BN1 Body / Chrome Question
mjobrien
Team Healey.....
Getting ready for final paint and had a few questions for the group.
1) The forward windshield feet are $50 at Moss, any reason to rechrome the old ones at that price? I would guess they would be more than that to get rechromed.
2) The Fender Beading is listed in Moss as 100-6/3000 type is this different from the typical BN1/BN2? I have the old ones that are in good shape, is it better (more correct) to reuse them or go with new?
Thanks in Advance
Michael
55 BN1 - almost ready for final paint
stevebn2bj7
In my opinion always rechrome original parts if possible. Especially parts like the windshield feet. Each car is unique in how it was fit together and your pieces will surely fit better than new parts.
For the fender beading, use the old stuff if it is still in good shape. I have used the new Moss pieces a few times and it fits well. It is probably the same part for the 100 and the six cylinder cars. You would need to cut the front piece where the windshield foot goes. Other than that it is pretty straightforward. You need to shape the rear piece as it comes rather straight.
Dave Russell
Yoda - R.I.P
I got very high quality feet from British Car Specialists - Norman Nock. Very good plating & a perfect fit. At the time, there was no plating shop that did quality work within 500 miles. If you haven't found it yet, the rear retaining/clamp bolt is hidden way up under the dash on the inside of the car.
The beading is stainless steel & nearly indestructible unless it is mashed. If it seems short on retaining clips it's easy to make new ones.
HEALEYJAG
Rechrome the old ones...quality is much better..I actually had to rechrome the reproductions I received with this car!!
Use the NEW fender beading...they are high quality..the old ones will always have little ding here and there while the new ones will look perfect..
Just my thoughts:
Pete
HEALEYJAG
Looks great..why don't you just buff out the primer and enjoy it this summer?
Keep at it..
Pete
B BN1 Overdrive issue Austin Healey 0
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
HealeyRick Wilwood Discs on a BN1 Austin Healey 1
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
Z For Sale 1954 Austin Healey 100-4 BN1 Beautiful Restoration Austin Healey Classifieds 0
Z For Sale 1955 Autsin Healey 100-4 BN1 and 1956 100-4 Race car Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
55modified Nardi hub for a BN1? Austin Healey 10
L BN1 Transmission rebuild Austin Healey 1
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
P BN1 Rear Chassis-to-Shroud Extensions Austin Healey 1
