Thanks, Steve. The attached pictures show the issue I am having. I purchased pre-bent S/S lines and while the bends appear correct, the long pipe seems to be a bit short and the short pipe seems to be a bit long. My suspicion is that the PO used a non standard bracket to attach the 3-way connector to the rear axle. In the picture, you can see that the bracket offsets the 3-way connector towards the right brake drum, which in turn accommodates the length of the current pipes. I also attached an illustration from the Moss site that shows the 3-way connector with no offset bracket. I'm inclined to eliminate the offset bracket, which may then work with my new pipes (hopefully). But this still leaves the question unanswered as to why the offset bracket was required to begin with? Are the existing pipes from a different Healey? Custom bent, they look to be factory bent? And the final question is if I eliminate the offset bracket, the flex hose will be closer to the battery, which is a concern (chaffing). Any insights will be much appreciated.
