Broke drill bit off in exhaust manifold bolt...
RickB
I sprayed PB blaster on the flange bolts for the past few days, today I got under there and took all 5 bolts out with no trouble.
The one that the PO broke off was a big problem. I drilled it & tried the easy out.
I went & bought a harder drill bit & drilled it some more...
The bit broke off in the hole, not enough left to grab with needle nose...
That's when I gave up for the day.
Any ideas that don't involve removing the manifolds from the head?
/bcforum/images/%%GRAEMLIN_URL%%/frown.gif
No fun there! I used to work at a VW machine shop and I often had to remove broken studs from the aluminum heads.
Is there any of the stud sticking out past the manifold or the head?
If there is some sticking past the head, bite the bullet and pull the manifold so you can get a clear shot at it with Visegrips. If it's flush to the head and you can get a small hard point against the flute of the bit and tap it anti-clockwise, there's a small chance you could loosen it and get it out. If you get the bit out, go back and keep drilling using a fresh bit and a little cutting oil. High speed but not much pressure.
In the worst case, you may have to pull the whole head off so it can be mounted and held rigid on a drill press so it can be removed and have an insert installed.
Good luck and keep us posted! Adam
Is this the bolt on the down tube ot actually into the head? I've just broken 4 outta the 6 on the downtube and have to figure a way to get them out now?
I wish there was a way to get them without removing the manifold, but I have never found a way.
Perhaps you can put a punch on the broken bit, and see if you can break it up, and then drill again.
Things would probably be easier with the manifold out.
Re: Broke drill bit off in exhaust manifold bolt..
Not the part up at the head, the down pipe part.
I'll see about drilling another hole in it tomorrow, the first one was to one side so the next will be more towards the other side. Maybe I'll get lucky.
Rick, suck it up and pull the manifold, before you do irreparable damage. Take it to a machine shop and have them remove the bolt. Even if they have to do it on a mill, it'll be cheaper than buggering it up and having to pay for a repair or a replacement manifold. With a drill bit broken off in it, it's going to either require enough heat to anneal the bit, a carbide mill or drill, or a combination of both.
Jeff
I agree-as the drilling is already off center,redrilling will probably end up with the same result,better, surer, quicker,cheaper in long run to remove it and take to machine shop
If there is any bit of the stud showing , even it it is flush, hit it with a mig welder. The welds will stick to the stud better than the cast iron plus it will put some heat into the area.
If you can create enough of a weld tit ..place a nut over the tit and fill the nut with weld.
Take a wrench and turn out the stud.
It might break off the first time but try it again as the stud will now have a real clean surface to take a weld.
Don't be afraid to turn up the welder a bit to get good deep weld.
Thanks guys, some ideas there I hadn't considered.
We have brilliant sunshine this morning, just as forcasted.
I am taking a day off work, an MG health day...
After I drink some coffee I will go out there and take another look.
If it comes down to removing the manifold, where do you get new gaskets? Is that something NAPA can get for me?
Is one kind better than others? It's been more than 20 years since I've done any gasket purchases.
Vince, did you use any PB blaster or other type of penetrating oil first?
Several days ago I put a ratchet wrench to a couple of mine and determined they had that feeling of "Go ahead punk, make my day". So I sprayed and sprayed them over three days. I was still amazed when they came right out.
Of course I bought new grade 8 hardened bolts and washers for the reassembly. I'll not tempt fate, I've broken my share of bolts in the past.
Why Grade 8, instead of Grade 5?
Reason I ask is Grade 8 is more brittle and will have more of a tendency to shear than Grade 5. Grade 5 will stretch and deform before it breaks, but Grade 8 just snaps.(shears, actually).
Just for future reference. This is when left handed drill bits work well. As you are drilling into the stud sometimes they actually cause it to break free and begin to come out. Spray them first with PB-Blaster and add some heat to help it soak in. Also, when putting in the new studs, a little Never-Seize on the stud and nut makes for easier removal next time.
The never-seize. lock-tite and the PB blaster are the best jewels so far that I have gained in this forum. Rick's predicament reminds me of the time it took four days in a New Hampshire February for me to change a thermostat on a '65 Comet. I think I broke all 3 of the [censored] bolts and two knuckles. Now with the help of the forum I fly through repairs, why just last night I finally got that light bulb in the radiator to work. just another dead short was all was, as usual.
I've busted off a few more titanium / carbide / whatever type drill bits today. I'm taking my new gaskets out now to put it together.
While the back hole on the front downtube isn't what anyone would call pristine, I have no doubt that I will be able to get this puppy back on the road today. Without removing the manifolds, ordering new gaskets, waiting around for them to arrive, breaking who knows what else in the process.
And yes, I will go and buy some never seize right now, before putting the new bolts in. Thanks for the tips & suggestions - hopefully the next post I make will be after success. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Done.
Back on the road.
Had to cheat a little, but all in all I'm pleased.
Sounds good too, there was an exhaust leak when I bought it, that turned into the flange gasket blowout.
Two new gaskets, everything cinched down tight, sounds perfect! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
You have done well! Care to share any of your cheating ways with us?
Adam
I got most of it drilled out, messed up the threads.
There was enough room to fit a 1/4 inch bolt so I used that with a washer and a nut. That's what I call cheating, but it did work.
I figure it's been going with only two bolts for a long time, it's gotta be better with two 5/16 & one 1/4.
Call be a scab if you will, but the job is done.
We went out and celebrated our 20th anniversary tonight, we went in the MGB.
Knew that was what you had done. Been there done that, why not.
At least if I ever do this again on this car it won't be hard to get that one out! /bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif
Trouble is, when you keep buying 'new' LBC's you only get to do this kind of thing once (unless you are Jack...). /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
My attempt to remove lower rear manifold stud...
i am now removing head...
Any guesstimates what hardened seats and valves would cost ?
Pic rotated CW 90deg
67 TR4a IRS
car has history of blowing out exhaust gasket 40k miles or so.
think this stud just got baked (annealed ?)
all other studs came off with lots of muscle.
note blowby scoring on head flat ...
KVH General Tech Angle Drive Broke (Repost) Triumph 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
F BJ8 Dipstick Broke Austin Healey 14
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Got_All_4 TR5/TR250 Rope trick on a broke valve spring Triumph 8
R Bugeye rebound strap bolt broke Spridgets 2
jlaird I broke eBay Spridgets 2
S TR2/3/3A exhaust manifold with rusted and broke studs Triumph 5
steveg Poly bushing broke after 1 month use Austin Healey 2
B bj8 bonnet release broke Austin Healey 11
B Help - broke down on road - battery good but no power to starter Austin Healey 17
X don't fix it if it ain't broke Spridgets 1
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
R Broke off d*mn bolt MG 3
6 HELP! something broke in the rear end... Triumph 71
G Driveline broke !! MG 38
Basil MGB Broke down on Rt66 Spotted 10
B WHOOPS! Broke the bezel Triumph 2
Keoke All of CA Not Broke Austin Healey 0
deadair Broke Down Today Triumph 14
tahoe healey Hand break - broke Austin Healey 8
G Broke the stupid heater pipe Spridgets 5
1 Window crank handle broke MG 12
mgnewbie I can't believe I broke the head bolt! MG 8
DrEntropy Brakes broke... Other Cars 13
W Broke check strap on door Triumph 4
Dadandson Broke a *^%&$#% Piston Ring Spridgets 2
davester #^*][%$@!broke@#$%^]^%!@brake@#&*$@!!^stud!*@##$!! MG 8
usaflm dang radiator broke Spridgets 5
tweety Part of my top frame broke, options? Spridgets 13
2wrench Can't believe I broke my rotor Triumph 12
B Oh crap! I broke the... Spridgets 15
T Not broke down, running great Triumph 35
1 BugEyeBrakeLightsBroke Spridgets 4
J Mg Midget 1500 gas pedal broke Spridgets 5
J Broke my harmonic balancer Triumph 15
T Long post, short question 'what is broke down' Triumph 9
T YO!! Broke a 1,000 miles Triumph 44
T Broke Down Again !! Triumph 76
G If it ain't broke, don't fix it...... Triumph 15
J Restoration without going broke -ideas? Spridgets 16
T Broke Down! Triumph 39
aeronca65t OT: Mother Ship is out of here! 2nd Diff broke! Spridgets 0
Shealey OT: Mother Ship is out of here! 2nd Diff broke! Other Cars 10
D Show & Tell........Who else broke something? Racing 17
drooartz Good drive, and broke the tach Spridgets 5
R My Carb Broke! MG 9
G I broke out in a cold sweat...... Triumph 1
S TR2/3/3A I broke the crankshaft on my TR3 Triumph 7
DrEntropy Alfa brakes broke... Other Cars 29
