank filler pipe Austin Healey 4
brgrmyster GT6 Original AC oil filler cap 67-68 GT6 [also TR4A]? Triumph 1
O TR2/3/3A TR3 Fuel Tank Filler Triumph 3
K oil filler cap Spridgets 0
J location of transmission oil filler on a BN-2 Austin Healey 5
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
DrEntropy Found confirmation of filler cap Lotus 14
A Gas filler cap Triumph 3
J What should I feel at oil filler pipe? Triumph 14
6 Fuel Filler Tube Color? Austin Healey 4
I What do I use to paint filler neck? Spridgets 10
Tabcon Okay...who poured green paint in my oil filler! Triumph 16
fad64b Help with "Filler Plates" Please MG 1
V TR2/3/3A TR-3B Oil Filler Cap Triumph 5
JPSmit What type of body filler do you use? Restoration & Tools 7
